I read on following page, “Autodesk® AutoCAD® Design Suite Standard 2014” version is ready for citrix XenApp.
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=13959101
Are “Autodesk Product Design Suite for Education 2014” or “Autodesk Education Master Suite 2014” ready for Citrix XenApp?
Sincerely Yours.
Kemal Sulhi GÜNDOĞDU
Uludag University Agricultural Faculty
Biosystems Engineering Department
Bursa/Turkey
email: kemalsulhi@gmail.com
The Product Design Suite is the Education Master Suite not supported on Citrix. The reason is that not ALL products in the suite have been tested in a Citrix environment.
For example, AutoCAD 2014 is supported in Citrix and is one of the products in the PDS and EMS. You could run AutoCAD 2014 in a Citrix environment. Please note that you need a special Citrix license and you can't combine a Citirx autodesk license with a 'normal' autodesk license on the license server (i.e. configuring LMTOOLS.exe).
According to our supplier, Autodesk will NOT transfer an educational license to a Citrix license. So although there are no technical reason why we cannot run on Citrix, Autodesk will not allow it because they will only transfer commercial licenses to the 'special' session specific license.
What they give with one hand they take away with the other.
here is the list of supported products on Citrix
DarrenP
