Installation & Licensing
Autodesk Revit 2015 on Mac using Bootcamp with Windows 7 Professional
2 REPLIES 2
pj
1171 Views, 2 Replies
I've installed windows profession under bootcamp and are trying to install Autodesk Revit 2015, Even though Autodesk say that the OS is supported when it comes to install from the popup installation menu is is locked out and says the the OS is not supported
2 REPLIES 2
TravisNave
in reply to: pj
Minimum requirements are Windows 7 SP1.  You might not have the service pack installed for Windows yet.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
pj
in reply to: TravisNave
Perfect, simple as that !
Thank you
Dezine 1
Administrator Productivity
