Installation & Licensing
Autodesk Quantity takeoff 2012 - "Can't find End User License Agreement"?
17 REPLIES 17
Message 1 of 18
fuglsang1000
12052 Views, 17 Replies
I have downloaded Autodesk Quantity Takeoff 2012 from students.autodesk.com (and have also tried to download from usa.autodesk.com), but when i open setup.exe and choses install i get the message:
And the installation program closes down. Why cant i install?
I have tried the following - suggested by Derrick from autodesk support center:
"If this happens when you download and try to install the software from the Education Community this means there is a problem with the installation file, and it will not work on your computer.
To resolve this issue, please do the following:
1.     Delete the file you downloaded.
2.     Next go to Start> Accessories> System Tools> Disc Cleanup and run that utility to clear your temp files, etc.
3.     Reboot your machine.
4.     Turn off your security software - anti-virus programs, firewalls, etc. can block downloads.
5.     Go to your country's main Autodesk website and download the trial version of the software*.
6.     Install the product.
7.     Re-enable your security software.
8.     Get your product key and serial number from the page you downloaded from.
9.      Launch the product you are trying to activate.
10.   A splash screen should come up with two buttons.
11.   Click on the one labeled “Activate” and follow the prompts.
*The trial version is the same as the commercial, free student, and purchased education version; the only difference is that it lacks a serial number. The only difference between the commercial, free, and purchased educational versions is their serial numbers.
What to do?
- Thanks
17 REPLIES 17
Message 2 of 18
copy "all other countries.rtf" file from the folder named EULA2 to EULA in the installation directory.
If you have a DVD you will need to copy the content to local hard disk before you do this.
please post the result.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Autodesk, Inc.
Message 3 of 18
m9905101
in reply to: hashim.mundol
I also have same problem, i already followed the step which was posted on top trying to solve, but it's failed
i have no DVD, I download Quantity Takeoff from Autodesk Education Community
Can i find installation directory on the this website?
Thanks for repling
Message 4 of 18
hashim.mundol
in reply to: m9905101
If you have downloaded the installation files are in c:\autodesk
Hashim Mundol
Autodesk, Inc.
Message 5 of 18
m9905101
i already copied the file "all other countries.rtf" file from the folder named EULA2 to EULA
still got a same result "Can't find End License Agreement"
enclosed error message
thanks for repling
Message 6 of 18
hashim.mundol
If you change the country in the license agreement does it work,
May I know which country you are selecting (selected by default)
thanks
Hashim Mundol
Autodesk, Inc.
Message 7 of 18
bh45
in reply to: fuglsang1000
is it not because it Can't find the united kingdom End User License Agreement?
Message 8 of 18
hashim.mundol
in reply to: bh45
it should take "All Other Countries" file.
Hashim Mundol
Autodesk, Inc.
Message 9 of 18
It worked!
I did what you described, and the program is install without any problems..
Thanks a lot!
Message 10 of 18
AntoniaDD
Hi
I have followed your advice. I have copied "all other countries.rtf" file from the folder named EULA2 to EULA in the installation directory.  And it worked.
Thank you so much.
Antonia Del Debbio
Message 11 of 18
thomas.workman
in reply to: AntoniaDD
copying the all other countries rft folder worked for me tto, cheers
Message 12 of 18
jmc9
I actually bought the Building Design Premium, meaning that the product was physically sent to me from Autodesk and I am getting the same error. However, my situation is a little different. There is no EULA2 folder, just an EULA folder. The EULA folder does contain the 'all other countries'. Any other solutions?
Message 13 of 18
hashim.mundol
in reply to: jmc9
Please try to copy the EULA folder to EULA2 folder. (media has to be copied to the local disk first)
Hashim Mundol
Autodesk, Inc.
Message 14 of 18
jmc9
in reply to: thomas.workman
Unfortunately both options did not work. There is no original Eula2 folder, so I created one and pasted all the contents from the Eula inside. It still did not work. Could it be the system that I am running? I am above the system minimum. This is what I am running.
AMD Phenom II X4 960T Processor 3.00 GHz
16 GB ram
64-bit Operating Syste
Message 15 of 18
nice
but istalling hasn't continued
Message 16 of 18
Thanks a lot has helped me a lot
Message 17 of 18
I found the solution in the installation folder is the "eula" folder inside the file "AdskLicense" find your country copy the data and creates a text file. "txt" in my case was "English.txt" and copy it to the same folder "eula" where are the data installation.
Greetings from Colombia!
Español: encontre la solucion, en la carpeta de instalacion esta la carpeta "eula" dentro esta el archivo "AdskLicense" busca tu pais copia los datos y crea un archivo de texto ".txt" en mi caso fue "English.txt" y copialo a la misma carpeta "eula" donde estan los datos de instalacion.
Saludos desde Colombia!!
Message 18 of 18
moh_elg2000
thans for all copy the files from eula2 to eula solve the problem
Administrator Productivity
