Hi there,
I'm a studdent and I am trying to activate Autodesk Revit 2015.
I have received my activation code from Autodesk.
After pasting it in the *Manually activate option.
I have this Error :
Registration-Activation Error (0015.111)
There is a problem with the activation code that you entered. Click one of the following links.
I need assistance please.
Thank you.
Solved by joane.bonghanoy. Go to Solution.
Hi @jerominus6,
I was able to pull up your Student Serial Number for Autodesk Revit 2015. I sent via Private Message (small envelope beside your profile name) the Activation Code.
I suggest that you copy and paste it to the field where you need to enter the Code to avoid any errors.
If you still need further assistance, please contact the Activation and Registration team directly:
1. Visit http://knowledge.autodesk.com/contactus
2. Select “Activation & Registration” or “License Management”
3. Select appropriate subtopics from the pull-down menus
4. Select “I Still Need Help” if you need personal assistance
hey , this problem of registration activation error 0015.1111 is also coming when i try to install the revit architecture 2015 in my laptop .
kindly solve my problem.
This is a public forum, please refrain from posting serial numbers or personal information
Edited by
Discussion_Admin
Welcome to the community and hopefully my (or someone else) reply will be beneficially to you.
WARNING: This is a worldwide public user community and it's important that you do not include/share your serial # in your posting/attachments. I will have the moderator remove your serial # in order to protect your information. For the future please keep that rule in mind.
I would suggest trying the Autodesk Register Once web site to activate your software. Link to that site is in my signature.
Mark Lancaster
& Autodesk Services MarketPlace Provider
Welcome to the Autodesk User's Community..
Didn't get what? Can you explain what you are talking about?
Mark Lancaster
