Installation & Licensing
Autodesk Simulation CFD Licence problems
25 REPLIES 25
Message 1 of 26
8476 Views, 25 Replies
I recently downloaded the 2013 Autodesk Simulation CFD for Windows 64-bit student version.
I succesfully installed it, but when I try to run the software for the first time, an error message appears telling me: "Cannot initialize license manager: ADLM: startup failed"
I try to activate my product online but the form aks me for the "Activation code" which I don't have and I cannot get it as the help section suggests. So I cannot generate the licence file.
I currently have installed Autodesk Inventor 2013 for Windows 64-bit student version and it works properly.
25 REPLIES 25
Message 2 of 26
pritek
Same problem, still waiting for the answer from the helpdesk.
Message 3 of 26
pritek
Problem solved, you need to edit the locale in regedit, then works. (it only works with "en-US" value)
http://forums.autodesk.com/autodesk/attachments/autodesk/24/45250/1/registry.jpg
Message 4 of 26
1.000.000 Thanks for this lovely solution. you will not belive how huch i have bustet my brains for this.
Message 5 of 26
pritek
Your welcome 😄
Message 6 of 26
muhammednoor
in reply to: pritek
do you any idea for this problem?
I try to activate my product online but the form aks me for the "Activation code" which I don't have and I cannot get it as the help section suggests. So I cannot generate the licence file.- how to solve this problem?
Message 7 of 26
Hi muhammednoor:
In order to generate an activation code you will need the request code that is displayed on your monitor after you begin the activation procedure. Following are the steps to retrieve the request code:
1. Run the program
2. Pull down menu 'Help'
3. Click on 'About'
4. Click the Production Information button at the right hand corner
5. Click on the Activate button
6. On this page you will be able to view Product, Serial Number and Request Code
Should you encounter any further issue, you may contact our Registration and Activation Team through this link:http://usa.autodesk.com/adsk/servlet/pc/item?id=18424632&siteID=123112
Have a nice day!
Arlin Bibat
Message 8 of 26
in reply to: arlinpega.bibat
I've got the same problem, but on the website I can't register my product. After the serial no. it jumps to the request code page... So I can' give my details... What can I do in this situation? Many thanks
Message 9 of 26
Hi. I've got the one problem with Autodesk Simulation CFD 2014. My license patch can't started and I think I don't activate its. This screens shows what it is a problem. Please, sombody help me with this.
Message 11 of 26
sml.samu15
I've got the same problem too with CFD 2015 ?
Message 12 of 26
s3191086
I am having this exact issue in CFD Simulation 2015 Student. Very frustrating.
Message 13 of 26
in reply to: s3191086
hi i am facing the same issues at the moment, have you found a solution yet?
Message 14 of 26
s3191086
Actually yes I did. I believe my solution was to simply install it as stand-alone instead of using any network licensing or something similar. Try that out and see how you go. If you can't get it to work just post again and I'll dig deeper into what I did 🙂
Message 15 of 26
thanks i got it!
Message 16 of 26
in reply to: pritek
I did the same what you said.. but the same problem still exist
Message 17 of 26
I am facing this problem now in CFD2016 Student and I need a solution urgently, if you offer something to solve this problem I will be very happy
Message 18 of 26
Mark.Lancaster
@Anonymous
Welcome to the community..
There seems to be a couple of issues that users are face with..
So
What problem are you faced with?  Details would be beneficially and not just say I have the same problem..   Smiley Wink
Mark Lancaster
Message 19 of 26
in reply to: Mark.Lancaster
You are right 🙂 I faced licencing problem in CFD 2016 Student and this problem occured after installation the program and I got same error message like above . I hope that we can overcome this problem.
Thank you for your interest
Message 20 of 26
Mark.Lancaster
@Anonymous
So I'm suppose to go through every link in this posting to see which error message you're referring to and then assume I pick the correct one.  If you want assistance then just provide the actual information in your posting.
Mark Lancaster
Administrator Productivity
