Hey,
i got a studend licence for showcase 2015. The problem is, that i can not install it. 2 seconds after i started it, it stops and gives me a .txt data.
"Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=-2147024546"
Can someone help me?
Thanks a lot
Solved by andreemde. Go to Solution.
Solved by ukdxb012. Go to Solution.
Please could you try the following suggestion on this link... http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-w...
