Installation & Licensing
New Member
0 Kudos
Post 11 of 18
Re: Autodesk Quantity takeoff 2012 - "Can't find End User License Agreement
11-28-2011 10:53 AM in reply to: AntoniaDD
copying the all other countries rft folder worked for me tto, cheers
Member
0 Kudos
Post 12 of 18
01-16-2012 04:28 PM in reply to: fuglsang1000
I actually bought the Building Design Premium, meaning that the product was physically sent to me from Autodesk and I am getting the same error. However, my situation is a little different. There is no EULA2 folder, just an EULA folder. The EULA folder does contain the 'all other countries'. Any other solutions?
Product Support
52 Kudos
Post 13 of 18
01-17-2012 12:53 AM in reply to: jmc9
Please try to copy the EULA folder to EULA2 folder. (media has to be copied to the local disk first)
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Member
0 Kudos
Post 14 of 18
01-17-2012 08:14 AM in reply to: thomas.workman
Unfortunately both options did not work. There is no original Eula2 folder, so I created one and pasted all the contents from the Eula inside. It still did not work. Could it be the system that I am running? I am above the system minimum. This is what I am running.
AMD Phenom II X4 960T Processor 3.00 GHz
16 GB ram
64-bit Operating Syste
New Member
0 Kudos
Post 15 of 18
03-20-2012 11:39 AM in reply to: fuglsang1000
nice
but istalling hasn't continued
New Member
0 Kudos
Post 16 of 18
10-19-2012 03:03 PM in reply to: hashim.mundol
Thanks a lot has helped me a lot
New Member
0 Kudos
Post 17 of 18
12-13-2013 03:57 PM in reply to: fuglsang1000
I found the solution in the installation folder is the "eula" folder inside the file "AdskLicense" find your country copy the data and creates a text file. "txt" in my case was "English.txt" and copy it to the same folder "eula" where are the data installation.
Greetings from Colombia!
Español: encontre la solucion, en la carpeta de instalacion esta la carpeta "eula" dentro esta el archivo "AdskLicense" busca tu pais copia los datos y crea un archivo de texto ".txt" en mi caso fue "English.txt" y copialo a la misma carpeta "eula" donde estan los datos de instalacion.
Saludos desde Colombia!!
New Member
0 Kudos
Post 18 of 18
09-09-2014 05:23 AM in reply to: AntoniaDD
thans for all copy the files from eula2 to eula solve the problem
