Installation & Licensing
Autodesk Revit 2014 Installation Hard Drive
3 REPLIES 3
924 Views, 3 Replies
I am having issues installing Acad Revit 2014 on Windows 7 (stand-alone) as it demands on being installed on C:. In my case C is a 64GB SSD with only windows installed on it - obviously too small but without a chance of getting any bigger. Is there a way of installing Revit on an other drive? Thanx a lot!!!
3 REPLIES 3
DannyHubbard
Check out this previous post on this subject.
http://forums.autodesk.com/t5/Installation-Licensing/Can-t-Install-on-a-non-bootable-Hard-drive/m-p/...
Danny
Danny Hubbard
QA Analyst
dembkod
GePichleri,
Hello. In most cases you can change the installation path as you are setting up the program installation. If you are installing from a Suite installer it will force the whole suite to be on the same drive.
So if you installed Autocad from the suite installer and then tried to use that same installer and install another program, like Revit on a different drive, the installer will not let you. It wants to keep the installs together.
Thank you for taking part in our community!
David Dembkoski
in reply to: dembkod
Thx for the answer! I will try that then 🙂
Is that a common knowledge because I could not find that on the net.
Thank you very much!
best!
Administrator Productivity
