Installation & Licensing
1 Kudo
Post 1 of 18
Autodesk Quantity takeoff 2012 - "Can't find End User License Agreement"?
7099 Views, 17 Replies
09-05-2011 09:04 AM
I have downloaded Autodesk Quantity Takeoff 2012 from students.autodesk.com (and have also tried to download from usa.autodesk.com), but when i open setup.exe and choses install i get the message:
And the installation program closes down. Why cant i install?
I have tried the following - suggested by Derrick from autodesk support center:
"If this happens when you download and try to install the software from the Education Community this means there is a problem with the installation file, and it will not work on your computer.
To resolve this issue, please do the following:
1.     Delete the file you downloaded.
2.     Next go to Start> Accessories> System Tools> Disc Cleanup and run that utility to clear your temp files, etc.
3.     Reboot your machine.
4.     Turn off your security software - anti-virus programs, firewalls, etc. can block downloads.
5.     Go to your country's main Autodesk website and download the trial version of the software*.
6.     Install the product.
7.     Re-enable your security software.
8.     Get your product key and serial number from the page you downloaded from.
9.      Launch the product you are trying to activate.
10.   A splash screen should come up with two buttons.
11.   Click on the one labeled “Activate” and follow the prompts.
*The trial version is the same as the commercial, free student, and purchased education version; the only difference is that it lacks a serial number. The only difference between the commercial, free, and purchased educational versions is their serial numbers.
What to do?
- Thanks
If you change the country in the license agreement does it work,
May I know which country you are selecting (selected by default)
thanks
Product Support
52 Kudos
Post 2 of 18
Re: Autodesk Quantity takeoff 2012 - "Can't find End User License Agreement
09-06-2011 12:48 AM in reply to: fuglsang1000
copy "all other countries.rtf" file from the folder named EULA2 to EULA in the installation directory.
If you have a DVD you will need to copy the content to local hard disk before you do this.
please post the result.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
0 Kudos
Post 3 of 18
09-06-2011 11:56 AM in reply to: hashim.mundol
I also have same problem, i already followed the step which was posted on top trying to solve, but it's failed
i have no DVD, I download Quantity Takeoff from Autodesk Education Community
Can i find installation directory on the this website?
Thanks for repling
Product Support
52 Kudos
Post 4 of 18
09-06-2011 01:50 PM in reply to: m9905101
If you have downloaded the installation files are in c:\autodesk
Hashim Mundol
0 Kudos
Post 5 of 18
09-06-2011 09:52 PM in reply to: hashim.mundol
i already copied the file "all other countries.rtf" file from the folder named EULA2 to EULA
still got a same result "Can't find End License Agreement"
enclosed error message
thanks for repling
Product Support
52 Kudos
Post 6 of 18
09-06-2011 11:44 PM in reply to: m9905101
thanks
Hashim Mundol
New Member
0 Kudos
Post 7 of 18
09-07-2011 04:09 AM in reply to: fuglsang1000
is it not because it Can't find the united kingdom End User License Agreement?
Product Support
52 Kudos
Post 8 of 18
09-07-2011 04:39 AM in reply to: bh45
it should take "All Other Countries" file.
Hashim Mundol
1 Kudo
Post 9 of 18
09-07-2011 07:34 AM in reply to: hashim.mundol
It worked!
I did what you described, and the program is install without any problems..
Thanks a lot!
New Member
1 Kudo
Post 10 of 18
11-21-2011 09:00 AM in reply to: hashim.mundol
Hi
I have followed your advice. I have copied "all other countries.rtf" file from the folder named EULA2 to EULA in the installation directory.  And it worked.
Thank you so much.
Antonia Del Debbio
