Installation & Licensing
Autodesk software on RDS Server
10 REPLIES 10
Message 1 of 11
ebitadam
6783 Views, 10 Replies
Hello All,
We are looking into potentially moving to a Microsoft Remote Desktop Services environment and I have a few questions regarding compatibility from a hardware and software perspective before proceeding.
We will be looking at using the Autodesk Navisworks Freedom and the DWG TrueView on our RDS system.
Is the software compatible with Windows Server 2012 R2?
Is the software supported in a Remote Desktop Services environment?
Are there any specific hardware / software / operating system requirements for the software?
Are there any specific hardware or software requirements for the software within RDS mode?
Are there any specific licensing requirements when the software is running in RDS mode?
Is there anyone in the community running this software that are running this software in RDS mode and if so how is the performance of the software?
Thankyou for your time, if you require any further information please let me know.
10 REPLIES 10
Message 2 of 11
TravisNave
in reply to: ebitadam
No.
No.
Autodesk only supports Citrix environments.
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=13959101
http://knowledge.autodesk.com/support/navisworks-products/troubleshooting/caas/sfdcarticles/sfdcarti...
No.
Yes, when running Citrix.
Running the Autodesk software in this fashion is a violation of the license agreement and is unsupported.
You're welcome.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 3 of 11
dgorsman
Navisworks Freedom and DWG TrueView are relatively lightweight, so there won't be much benefit to running them remotely as opposed to having them on the users hardware except for when they have mobile, extremely lightweight systems like a tablet.  In that case might also want to look into AutoDesk Remote.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Message 4 of 11
DrawIT
in reply to: TravisNave
This isn't right - "Running the Autodesk software in this fashion is a violation of the license agreement and is unsupported."
Doesn't appy to TrueView because it doesn't have an agreement.
This isn't right - "Autodesk only supports Citrix environments. http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=13959101"
This doesn't suggest AutoDesk products will not run on other environments. It just says they partner with Citrix and which Citrix products will work.
We run TrueView on RDS no problem bar one small font problem - ongoing as I type. Smiley Happy
Message 5 of 11
TravisNave
in reply to: DrawIT
Don't confuse the issue. This thread is not about "read-only" software but
full version products.
The use of Autodesk products over remote server services is prohibited
except when using Citrix XenApp.
Thanks.
Autodesk Forums:
Message 6 of 11
DrawIT
The requester wanted an answer to this question   "Is there anyone in the community running this software that are running this software in RDS mode and if so how is the performance of the software?"
I replied for TrueView. Your answer seemed to apply to both TrueView and Navis.
So yes we are running Trueview with little problem on our RDS environment and there are no licesnsing issues without an agreement. Saying what works with Citrix isn't an answer.
Message 7 of 11
TravisNave
in reply to: DrawIT
Whatever floats your boat guy. TrueView is not a performance based product.
But that's fine. Glad it works for you. Thanks for your input. Have a good
one.
Autodesk Forums:
Tags (1)
Message 8 of 11
TravisNave
in reply to: DrawIT
one.
Autodesk Forums:
Message 9 of 11
DrawIT
It's not about me really but it's for whoever needs to know if TrueView works or not on RDS.
Message 10 of 11
TravisNave
in reply to: DrawIT
Excellent!
Autodesk Forums:
Message 11 of 11
DrawIT
Good. Then why not give Kudos?
Administrator Productivity
