Installation & Licensing
Autodesk Product Design Suite Ultimate 2012 Error:1720
4 REPLIES 4
KrisLizak
1147 Views, 4 Replies
Hello
I recieved a error message and installation will not finish. Please see the attached image.
4 REPLIES 4
TravisNave
in reply to: KrisLizak
You might have an issue with your installed VB Script.  Try creating a new user profile with local admin rights and installing as the new user.  If that doesn't work, make sure you have the latest version of the Windows Installer.
Error 1720 doesn't happen very often and it indicates a problem with your Windows and not the Autodesk software.
Autodesk Forums:
KrisLizak
That's what I tohught. I will give it a try and let you know.
i had the same problem.. could you send me a link to get windows installer?? thanks:smileyhappy 🙂
philip.s
Hi Aaron,
What version of Windows are you running? For XP or VIsta, you can download directly from Microsoft. If you are running Windows 7, please see the following articles (article1, article2, article3).
Administrator Productivity
