Installation & Licensing
Autodesk product failed to send the required value for SERIALNUM
46 REPLIES 46
Message 1 of 47
JBerns
7563 Views, 46 Replies
Our client has installed Product Design Suite 2012 on an XP SP3 system with an Intel chipset for video.
Status
Sketchbook Designer     Works
AutoCAD Mechanical     Starts, but displays a message "An Autodesk product failed to send the required value for SERIALNUM.  The error report sent to Autodesk may be incomplete." Mechanical appears to work after that message is dismissed.
Inventor                          Crashes at startup, crash report sent
Showcase                      Crashes at startup, crash report sent
3ds Max Design            Works
Mudbox                          Crashes, crash report sent.
Fusion                            Works
The client has uninstalled, cleaned registry/folders, and reinstalled. The problems persist.
They appear to have an Internet connection. Crash reports are being successfully sent and replies received.
Advice to resolve this would be appreciated.
Best regards,
J. Berns
CAD Administrator
Using Inventor 2022
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
46 REPLIES 46
Message 21 of 47
Already tried reinstalling NET 3.5 from the 3rd party folder some time ago and no luck unfortunately.
Message 22 of 47
in reply to: Stanski
Stanski,
I'm with you there. Nothing works, I keep getting told to check the 3.5.net, uninstalll-reinstall. There is a problem with APPRENTICEREGSVR.EXE, on my system.
ApprenticeRegSvr.exe
   16.0.16000.0
   4d6d8818
   KERNELBASE.dll
   6.1.7601.17651
   4e211319
   c06d007e
   0000b9bc
   bc8
   01cce01d970cad79
   C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\x64\Inventor\Program Files\Autodesk\Inventor 2012\Bin\Bin32\ApprenticeRegSvr.exe
   C:\Windows\syswow64\KERNELBASE.dll
   d548466b-4c10-11e1-afa5-0018f35720fe
Message 23 of 47
HelenChen-Autodesk
Hello Kevin,
Could you please attached the error message to have a look?
Whether you get the error message of APPRENTICEREGSVR.EXE from Windows Application Event?
Did you try to copy the APPRENTICEREGSVR.EXE file from the installation package to replace the one which installed in your machine to see whether it works?
Hello Stanski,
Could you please check the Windows Application Event to see whether there is any error log recorded after you failed to launch Inventor? If there is, it does helpful for us to investigate.
Thank you all!
Helen
Message 24 of 47
O.K. I'm back. Here is the copy of the Apprenticeregsvr.exe error log. It's not letting me attach the document so I'll paste it here.
Log Name:      Application
Source:        Application Error
Date:          1/31/2012 8:38:18 AM
Event ID:      1000
Task Category: (100)
Level:         Error
Keywords:      Classic
User:          N/A
Computer:      home1-PC
Description:
Faulting application name: ApprenticeRegSvr.exe, version: 16.0.16000.0, time stamp: 0x4d6d8818
Faulting module name: KERNELBASE.dll, version: 6.1.7601.17651, time stamp: 0x4e211319
Exception code: 0xc06d007e
Fault offset: 0x0000b9bc
Faulting process id: 0xbc8
Faulting application start time: 0x01cce01d970cad79
Faulting application path: C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\x64\Inventor\Program Files\Autodesk\Inventor 2012\Bin\Bin32\ApprenticeRegSvr.exe
Faulting module path: C:\Windows\syswow64\KERNELBASE.dll
Report Id: d548466b-4c10-11e1-afa5-0018f35720fe
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
  <System>
    <Provider Name="Application Error" />
    <EventID Qualifiers="0">1000</EventID>
    <Level>2</Level>
    <Task>100</Task>
    <Keywords>0x80000000000000</Keywords>
    <TimeCreated SystemTime="2012-01-31T13:38:18.000000000Z" />
    <EventRecordID>20158</EventRecordID>
    <Channel>Application</Channel>
    <Computer>home1-PC</Computer>
    <Security />
  </System>
  <EventData>
    <Data>ApprenticeRegSvr.exe</Data>
    <Data>16.0.16000.0</Data>
    <Data>4d6d8818</Data>
    <Data>KERNELBASE.dll</Data>
    <Data>6.1.7601.17651</Data>
    <Data>4e211319</Data>
    <Data>c06d007e</Data>
    <Data>0000b9bc</Data>
    <Data>bc8</Data>
    <Data>01cce01d970cad79</Data>
    <Data>C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\x64\Inventor\Program Files\Autodesk\Inventor 2012\Bin\Bin32\ApprenticeRegSvr.exe</Data>
    <Data>C:\Windows\syswow64\KERNELBASE.dll</Data>
    <Data>d548466b-4c10-11e1-afa5-0018f35720fe</Data>
  </EventData>
</Event>
- <System>
  <Level>2</Level>
  <Task>100</Task>
  <Security />
  </System>
- <EventData>
  <Data>bc8</Data>
  </EventData>
  </Event>
Message 25 of 47
Hi, Helen, have you figured out what's going on yet?
Message 26 of 47
Message 27 of 47
HelenChen-Autodesk
Hello Kevin,
Our developer checked the log file from you, looks like there might be something cause ApprenticeRegSvr.exe file is incompatible with your OS.
Is it possible that you can allow our developer to remote your machine to have a check? Like use NetMeeting or something else if it's possible for you.
Helen
Message 28 of 47
I'm operating on an AMDx64 2.4gig dual core processor, 4gb ram, Geforce 6150le integrated graphics, windows 7 home premium. It's not the system. The program actually opened last night for the first time, and is running fine. I didn't do anything other than click on the Inventor icon. This leads me to believe that there are issues with the program itself. However if when I close this inventor12 program and it does not open again, I will need the info to get in touch with your technician, to track down application bugs.
One problem that I see is that Autodesk upgrades their programs too much, I was taught a long time ago, if it's not broke, don't fix it.
Thanks Helen.
Message 29 of 47
HelenChen-Autodesk
Hello Kevin,
Could you please send an email to me? I will forward to our technical co-worker to contact you.
My email address is:
HelenDOTChenATAutodeskDOTCom
Helen
Message 30 of 47
Hi, Helen, Inventor ran well for awhile, opening and closing fine. Now It's back to the SERIAL NUM error. I'm sending you an email. Keep an eye on your inbox.
Thanks!
Message 31 of 47
Stanski
So is there a proper solution yet for us measly XP users that doesn't involve a complete system re-install?
Message 32 of 47
Just spent 2 hrs on a remote access program debug to no avail. The program opened once, but back to the SOS! I give up, think I'll just uninstall it for the last time and leave it at that.
Message 33 of 47
So another month and any more news?
Frankly it's disgusting that a £5k+ program suite just doesn't work and there is little or no backup or assistance to get it working. I've used 2D AutoCAD on and off for years and there have always been minor niggles which have always been solved, but this particular issue is without solution.
I have to keep using other peoples' machines to get onto Inventor which is extremely disrupting and invoncenient and totally defeats the object of my company spending so much money on the software suite in the first place.
Message 34 of 47
Hello Stanski,
We are really very sorry for any inconvenience.
Our developer team is continuing investigating this issue, however so far we haven’t found better solutions yet…
We will keep you posted if there is any update later.
Thank you very much for your cooperation and patient.
Helen
Message 35 of 47
Hi
[SOLVED]
Hi, I just did a reinstall of Inventor and it now works.
[/SOLVED]
I'm using Inventor 2012 at my work and it have worked all the time until I updated Design Review to ver 2013.
Now Inventor doesn't start anymore.
Other Autodesk softwares works, Autodesk Collaboration, Autocad 2012, Inventor Fusion, but not Inventor 2012...  the program I use most and is vital for my work.....
I have tried updating .Net, enabling/disabling it. Restarting windows like mad.. Uninstalling Design Review...
But nothing yet.
Going to reinstall Inventor to see if it works.
Have you found any solutions yet??
/Philip
Message 36 of 47
Hi Philip,
Please let us know the result after reinstallation. Hopefully it works for you.
If it is still a problem, we may give further research.
-Aaron
Aaron Long
Software QA Manager
Inventor Quality Assurance Team
Autodesk, Inc.
Message 37 of 47
Batman2000
Hi
Everything is working fine after the reinstall of Inventor. Working as normal. Still crashes almost everyday 🙂 but that is a different matter. I do think the problem solved itself when it reinstalled Design Review 2012 automatically.
/Philip
Message 38 of 47
Hi Philip,
thanks for your quick response.Smiley Happy
regards
-Aaron
Aaron Long
Software QA Manager
Autodesk, Inc.
Message 39 of 47
Andreas.Kramer
Smiley Mad
now it hits use
suddenly yesterday the inventor never starts, and we became this errormessage.
But on all our PCs and only on inventor 2012
Inventor 2013 starts fine and all other programms of the suit works.
We change nothing on out PCs or our Server.
I try .NET start and stop, new installation but sillt the same error.
HELP
Smiley Frustrated
Message 40 of 47
Hello, there is a problem with Fonts in Inventor 2012. There is no solution to this problem, it is a program error. You will have to download a newer version of inventor.
Administrator Productivity
