Hello Forum We would like install Showcase 2015 Trial and get this error on Windows 8.1 French: 2
2014/9/8:18:02:58 Administrator WINW2647 === Setup started on WINW2647 by Administrator ===
2014/9/8:18:02:58 Administrator WINW2647 Path_Length: 146
2014/9/8:18:02:58 Administrator WINW2647 Current Directory C:\Autodesk\Autodesk_SC_2015_Multilingual_Win_64bit_wi_R2_fr-FR
2014/9/8:18:02:58 Administrator WINW2647 Launch
2014/9/8:18:02:58 Administrator WINW2647 CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/SHOWCASE/WI/Autodesk_SC_2015_Multilingual_Win_64bit_wi_R2_... /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/9/8:18:02:58 Administrator WINW2647 Setup Windows update reboot is pending
2014/9/8:18:03:03 Administrator WINW2647 === Setup ended ===
2014/9/8:18:20:44 Administrator WINW2647 === Setup started on WINW2647 by Administrator ===
2014/9/8:18:20:44 Administrator WINW2647 Path_Length: 146
2014/9/8:18:20:44 Administrator WINW2647 Current Directory C:\Autodesk\Autodesk_SC_2015_Multilingual_Win_64bit_wi_R2_fr-FR
2014/9/8:18:20:44 Administrator WINW2647 Launch
2014/9/8:18:20:44 Administrator WINW2647 CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/SHOWCASE/WI/Autodesk_SC_2015_Multilingual_Win_64bit_wi_R2_... /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/9/8:18:20:44 Administrator WINW2647 Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AIB0C.tmp
2014/9/8:18:21:23 Administrator WINW2647 === Setup ended ===
2014/9/8:18:20:45 Administrator WINW2647 === Setup started on WINW2647 by Administrator ===
2014/9/8:18:20:45 Administrator WINW2647 Path_Length: 146
2014/9/8:18:20:45 Administrator WINW2647 Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AIB0C.tmp
2014/9/8:18:20:45 Administrator WINW2647 Launch
2014/9/8:18:21:14 Administrator WINW2647 Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/SHOWCASE/WI/{909BEEC9-BF7F-486B-AF5B-180FACC20C7D}/SETUP_x...
2014/9/8:18:21:22 Administrator WINW2647 Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/SHOWCASE/WI/{909BEEC9-BF7F-486B-AF5B-180FACC20C7D}/SETUP_x...
2014/9/8:18:21:23 Administrator WINW2647 PageOpen LaunchDialog
2014/9/8:18:21:30 Administrator WINW2647 PageOpen LicenseDialog
2014/9/8:18:21:30 Administrator WINW2647 PageOpen ProductInfoDialog
2014/9/8:18:21:37 Administrator WINW2647 PageOpen ProductSelectionDialog2
2014/9/8:18:21:48 Administrator WINW2647 PageOpen FullProgressDialog
2014/9/8:18:21:48 Administrator WINW2647 Download Play VCREDIST2005SP1ATLX86 http://trial2.autodesk.com/SWDLDNET4/2015/SHOWCASE/WI/{909BEEC9-BF7F-486B-AF5B-180FACC20C7D}/VCREDIS...
2014/9/8:18:21:49 Administrator WINW2647 Download Complete VCREDIST2005SP1ATLX86 http://trial2.autodesk.com/SWDLDNET4/2015/SHOWCASE/WI/{909BEEC9-BF7F-486B-AF5B-180FACC20C7D}/VCREDIS...
2014/9/8:18:21:49 Administrator WINW2647 Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\WI\Autodesk Showcase 2015\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ADMINI~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/9/8:18:21:55 Administrator WINW2647 Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Succeeded
2014/9/8:18:21:55 Administrator WINW2647 Download Play VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET4/2015/SHOWCASE/WI/{909BEEC9-BF7F-486B-AF5B-180FACC20C7D}/VCREDIS...
2014/9/8:18:21:57 Administrator WINW2647 Download Complete VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET4/2015/SHOWCASE/WI/{909BEEC9-BF7F-486B-AF5B-180FACC20C7D}/VCREDIS...
2014/9/8:18:21:57 Administrator WINW2647 Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\WI\Autodesk Showcase 2015\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\ADMINI~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/9/8:18:22:02 Administrator WINW2647 Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Succeeded
2014/9/8:18:22:02 Administrator WINW2647 Download Play VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/SHOWCASE/WI/{909BEEC9-BF7F-486B-AF5B-180FACC20C7D}/VCREDIS...
2014/9/8:18:22:05 Administrator WINW2647 Download Complete VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/SHOWCASE/WI/{909BEEC9-BF7F-486B-AF5B-180FACC20C7D}/VCREDIS...
2014/9/8:18:22:05 Administrator WINW2647 Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Showcase 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\ADMINI~1\AppData\Local\Temp\vcredist_x86_2012.log
2014/9/8:18:22:07 Administrator WINW2647 Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/9/8:18:22:07 Administrator WINW2647 Download Play VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/SHOWCASE/WI/{909BEEC9-BF7F-486B-AF5B-180FACC20C7D}/VCREDIS...
2014/9/8:18:22:10 Administrator WINW2647 Download Complete VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/SHOWCASE/WI/{909BEEC9-BF7F-486B-AF5B-180FACC20C7D}/VCREDIS...
2014/9/8:18:22:10 Administrator WINW2647 Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Showcase 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\ADMINI~1\AppData\Local\Temp\vcredist_x64_2012.log
2014/9/8:18:22:11 Administrator WINW2647 Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/9/8:18:22:11 Administrator WINW2647 Download Play DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/SHOWCASE/WI/{909BEEC9-BF7F-486B-AF5B-180FACC20C7D}/DIRECTX...
2014/9/8:18:22:51 Administrator WINW2647 Download Complete DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/SHOWCASE/WI/{909BEEC9-BF7F-486B-AF5B-180FACC20C7D}/DIRECTX...
2014/9/8:18:22:51 Administrator WINW2647 Installing DirectX 9.0 Runtime: "C:\Autodesk\WI\Autodesk Showcase 2015\3rdParty\DirectX\DXSETUP.exe" /SILENT
2014/9/8:18:23:04 Administrator WINW2647 Install DirectX 9.0 Runtime Failed Failure is ignored, Result=-9
2014/9/8:18:23:05 Administrator WINW2647 Download Play CM http://trial2.autodesk.com/SWDLDNET4/2015/SHOWCASE/WI/{909BEEC9-BF7F-486B-AF5B-180FACC20C7D}/CM.tar....
2014/9/8:18:23:25 Administrator WINW2647 Download Complete CM http://trial2.autodesk.com/SWDLDNET4/2015/SHOWCASE/WI/{909BEEC9-BF7F-486B-AF5B-180FACC20C7D}/CM.tar....
2014/9/8:18:23:25 Administrator WINW2647 Installing Autodesk® Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=fr-fr SETUP_PACKAGENAME="Autodesk® Showcase® 2015" SETUP_PACKAGECODE={6E39C074-49BA-4F07-89E9-4E6DDB3A680D} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;{ABE2F70B-8D94-44E9-AA04-F0DB35063D62},{4FBC9635-AC56-4378-8FDE-C4D3ED072681},{9F6466D9-6EFC-4A10-B931-C72D1A3F1763},;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Showcase 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/9/8:18:23:35 Administrator WINW2647 Install Autodesk® Material Library 2015 Succeeded
2014/9/8:18:23:36 Administrator WINW2647 Download Play CMILB http://trial2.autodesk.com/SWDLDNET4/2015/SHOWCASE/WI/{909BEEC9-BF7F-486B-AF5B-180FACC20C7D}/CMILB.t...
2014/9/8:18:24:03 Administrator WINW2647 Download Complete CMILB http://trial2.autodesk.com/SWDLDNET4/2015/SHOWCASE/WI/{909BEEC9-BF7F-486B-AF5B-180FACC20C7D}/CMILB.t...
2014/9/8:18:24:03 Administrator WINW2647 Installing Autodesk® Material Library 2015 - Base Resolution Image Library: ADSK_EULA_STATUS=#1 MUILANG=fr-fr SETUP_PACKAGENAME="Autodesk® Showcase® 2015" SETUP_PACKAGECODE={6E39C074-49BA-4F07-89E9-4E6DDB3A680D} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Showcase 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/9/8:18:24:10 Administrator WINW2647 Install Autodesk® Material Library 2015 - Base Resolution Image Library Succeeded
2014/9/8:18:24:11 Administrator WINW2647 Download Play CMILL http://trial2.autodesk.com/SWDLDNET4/2015/SHOWCASE/WI/{909BEEC9-BF7F-486B-AF5B-180FACC20C7D}/CMILL.t...
2014/9/8:18:25:46 Administrator WINW2647 Download Complete CMILL http://trial2.autodesk.com/SWDLDNET4/2015/SHOWCASE/WI/{909BEEC9-BF7F-486B-AF5B-180FACC20C7D}/CMILL.t...
2014/9/8:18:25:46 Administrator WINW2647 Installing Autodesk® Material Library 2015 - Low Resolution Image Library: ADSK_EULA_STATUS=#1 MUILANG=fr-fr SETUP_PACKAGENAME="Autodesk® Showcase® 2015" SETUP_PACKAGECODE={6E39C074-49BA-4F07-89E9-4E6DDB3A680D} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Showcase 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/9/8:18:25:56 Administrator WINW2647 Install Autodesk® Material Library 2015 - Low Resolution Image Library Succeeded
2014/9/8:18:25:56 Administrator WINW2647 Download Play CMILM http://trial2.autodesk.com/SWDLDNET4/2015/SHOWCASE/WI/{909BEEC9-BF7F-486B-AF5B-180FACC20C7D}/CMILM.t...
2014/9/8:18:31:29 Administrator WINW2647 Download Complete CMILM http://trial2.autodesk.com/SWDLDNET4/2015/SHOWCASE/WI/{909BEEC9-BF7F-486B-AF5B-180FACC20C7D}/CMILM.t...
2014/9/8:18:31:29 Administrator WINW2647 Installing Autodesk® Material Library 2015 - Medium Resolution Image Library: ADSK_EULA_STATUS=#1 MUILANG=fr-fr SETUP_PACKAGENAME="Autodesk® Showcase® 2015" SETUP_PACKAGECODE={6E39C074-49BA-4F07-89E9-4E6DDB3A680D} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Showcase 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/9/8:18:31:45 Administrator WINW2647 Install Autodesk® Material Library 2015 - Medium Resolution Image Library Succeeded
2014/9/8:18:31:45 Administrator WINW2647 Download Play ADSYNC http://trial2.autodesk.com/SWDLDNET4/2015/SHOWCASE/WI/{909BEEC9-BF7F-486B-AF5B-180FACC20C7D}/ADSYNC_...
2014/9/8:18:32:57 Administrator WINW2647 Download Complete ADSYNC http://trial2.autodesk.com/SWDLDNET4/2015/SHOWCASE/WI/{909BEEC9-BF7F-486B-AF5B-180FACC20C7D}/ADSYNC_...
2014/9/8:18:32:57 Administrator WINW2647 Installing Autodesk 360: ADSK_EULA_STATUS=#1 MUILANG=fr-fr SETUP_PACKAGENAME="Autodesk® Showcase® 2015" SETUP_PACKAGECODE={6E39C074-49BA-4F07-89E9-4E6DDB3A680D} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Showcase 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/9/8:18:33:14 Administrator WINW2647 Install Autodesk 360 Succeeded Reboot is required
2014/9/8:18:33:15 Administrator WINW2647 Download Play RXS http://trial2.autodesk.com/SWDLDNET4/2015/SHOWCASE/WI/{909BEEC9-BF7F-486B-AF5B-180FACC20C7D}/RXS_x64...
2014/9/8:18:35:35 Administrator WINW2647 Download Complete RXS http://trial2.autodesk.com/SWDLDNET4/2015/SHOWCASE/WI/{909BEEC9-BF7F-486B-AF5B-180FACC20C7D}/RXS_x64...
2014/9/8:18:35:35 Administrator WINW2647 Installing Autodesk® Revit® Interoperability 2015 for Autodesk® Showcase: C_APP_NAME=Showcase C_APP_VER=2015 C_RES=ENU RX_PD="Showcase 2015" ADDLOCAL=RevitEngine,RPC,MACRO,DWG INSTALLDIR="C:\Program Files\Autodesk\" ADSK_EULA_STATUS=#1 MUILANG=fr-fr SETUP_PACKAGENAME="Autodesk® Showcase® 2015" SETUP_PACKAGECODE={6E39C074-49BA-4F07-89E9-4E6DDB3A680D} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=".NET Framework Runtime 3.5 SP1,.NET Framework Runtime 4.5,DirectX 9.0 Runtime,;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Showcase 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/9/8:18:36:08 Administrator WINW2647 Install Autodesk® Revit® Interoperability 2015 for Autodesk® Showcase Succeeded
2014/9/8:18:36:08 Administrator WINW2647 Download Play SHOWCASE http://trial2.autodesk.com/SWDLDNET4/2015/SHOWCASE/WI/{909BEEC9-BF7F-486B-AF5B-180FACC20C7D}/SHOWCAS...
2014/9/8:18:45:37 Administrator WINW2647 Download Complete SHOWCASE http://trial2.autodesk.com/SWDLDNET4/2015/SHOWCASE/WI/{909BEEC9-BF7F-486B-AF5B-180FACC20C7D}/SHOWCAS...
2014/9/8:18:45:38 Administrator WINW2647 Installing Autodesk® Showcase® 2015: TRANSFORMS="C:\Users\ADMINI~1\AppData\Local\Temp\_AIB0C.tmp\x64\Showcase\AutodeskShowcase9.0-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Showcase 2015" INSTALLDIR="C:\Program Files\Autodesk\Showcase 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/9/8:18:47:24 Administrator WINW2647 Install Autodesk® Showcase® 2015 Succeeded
2014/9/8:18:47:24 Administrator WINW2647 Download Play DirectConnect http://trial2.autodesk.com/SWDLDNET4/2015/SHOWCASE/WI/{909BEEC9-BF7F-486B-AF5B-180FACC20C7D}/DirectC...
2014/9/8:18:49:19 Administrator WINW2647 Download Complete DirectConnect http://trial2.autodesk.com/SWDLDNET4/2015/SHOWCASE/WI/{909BEEC9-BF7F-486B-AF5B-180FACC20C7D}/DirectC...
2014/9/8:18:49:19 Administrator WINW2647 Installing Autodesk® DirectConnect 2015: ADSK_EULA_STATUS=#1 MUILANG=fr-fr SETUP_PACKAGENAME="Autodesk® Showcase® 2015" SETUP_PACKAGECODE={6E39C074-49BA-4F07-89E9-4E6DDB3A680D} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Internet Explorer 7,Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86),Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),Microsoft Visual C++ 2012 Redistributable (x86),Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64),Microsoft Visual C++ 2008 SP1 Redistributable (x64),Microsoft Visual C++ 2010 SP1 Redistributable (x64),Microsoft Visual C++ 2012 Redistributable (x64),{FF59CB23-1800-4047-B40C-E20AE7051491},DirectX 9.0 Runtime,;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Showcase 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/9/8:18:49:51 Administrator WINW2647 Install Autodesk® DirectConnect 2015 Succeeded
2014/9/15:09:43:35 Administrator WINW2647 === Setup started on WINW2647 by Administrator ===
2014/9/15:09:43:35 Administrator WINW2647 Launch
2014/9/15:09:43:35 Administrator WINW2647 CommandLine /P {C7CE59CD-1993-44C6-A997-F17C1FA560A1} /M SHOWCASE /LANG fr-fr
2014/9/15:09:43:36 Administrator WINW2647 === Setup ended ===
2014/9/15:09:43:36 Administrator WINW2647 PageOpen MaintenanceDialog
2014/9/15:09:43:42 Administrator WINW2647 PageOpen RepairDialog
2014/9/15:09:43:49 Administrator WINW2647 PageOpen MaintVerifyReadyDialog
2014/9/15:09:43:49 Administrator WINW2647 PageOpen FullProgressDialog
2014/9/15:09:43:49 Administrator WINW2647 Installing Autodesk® Showcase® 2015: ADSK_LAUNCH_MODE="STANDALONE" ADSK_RUNNING_FROM_ADMIN="FALSE" MUILANG="fr-fr" REINSTALL="ALL" REINSTALLMODE="eum" REMOVE="" SETUP_PACKAGENAME="Autodesk® Showcase® 2015" SETUP_PACKAGECODE={6E39C074-49BA-4F07-89E9-4E6DDB3A680D} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" INSTALLDIR="C:\Program Files\Autodesk\Showcase 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/9/15:09:48:15 Administrator WINW2647 Reinstall Autodesk® Showcase® 2015 Succeeded
2014/9/15:09:48:15 Administrator WINW2647 PageOpen MaintCompleteDialog
2014/9/15:09:48:31 Administrator WINW2647 === Setup ended ===
2014/9/15:09:51:27 Administrator WINW2647 === Setup started on WINW2647 by Administrator ===
2014/9/15:09:51:27 Administrator WINW2647 Launch
2014/9/15:09:51:27 Administrator WINW2647 CommandLine /P {C7CE59CD-1993-44C6-A997-F17C1FA560A1} /M SHOWCASE /LANG fr-fr
2014/9/15:09:51:29 Administrator WINW2647 === Setup ended ===
2014/9/15:09:51:28 Administrator WINW2647 === Setup started on WINW2647 by Administrator ===
2014/9/15:09:51:28 Administrator WINW2647 Launch
2014/9/15:09:51:28 Administrator WINW2647 PageOpen MaintenanceDialog
2014/9/15:09:51:30 Administrator WINW2647 PageOpen MaintVerifyReadyDialog
2014/9/15:09:51:32 Administrator WINW2647 PageOpen FullProgressDialog
2014/9/15:09:51:32 Administrator WINW2647 Installing Autodesk® Showcase® 2015: REMOVE=ALL INSTALLDIR="C:\Program Files\Autodesk\Showcase 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/9/15:09:53:59 Administrator WINW2647 Uninstall Autodesk® Showcase® 2015 Succeeded
2014/9/15:09:53:59 Administrator WINW2647 PageOpen MaintCompleteDialog
2014/9/15:09:54:22 Administrator WINW2647 === Setup ended ===
2014/9/15:10:00:41 Administrator WINW2647 === Setup started on WINW2647 by Administrator ===
2014/9/15:10:00:41 Administrator WINW2647 Path_Length: 146
2014/9/15:10:00:41 Administrator WINW2647 Current Directory C:\Autodesk\Autodesk_SC_2015_Multilingual_Win_64bit_wi_R2_fr-FR
2014/9/15:10:00:41 Administrator WINW2647 Launch
2014/9/15:10:00:41 Administrator WINW2647 CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/SHOWCASE/WI/Autodesk_SC_2015_Multilingual_Win_64bit_wi_R2_... /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/9/15:10:00:41 Administrator WINW2647 Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI4CE9.tmp
2014/9/15:10:00:42 Administrator WINW2647 === Setup ended ===
2014/9/15:10:00:42 Administrator WINW2647 === Setup started on WINW2647 by Administrator ===
2014/9/15:10:00:42 Administrator WINW2647 Path_Length: 146
2014/9/15:10:00:42 Administrator WINW2647 Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI4CE9.tmp
2014/9/15:10:00:42 Administrator WINW2647 Launch
2014/9/15:10:00:42 Administrator WINW2647 Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/SHOWCASE/WI/{909BEEC9-BF7F-486B-AF5B-180FACC20C7D}/SETUP_x...
2014/9/15:10:00:42 Administrator WINW2647 PageOpen LaunchDialog
2014/9/15:10:00:52 Administrator WINW2647 PageOpen LicenseDialog
2014/9/15:10:00:52 Administrator WINW2647 PageOpen ProductInfoDialog
2014/9/15:10:01:02 Administrator WINW2647 PageOpen ProductSelectionDialog2
2014/9/15:10:01:07 Administrator WINW2647 PageOpen FullProgressDialog
2014/9/15:10:01:07 Administrator WINW2647 Download Skipped VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/SHOWCASE/WI/{909BEEC9-BF7F-486B-AF5B-180FACC20C7D}/VCREDIS...
2014/9/15:10:01:07 Administrator WINW2647 Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Showcase 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\ADMINI~1\AppData\Local\Temp\vcredist_x86_2012.log
2014/9/15:10:01:21 Administrator WINW2647 Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/9/15:10:01:21 Administrator WINW2647 Download Skipped VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/SHOWCASE/WI/{909BEEC9-BF7F-486B-AF5B-180FACC20C7D}/VCREDIS...
2014/9/15:10:01:21 Administrator WINW2647 Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Showcase 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\ADMINI~1\AppData\Local\Temp\vcredist_x64_2012.log
2014/9/15:10:01:34 Administrator WINW2647 Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/9/15:10:01:34 Administrator WINW2647 Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/SHOWCASE/WI/{909BEEC9-BF7F-486B-AF5B-180FACC20C7D}/DIRECTX...
2014/9/15:10:01:34 Administrator WINW2647 Installing DirectX 9.0 Runtime: "C:\Autodesk\WI\Autodesk Showcase 2015\3rdParty\DirectX\DXSETUP.exe" /SILENT
2014/9/15:10:01:51 Administrator WINW2647 Install DirectX 9.0 Runtime Succeeded
2014/9/15:10:01:51 Administrator WINW2647 Download Skipped SHOWCASE http://trial2.autodesk.com/SWDLDNET4/2015/SHOWCASE/WI/{909BEEC9-BF7F-486B-AF5B-180FACC20C7D}/SHOWCAS...
2014/9/15:10:01:51 Administrator WINW2647 Installing Autodesk® Showcase® 2015: TRANSFORMS="C:\Users\ADMINI~1\AppData\Local\Temp\_AI4CE9.tmp\x64\Showcase\AutodeskShowcase9.0-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Showcase 2015" INSTALLDIR="C:\Program Files\Autodesk\Showcase 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/9/15:10:07:16 Administrator WINW2647 Install Autodesk® Showcase® 2015 Failed Installation aborted, Result=1603
2014/9/15:10:07:16 Administrator WINW2647 Rollback DirectX 9.0 Runtime Failed Failure is ignored, Result=1619
2014/9/15:10:07:16 Administrator WINW2647 Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2014/9/15:10:07:16 Administrator WINW2647 Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2014/9/15:10:07:16 Administrator WINW2647 PageOpen InstallCompleteDialog
2014/9/15:10:16:43 Administrator WINW2647 === Setup ended ===
2014/9/15:10:16:58 Administrator WINW2647 === Setup started on WINW2647 by Administrator ===
2014/9/15:10:16:58 Administrator WINW2647 Path_Length: 146
2014/9/15:10:16:58 Administrator WINW2647 Current Directory C:\Autodesk\Autodesk_SC_2015_Multilingual_Win_64bit_wi_R2_fr-FR
2014/9/15:10:16:58 Administrator WINW2647 Launch
2014/9/15:10:16:58 Administrator WINW2647 CommandLine /URL "http://trial2.autodesk.com/SWDLDNET4/2015/SHOWCASE/WI/Autodesk_SC_2015_Multilingual_Win_64bit_wi_R2_... /akamai
2014/9/15:10:16:58 Administrator WINW2647 Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI337C.tmp
2014/9/15:10:16:59 Administrator WINW2647 === Setup ended ===
2014/9/15:10:16:58 Administrator WINW2647 Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/SHOWCASE/WI/{909BEEC9-BF7F-486B-AF5B-180FACC20C7D}/SETUP_x...
2014/9/15:10:16:58 Administrator WINW2647 PageOpen LaunchDialog
2014/9/15:10:17:01 Administrator WINW2647 PageOpen LicenseDialog
2014/9/15:10:17:04 Administrator WINW2647 PageOpen ProductSelectionDialog2
2014/9/15:10:17:11 Administrator WINW2647 === Setup ended ===
2014/9/15:10:17:20 Administrator WINW2647 === Setup started on WINW2647 by Administrator ===
2014/9/15:10:17:20 Administrator WINW2647 Path_Length: 146
2014/9/15:10:17:20 Administrator WINW2647 Current Directory C:\Autodesk\Autodesk_SC_2015_Multilingual_Win_64bit_wi_R2_fr-FR
2014/9/15:10:17:20 Administrator WINW2647 Launch
2014/9/15:10:17:20 Administrator WINW2647 CommandLine /URL "http://trial2.autodesk.com/SWDLDNET4/2015/SHOWCASE/WI/Autodesk_SC_2015_Multilingual_Win_64bit_wi_R2_... /akamai
2014/9/15:10:17:20 Administrator WINW2647 Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI8B8F.tmp
2014/9/15:10:17:21 Administrator WINW2647 === Setup ended ===
2014/9/15:10:17:21 Administrator WINW2647 === Setup started on WINW2647 by Administrator ===
2014/9/15:10:17:21 Administrator WINW2647 Path_Length: 146
2014/9/15:10:17:21 Administrator WINW2647 Current Directory C:\Users\ADMINI~1\AppData\Local\Temp\_AI8B8F.tmp
2014/9/15:10:17:21 Administrator WINW2647 Launch
2014/9/15:10:17:21 Administrator WINW2647 Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/SHOWCASE/WI/{909BEEC9-BF7F-486B-AF5B-180FACC20C7D}/SETUP_x...
2014/9/15:10:17:21 Administrator WINW2647 PageOpen LaunchDialog
2014/9/15:10:17:23 Administrator WINW2647 PageOpen LicenseDialog
2014/9/15:10:17:33 Administrator WINW2647 PageOpen ProductInfoDialog
2014/9/15:10:17:40 Administrator WINW2647 PageOpen ProductSelectionDialog2
2014/9/15:10:17:44 Administrator WINW2647 PageOpen FullProgressDialog
2014/9/15:10:17:45 Administrator WINW2647 Download Skipped VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/SHOWCASE/WI/{909BEEC9-BF7F-486B-AF5B-180FACC20C7D}/VCREDIS...
2014/9/15:10:17:45 Administrator WINW2647 Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Showcase 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\ADMINI~1\AppData\Local\Temp\vcredist_x86_2012.log
2014/9/15:10:17:46 Administrator WINW2647 Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/9/15:10:17:46 Administrator WINW2647 Download Skipped VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/SHOWCASE/WI/{909BEEC9-BF7F-486B-AF5B-180FACC20C7D}/VCREDIS...
2014/9/15:10:17:46 Administrator WINW2647 Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Showcase 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\ADMINI~1\AppData\Local\Temp\vcredist_x64_2012.log
2014/9/15:10:17:46 Administrator WINW2647 Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/9/15:10:17:46 Administrator WINW2647 Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/SHOWCASE/WI/{909BEEC9-BF7F-486B-AF5B-180FACC20C7D}/DIRECTX...
2014/9/15:10:17:46 Administrator WINW2647 Installing DirectX 9.0 Runtime: "C:\Autodesk\WI\Autodesk Showcase 2015\3rdParty\DirectX\DXSETUP.exe" /SILENT
2014/9/15:10:18:04 Administrator WINW2647 Install DirectX 9.0 Runtime Succeeded
2014/9/15:10:18:04 Administrator WINW2647 Download Skipped SHOWCASE http://trial2.autodesk.com/SWDLDNET4/2015/SHOWCASE/WI/{909BEEC9-BF7F-486B-AF5B-180FACC20C7D}/SHOWCAS...
2014/9/15:10:18:05 Administrator WINW2647 Installing Autodesk® Showcase® 2015: TRANSFORMS="C:\Users\ADMINI~1\AppData\Local\Temp\_AI8B8F.tmp\x64\Showcase\AutodeskShowcase9.0-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Showcase 2015" INSTALLDIR="C:\Program Files\Autodesk\Showcase 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/9/15:10:27:38 Administrator WINW2647 Install Autodesk® Showcase® 2015 Failed Installation aborted, Result=1603
2014/9/15:10:27:38 Administrator WINW2647 Rollback DirectX 9.0 Runtime Failed Failure is ignored, Result=1619
2014/9/15:10:27:39 Administrator WINW2647 Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2014/9/15:10:27:39 Administrator WINW2647 Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2014/9/15:10:27:39 Administrator WINW2647 PageOpen InstallCompleteDialog
2014/9/15:10:28:52 Administrator WINW2647 === Setup ended ===
