Installation & Licensing
Autodesk Network License Manager 2014
69 REPLIES 69
Message 1 of 70
TravisNave
16082 Views, 69 Replies
Well, it's that time again.  Time to update your Autodesk Network License Manager files to the latest and greatest (Autodesk) version.
Autodesk is providing version 11.11 for 2014 products.
You can get the Autodesk Network License Manager files here for both 32-bit and 64-bit versions:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18610121&linkID=12305695
You can always get the latest version of the NLM from the following link:
http://www.globes.com/support/fnp_utilities_download.htm
At the time of this post, the latest version is 11.11.1, which is newer than the version supplied by Autodesk.  I am attaching the necessary 32-bit adskflex vendor daemon file in this message (v11.11) for your convenience.  You can use this file if you are using the Flexera License Administrator instead of LMTOOLS.  You can find the FLEXnet License Admin also in the link above.  I will post the 64-bit adskflex.exe vendor daemon file in a follow-up post below.
You can update your license file to 2014 versions once your Subscription has been fulfilled.
You can use the online method to activate your license here:
http://usa.autodesk.com/adsk/servlet/pc/item?id=18424632&siteID=123112
Or you can can call Autodesk Product Registration and Authorization:
http://en.autodesk.ca/adsk/servlet/index?siteID=9719649&id=9830778
1-800-551-1490 > Option 1 (English) > Option 2 > (Network)
Asia / Pacific: 65.6735.5688
Europe / Middle East / Asia: 41.32.723.9595
You will need to provide your serial number and ethernet ID of the new license server.
For a Quick-Start Guide on configuring the Autodesk License Manager, please see my post for further information:
http://forums.autodesk.com/t5/Installation-Licensing/Quick-Start-Guide-for-Configuring-LMTOOLS/m-p/3...
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Tags (1)
69 REPLIES 69
Message 21 of 70
DarrenP
in reply to: jlobo2
read this: http://forums.autodesk.com/t5/Installation-Licensing/Combining-License-Files-for-Subscription-and-No...
DarrenP
Message 22 of 70
jlobo2
in reply to: DarrenP
Awesome,
Thank You Darren.
Message 23 of 70
TravisNave
in reply to: jlobo2
Also see my combining License files link in my signature.
Autodesk Forums:
Message 24 of 70
jlobo2
in reply to: TravisNave
Thank You Travis.
Message 25 of 70
jlobo2
Just wanted to confirm the 4 .exe files you mentioned are
1. adskflex
2. lmgrd
3. lmtools
4. lmutil
Are these the only files to be replaced?
Message 26 of 70
DarrenP
in reply to: jlobo2
yes
DarrenP
Message 27 of 70
TravisNave
in reply to: jlobo2
That is correct. I provide the adskflex file in this thread The rest can be
downloaded from Flexera in my link there.
Autodesk Forums:
Message 28 of 70
jlobo2
What are the System Requirements for the Server for Shared License for AutoCAD 2014 and AutoCAD 2012?
I replaced the 4 exe files yesterday and followed the procedure in the link, but it did not work. Then I tried to install the License Manager for AutoCAD 2014, then it gave me a message saying, that it does not meet the System Requirements.
Would appreciate any help with the same.
Message 29 of 70
DarrenP
in reply to: jlobo2
requirements are here: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21880916&linkID=9243099&CMP=OTC-RSS...
DarrenP
Message 30 of 70
DarrenP
unless your running something older than xp or server 2003 you should be fine
DarrenP
Message 31 of 70
jlobo2
Currently its running on Windows Vista SP2.
Message 32 of 70
DarrenP
in reply to: jlobo2
the one OS it doesn't work with
DarrenP
Message 33 of 70
jlobo2
Hmmm. Yeah. Thanks for your help Darren and Travis. I will get back when the Supported OS are installed, or is there any other possible alternative?
Message 34 of 70
DarrenP
in reply to: jlobo2
you can use 11.10 which came with 2013 which does support vista
DarrenP
Message 35 of 70
jlobo2
But, will it support AutoCAD 2014 Licenses, because we are keen to go for 2014?
Message 36 of 70
DarrenP
in reply to: jlobo2
if it doesn't
do you have another machine that has xp, or 7 or 8 on it so you can install the lastest license manager on it
this will require a new license file
DarrenP
Message 37 of 70
DarrenP
i just tried mine with 11.10 and 2014 products it seems to work
DarrenP
Message 38 of 70
jlobo2
Ok,
I just spoke to my Opertaions team and we have Windows 2008 Server with SP2. The server had a buggy app which showed that the OS is Windows Vista.
So now here are the details that we have;
1. Current System : Windows 2008 Server with SP2
2. Did copy the 4 exe files that were discussed in this thread before.
3. Followed the steps from the link you had shared earlier
But it still did not work.
I read somewhere about the dates should be the same for the .lic file. Can you help me get some more details about the same. Thanks
Message 39 of 70
jlobo2
Darren thanks for your help, I have posted a new question. I would really appreciate the help with the same. Thanks a ton for all the help from you.
Message 40 of 70
DarrenP
in reply to: jlobo2
at point didn't work?
DarrenP
Administrator Productivity
