Installation & Licensing
New Member
Andreas.Kramer
Message 41 of 47 (1,253 Views)
Re: Autodesk product failed to send the required value for SERIALNUM
08-17-2012 07:01 AM in reply to: kevinwhite815
@ kevinwhite815
oh yes your are right
We found now a bad font on our System.
When we delete it Inventor works.
But why this error mesasage ?
It doesent fit to that.
Active Member
Stanski
Message 42 of 47 (1,211 Views)
08-23-2012 01:28 AM in reply to: Andreas.Kramer
Well we gave up trying in the end (since no useful advice came from Autodesk) and bought a new PC with Windows 7 and thus far Inventor seems to work fine on it.
Extremely disappointed to not have had a proper solution to this problem.
Active Member
Stanski
Message 43 of 47 (1,112 Views)
10-19-2012 06:14 AM in reply to: Andreas.Kramer
Problem solved. Got a new machine at work with WIndows 7 on.
Such a shame there's no support for older platforms. Still fairly cheesed off there was no definitive solution to the problem on XP based machines.
New Member
yacinebenrahal
Message 44 of 47 (1,080 Views)
10-25-2012 12:34 AM in reply to: jberns
I am also having this problem. I am a student running windows xp (sp3) and have reinstalled inventor pro many times, as you have all said, it crashes at startup and then sends an error report. Any help would be much appreciated.
kevinwhite815
Message 45 of 47 (1,073 Views)
10-25-2012 03:43 AM in reply to: Andreas.Kramer
Everyone should try SolidWorks, it is a better program. SolidWorks is more user friendly, easier to manipulate, and hasn't crashed or given me any problems. SolidWorks is also more affordable than Inventor, and more companies use SolidWorks than inventor because of the price.
New Member
austinpaynter
Message 46 of 47 (863 Views)
02-22-2013 08:13 PM in reply to: jberns
SOLVED!
OK so i was having this problem along with 3DS max saying something about the .NET framework. So I downloaded the latest >NET (4.5). And Still nothing. Then i went into windows features and realized .NET wasn't even turned on (although i worked before so I don't know what changed or when) but it works now!
VoteCoffee
Message 47 of 47 (325 Views)
02-12-2014 10:46 AM in reply to: austinpaynter
For my system, the issue was caused by too many characters in windows environmental variables. I deleted items from other programs that were not important and rebooted and it worked like a charm. You can access these settings via: C:\Windows\System32\SystemPropertiesAdvanced.exe OR control panel->system->advanced system properties then click the environment variables button. Delete entries to get it below size. I figured this out because I went to program features and it could not find %windir%, though this symptom may or may not be exhibited.
