Installation & Licensing
Autodesk Revit MEP 2012 - Instalation Error - Help please!!!!
6 REPLIES 6
876 Views, 6 Replies
hi all
Did anyone had a problem like this before?
2011/10/18:21:21:33	vincent	VINCENT-PC	=== Setup started on VINCENT-PC by vincent ===
2011/10/18:21:21:33	vincent	VINCENT-PC	Launch
2011/10/18:21:22:22	vincent	VINCENT-PC	=== Setup ended ===
2011/10/18:21:21:34	vincent	VINCENT-PC	=== Setup started on VINCENT-PC by vincent ===
2011/10/18:21:21:34	vincent	VINCENT-PC	Launch
2011/10/18:21:22:23	vincent	VINCENT-PC	PageOpen	LaunchDialog
2011/10/18:21:23:07	vincent	VINCENT-PC	PageOpen	LicenseDialog
2011/10/18:21:23:13	vincent	VINCENT-PC	PageOpen	ProductInfoDialog
2011/10/18:21:23:24	vincent	VINCENT-PC	PageOpen	ProductSelectionDialog2
2011/10/18:21:25:17	vincent	VINCENT-PC	PageOpen	FullProgressDialog
2011/10/18:21:25:17	vincent	VINCENT-PC	Installing .NET Framework Runtime 3.5 SP1 Language Pack: J:\wx\software\mep\ /q /norestart /c:"install.exe /qn"
2011/10/18:21:25:17	vincent	VINCENT-PC	Install	.NET Framework Runtime 3.5 SP1 Language Pack	Failed	Failure is ignored, Result=5
2011/10/18:21:25:17	vincent	VINCENT-PC	Installing DirectX® Runtime: J:\wx\software\mep\3rdParty\DirectX\DXSETUP.exe /silent
2011/10/18:21:26:03	vincent	VINCENT-PC	Install	DirectX® Runtime	Succeeded
2011/10/18:21:26:04	vincent	VINCENT-PC	Installing Autodesk® Revit® MEP 2012:  TRANSFORMS="J:\wx\software\mep\x86\zh-cn\RME2012\RME2012.mst;C:\Users\vincent\AppData\Local\Temp\_AIF806.tmp\x86\RME2012\RME2012-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="J:\wx\software\mep\" INSTALLDIR="D:\Program Files\Professional Software\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2011/10/18:21:26:45	vincent	VINCENT-PC	Install	Autodesk® Revit® MEP 2012	Failed	Installation aborted, Result=1603
2011/10/18:21:26:45	vincent	VINCENT-PC	Rollback	DirectX® Runtime	Failed	Failure is ignored, Result=1619
a
At this moment and unfortunately I can't install Autodesk Revit MEP 2012, can anyone help me to solve this instalation problem?
Thanks on advance for all help you can provide me.
6 REPLIES 6
Darin.Green
in reply to: 198905150627
It looks like you're installing the software from a network location... Copy the files down to your machine, clear the temp directory and disable your antivirus program then run the installer again.
Let me know if this resolves the issue.
If this information was helpful, please consider using the Accept Solution
in reply to: Darin.Green
still the same .
When I was reloading a system(win7 Enterprise Edition)
ths all the same
Darin.Green
Uninstall .NET Framework 3.5 and reinstall it from the MEP installation files. The installation file should be in the following directory.
...\3rdParty\NET
you know! win7 can not install .netframwork 3.5   .We can only turn on it.
but i can install architecture2012 and structure2012.
Darin.Green
That's right... I forgot about windows 7 framework configuration.
In the installation log file you post, shows an error for the .NET Framework 3.5 language pack. Within the Add\Remove Programs, select "Turn Windows Features On or Off" link on the left side of the window. When the dialog box open, un-check "Microsoft .NET Framework 3.5.1" click OK, then go back in to enable it.
You should also have .NET Framework 4 Client and Extended within the Add\Remove programs window. If this is not listed, install it from the media directory.
\3rdParty\NET
I have been successfully installed on 64 - bit systems   .    ths all the same!
Administrator Productivity
