hi all
Did anyone had a problem like this before?
2011/10/18:21:21:33 vincent VINCENT-PC === Setup started on VINCENT-PC by vincent === 2011/10/18:21:21:33 vincent VINCENT-PC Launch 2011/10/18:21:22:22 vincent VINCENT-PC === Setup ended === 2011/10/18:21:21:34 vincent VINCENT-PC === Setup started on VINCENT-PC by vincent === 2011/10/18:21:21:34 vincent VINCENT-PC Launch 2011/10/18:21:22:23 vincent VINCENT-PC PageOpen LaunchDialog 2011/10/18:21:23:07 vincent VINCENT-PC PageOpen LicenseDialog 2011/10/18:21:23:13 vincent VINCENT-PC PageOpen ProductInfoDialog 2011/10/18:21:23:24 vincent VINCENT-PC PageOpen ProductSelectionDialog2 2011/10/18:21:25:17 vincent VINCENT-PC PageOpen FullProgressDialog 2011/10/18:21:25:17 vincent VINCENT-PC Installing .NET Framework Runtime 3.5 SP1 Language Pack: J:\wx\software\mep\ /q /norestart /c:"install.exe /qn" 2011/10/18:21:25:17 vincent VINCENT-PC Install .NET Framework Runtime 3.5 SP1 Language Pack Failed Failure is ignored, Result=5 2011/10/18:21:25:17 vincent VINCENT-PC Installing DirectX® Runtime: J:\wx\software\mep\3rdParty\DirectX\DXSETUP.exe /silent 2011/10/18:21:26:03 vincent VINCENT-PC Install DirectX® Runtime Succeeded 2011/10/18:21:26:04 vincent VINCENT-PC Installing Autodesk® Revit® MEP 2012: TRANSFORMS="J:\wx\software\mep\x86\zh-cn\RME2012\RME2012.mst;C:\Users\vincent\AppData\Local\Temp\_AIF806.tmp\x86\RME2012\RME2012-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="J:\wx\software\mep\" INSTALLDIR="D:\Program Files\Professional Software\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2011/10/18:21:26:45 vincent VINCENT-PC Install Autodesk® Revit® MEP 2012 Failed Installation aborted, Result=1603 2011/10/18:21:26:45 vincent VINCENT-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 a
At this moment and unfortunately I can't install Autodesk Revit MEP 2012, can anyone help me to solve this instalation problem?
Thanks on advance for all help you can provide me.
It looks like you're installing the software from a network location... Copy the files down to your machine, clear the temp directory and disable your antivirus program then run the installer again.
Let me know if this resolves the issue.
If this information was helpful, please consider using the Accept Solution
Darin Green
Director of Customer Support
Synergis Engineering Design Solutions
Facebook | Twitter | LinkedIn
still the same .
Uninstall .NET Framework 3.5 and reinstall it from the MEP installation files. The installation file should be in the following directory.
...\3rdParty\NET
Darin Green
you know! win7 can not install .netframwork 3.5 .We can only turn on it.
but i can install architecture2012 and structure2012.
That's right... I forgot about windows 7 framework configuration.
In the installation log file you post, shows an error for the .NET Framework 3.5 language pack. Within the Add\Remove Programs, select "Turn Windows Features On or Off" link on the left side of the window. When the dialog box open, un-check "Microsoft .NET Framework 3.5.1" click OK, then go back in to enable it.
You should also have .NET Framework 4 Client and Extended within the Add\Remove programs window. If this is not listed, install it from the media directory.
\3rdParty\NET
Darin Green
