I have installed Autodesk showcase 2012 and when I try to open it up, I see an error saying " Autodesk Showcase 2012 SP1: window initialization failed. Your hardware configuration may not be supported". Please view the image below:
I have installed the service pack but still it showing the same error. Any suggestions and comments would be much appreciated,
Thanks.
what are your system requirements?
it says in the error message that your hardware may not be supported
DarrenP
Kindly view the attachments for the specifications of my laptop.
thats a hardware problem
you need to upgrade your graphics card to run showcase
you can not run showcase on that video card
DarrenP
Can you suggest me which graphic card should I have and if it is possible to upgrade a graphic card on a dell studio laptop?
you need to talk to dell about upgrading the laptop
you can use this to determine a graphics card: http://usa.autodesk.com/adsk/servlet/cert?siteID=123112&id=16391880
DarrenP
I get the same error. Z400 workstation (6Gb) with Quadro 600 graphics card (1Gb). Windows XP x64 SP2.
did you read this whole thread?
DarrenP
is that a trick question?
