Well, it's that time again. Time to update your Autodesk Network License Manager files to the latest and greatest (Autodesk) version.
Autodesk is providing version 11.13.1.2 for 2017 products.
NOTE: It is required to update to 11.13.1.2 for the product license to work, otherwise you will get a 0.0.0 error.
Just like last year and moving forward, the License Manager files are no longer available for direct download from Flexera. Per their new policy, you must obtain the license manager from your software vendor. You can download the Autodesk Network License Manager files here for both 32-bit and 64-bit versions:
If there are updates to the Autodesk Network License Manager files as the 2017 product line is rolled-out, I will reflect those changes in this thread.
You can update your license file to 2017 versions from your Autodesk Accounts page once your Subscription has been updated.
You can use the online method to activate your license here:
https://register.autodesk.com and from the new Autodesk Accounts page at https://accounts.autodesk.com
Or you can can contact your Value-Added Reseller for assistance. You can locate your VAR here:
http://www.autodesk.com/resellers/locate-a-reseller
To update your license file, you will need to provide your serial number and ethernet ID of the new license server.
For a Quick-Start Guide on configuring the Autodesk License Manager, please see my post for further information:
http://forums.autodesk.com/t5/Installation-Licensing/Quick-Start-Guide-for-Configuring-LMTOOLS/m-p...
Good Luck!
Solved by TravisNave. Go to Solution.
Hopefully the Auto-response helped you out...
Mark Lancaster
& Autodesk Services MarketPlace Provider
If you want to simply update the .exe files for your license manager, you can do this quickly and efficiently. In fact, you can do this during working hours without affecting your users at all. Yes, I know it sounds scary, but I promise I do it all the time.
@TravisNave It would be nice if the forum admin would lock this at the top (of the forum) because in a few hours this information which is essential will be off onto the next page and lost...
Mark Lancaster
my customer has ACAD 2017 + BDSS 2016 in his license file. I advised him to install LMS 11.13.1.2 which he did.
Unfortunatelly, he is still getting error 0.0.0. Antivirus and FW are shut down.Server WS2008R2standard SP1 64bit.
We havent tested yet to use only 2017 Increment to avoid mixing both 2016+2017 but it is a little bit complicated - the enduser is not very happy...
Any advices please?
Thank you
George
holy cow, switch out the exe, that is so genius!
That worked perfectly, and makes testing fast enough I can do during the day.
Wish I had known this years ago. 1 Kudo is not enough.
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
Hi
I am getting the following message when trying the install, can anyone please advise.
Regards
Martyn
Updating DACL Failed
Service has been created but failed to update the DACL settings of FlexNet Licensing Service. It will give problem for accessing TS features. Check whether FlexNet Licensing Service is correctly installed or not and delete and create this service again
If you save the service again does the message go away?
Have you looked at these 2 postings:
Mark Lancaster
No impact but all license servers need to be at the same LMTOOL (license manager) version.
Mark Lancaster
