Installation & Licensing
Autodesk Showcase 2012- Help needed
9 REPLIES 9
Message 1 of 10
autodeskasad
1505 Views, 9 Replies
I have installed Autodesk showcase 2012 and when I try to open it up, I see an error saying " Autodesk Showcase 2012 SP1: window initialization failed. Your hardware configuration may not be supported". Please view the image below:
I have installed the service pack but still it showing the same error. Any suggestions and comments would be much appreciated,
Thanks.
9 REPLIES 9
Message 2 of 10
DarrenP
in reply to: autodeskasad
what are your system requirements?
it says in the error message that your hardware may not be supported
DarrenP
Message 3 of 10
autodeskasad
in reply to: DarrenP
Kindly view the attachments for the specifications of my laptop.
Message 4 of 10
DarrenP
thats a hardware problem
you need to upgrade your graphics card to run showcase
you can not run showcase on that video card
DarrenP
Message 5 of 10
autodeskasad
Can you suggest me which graphic card should I have and if it is possible to upgrade a graphic card on a dell studio laptop?
Message 6 of 10
DarrenP
you need to talk to dell about upgrading the laptop
you can use this to determine a graphics card: http://usa.autodesk.com/adsk/servlet/cert?siteID=123112&id=16391880
DarrenP
Message 7 of 10
autodeskasad
ok, thanks alot for all the inforamation. 🙂
Message 8 of 10
signmeup
I get the same error. Z400 workstation (6Gb) with Quadro 600 graphics card (1Gb). Windows XP x64 SP2.
Product Design Suite 2017, HP Z800 Xeon X5680 @ 3.33GHz x2, CPU x24, 96Gb, Nvidia Quadro 5000
Message 9 of 10
DarrenP
in reply to: signmeup
did you read this whole thread?
DarrenP
Message 10 of 10
signmeup
is that a trick question?
Administrator Productivity
