when I first bought my computer these products Installed fine and ran perfect I recently had to reinstall windows and now they wont fully install it says instilation complete but everything failed to install. Can someone please help me with this issue I cant figure it out.
LOG INFO:
2014/6/14:14:09:14 Darnaz DEEGAMECREATOR === Setup started on DEEGAMECREATOR by Darnaz ===
2014/6/14:14:09:14 Darnaz DEEGAMECREATOR Path_Length: 148
2014/6/14:14:09:14 Darnaz DEEGAMECREATOR Current Directory C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_dlm
2014/6/14:14:09:14 Darnaz DEEGAMECREATOR Launch
2014/6/14:14:09:14 Darnaz DEEGAMECREATOR CommandLine
2014/6/14:14:09:14 Darnaz DEEGAMECREATOR Current Directory G:\TEMP\_AI25CA.tmp
2014/6/14:14:09:18 Darnaz DEEGAMECREATOR === Setup ended ===
2014/6/14:14:09:15 Darnaz DEEGAMECREATOR === Setup started on DEEGAMECREATOR by Darnaz ===
2014/6/14:14:09:15 Darnaz DEEGAMECREATOR Path_Length: 148
2014/6/14:14:09:15 Darnaz DEEGAMECREATOR Current Directory G:\TEMP\_AI25CA.tmp
2014/6/14:14:09:15 Darnaz DEEGAMECREATOR Launch
2014/6/14:14:09:18 Darnaz DEEGAMECREATOR PageOpen LaunchDialog
2014/6/14:14:09:24 Darnaz DEEGAMECREATOR PageOpen LicenseDialog
2014/6/14:14:09:31 Darnaz DEEGAMECREATOR PageOpen ProductInfoDialog
2014/6/14:14:10:03 Darnaz DEEGAMECREATOR PageOpen ProductSelectionDialog2
2014/6/14:14:10:07 Darnaz DEEGAMECREATOR PageOpen FullProgressDialog
2014/6/14:14:10:07 Darnaz DEEGAMECREATOR Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): "C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_dlm\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe" /q /norestart
2014/6/14:14:10:20 Darnaz DEEGAMECREATOR Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2014/6/14:14:10:20 Darnaz DEEGAMECREATOR Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_dlm\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/6/14:14:10:30 Darnaz DEEGAMECREATOR Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/6/14:14:10:30 Darnaz DEEGAMECREATOR Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_dlm\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/6/14:14:10:38 Darnaz DEEGAMECREATOR Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/6/14:14:10:38 Darnaz DEEGAMECREATOR Installing .NET Framework Runtime 3.5 SP1: "C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_dlm\3rdParty\NET\35SP1\wcu\dotNetFramework\Install35Net.exe"
2014/6/14:14:11:15 Darnaz DEEGAMECREATOR Install .NET Framework Runtime 3.5 SP1 Failed Installation aborted, Result=1603
2014/6/14:14:11:15 Darnaz DEEGAMECREATOR Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2014/6/14:14:11:15 Darnaz DEEGAMECREATOR Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
2014/6/14:14:11:15 Darnaz DEEGAMECREATOR Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2014/6/14:14:11:16 Darnaz DEEGAMECREATOR PageOpen InstallCompleteDialog
2014/6/14:14:11:43 Darnaz DEEGAMECREATOR === Setup ended ===
2014/6/15:02:07:56 Darnaz DEEGAMECREATOR === Setup started on DEEGAMECREATOR by Darnaz ===
2014/6/15:02:07:56 Darnaz DEEGAMECREATOR Path_Length: 148
2014/6/15:02:07:56 Darnaz DEEGAMECREATOR Current Directory C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_dlm
2014/6/15:02:07:56 Darnaz DEEGAMECREATOR Launch
2014/6/15:02:07:56 Darnaz DEEGAMECREATOR CommandLine
2014/6/15:02:07:56 Darnaz DEEGAMECREATOR Current Directory G:\TEMP\_AI2329.tmp
2014/6/15:02:08:00 Darnaz DEEGAMECREATOR === Setup ended ===
2014/6/15:02:07:57 Darnaz DEEGAMECREATOR === Setup started on DEEGAMECREATOR by Darnaz ===
2014/6/15:02:07:57 Darnaz DEEGAMECREATOR Path_Length: 148
2014/6/15:02:07:57 Darnaz DEEGAMECREATOR Current Directory G:\TEMP\_AI2329.tmp
2014/6/15:02:07:57 Darnaz DEEGAMECREATOR Launch
2014/6/15:02:08:00 Darnaz DEEGAMECREATOR PageOpen LaunchDialog
2014/6/15:02:08:04 Darnaz DEEGAMECREATOR PageOpen LicenseDialog
2014/6/15:02:09:26 Darnaz DEEGAMECREATOR PageOpen ProductSelectionDialog2
2014/6/15:02:09:29 Darnaz DEEGAMECREATOR PageOpen FullProgressDialog
2014/6/15:02:09:30 Darnaz DEEGAMECREATOR Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_dlm\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/6/15:02:09:30 Darnaz DEEGAMECREATOR Install Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=-2147024546
2014/6/15:02:09:30 Darnaz DEEGAMECREATOR Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_dlm\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/6/15:02:09:31 Darnaz DEEGAMECREATOR Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/6/15:02:09:31 Darnaz DEEGAMECREATOR Installing .NET Framework Runtime 3.5 SP1: "C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_dlm\3rdParty\NET\35SP1\wcu\dotNetFramework\Install35Net.exe"
2014/6/15:02:14:37 Darnaz DEEGAMECREATOR Install .NET Framework Runtime 3.5 SP1 Succeeded
2014/6/15:02:14:37 Darnaz DEEGAMECREATOR Installing DirectX® Runtime: "C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent
2014/6/15:02:14:42 Darnaz DEEGAMECREATOR Install DirectX® Runtime Succeeded
2014/6/15:02:14:42 Darnaz DEEGAMECREATOR Installing Autodesk® Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/6/15:02:14:56 Darnaz DEEGAMECREATOR Install Autodesk® Material Library 2015 Succeeded
2014/6/15:02:14:56 Darnaz DEEGAMECREATOR Installing Autodesk® Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/6/15:02:15:04 Darnaz DEEGAMECREATOR Install Autodesk® Material Library 2015 - Base Image Library Succeeded
2014/6/15:02:15:04 Darnaz DEEGAMECREATOR Installing Autodesk® Material Library 2015 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/6/15:02:15:31 Darnaz DEEGAMECREATOR Install Autodesk® Material Library 2015 - Medium Resolution Library Succeeded
2014/6/15:02:15:31 Darnaz DEEGAMECREATOR Installing Autodesk Application Manager: "C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_dlm\x86\ADAPPLICATIONMANAGER\AdApplicationManager-WebInstaller.exe"
2014/6/15:02:23:19 Darnaz DEEGAMECREATOR Install Autodesk Application Manager Failed Failure is ignored, Result=1603
2014/6/15:02:23:21 Darnaz DEEGAMECREATOR Installing Autodesk® 3ds Max 2015: TRANSFORMS="G:\TEMP\_AI2329.tmp\x64\max\3dsMax-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/6/15:02:34:32 Darnaz DEEGAMECREATOR Install Autodesk® 3ds Max 2015 Failed Installation aborted, Result=1603
2014/6/15:02:34:38 Darnaz DEEGAMECREATOR Rollback Autodesk® Material Library 2015 - Medium Resolution Library Succeeded
2014/6/15:02:34:44 Darnaz DEEGAMECREATOR Rollback Autodesk® Material Library 2015 - Base Image Library Succeeded
2014/6/15:02:34:56 Darnaz DEEGAMECREATOR Rollback Autodesk® Material Library 2015 Succeeded
2014/6/15:02:34:56 Darnaz DEEGAMECREATOR Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/6/15:02:34:56 Darnaz DEEGAMECREATOR Rollback .NET Framework Runtime 3.5 SP1 Failed Installation aborted, Result=1619
2014/6/15:02:34:56 Darnaz DEEGAMECREATOR Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
You have to compleatly uninstall all other inventor products before you can install another one.
The above response is inaccurate.
Your failure is not evident in the log file. What OS are you installing on? Also, are you installing from media or download? It appears your temp file is on your G:\ drive. What is this drive?
The more information you can provide, the easier it will be to determine the failure.
