I need some help with installation of Revit 2012, and Inventor Professional 2012.
I get as far as:
Enter SN, and Product Key--Configure Installation--Install Button--Nothing Installs (Errors) FOR BOTH PRODUCTS
Attached are the LogFiles from the installation from each of the programs...
Any Help Is Appreciated,
Amanda
Solved by emily.xu. Go to Solution.
Hi Amanda
Welcome to Autodesk Community!
I checked the log file, the installation failed at VC++ 2005 and 2010. Please try to remove VC++ 2005 and 2010 from your Control Panel if exist.Then run the installation, if still fail:
1 Try to login your system with a local admin user
2 Try to install VC++ 2005 and 2010 manualy from the folder: 3rdParty\x64(or X86)\VCRedist.
Hope that helps.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
