I've tried to install autodesk before however nothing really seemed to help. It's be almost a year and I actually really need the program to install now. I've tried most of the methods and now I have a new computer that I tried to extract it on. Currently if I execute Autodesk Inventor 2014 Eng 64 niy dim 002 002.sfx then it would be stalled at (8.09GB of 8.80GB) whereas if I were to execute the Autodesk Inventor 2014 Eng 64 niy dim 001 002.sfx file I would be stuck at (8.09GB or 8.80GB). Also if I execute the Autodesk Inventor 2014 Eng 64 niy dim 002 002.sfx file it will be stuck at 10 seconds and the Autodesk Inventor 2014 Eng 64 niy dim 001 002.sfx file would be stuck at 9 seconds although the sizes are the same
Solved by lynn_zhang. Go to Solution.
Hi @NguyenBtp
Sorry about your installation issue! Perhaps you can try re-downloading the product and re-install it. You can download Inventor 2014 Eng 64bit from our Virtual Agent following the instructions. Hope this helps.
