Installation & Licensing
TravisNave
Message 1 of 70 (11,031 Views)
Autodesk Network License Manager 2014
11031 Views, 69 Replies
04-01-2013 10:00 AM
Well, it's that time again.  Time to update your Autodesk Network License Manager files to the latest and greatest (Autodesk) version.
Autodesk is providing version 11.11 for 2014 products.
You can get the Autodesk Network License Manager files here for both 32-bit and 64-bit versions:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18610121&linkID=12305695
You can always get the latest version of the NLM from the following link:
http://www.globes.com/support/fnp_utilities_download.htm
At the time of this post, the latest version is 11.11.1, which is newer than the version supplied by Autodesk.  I am attaching the necessary 32-bit adskflex vendor daemon file in this message (v11.11) for your convenience.  You can use this file if you are using the Flexera License Administrator instead of LMTOOLS.  You can find the FLEXnet License Admin also in the link above.  I will post the 64-bit adskflex.exe vendor daemon file in a follow-up post below.
You can update your license file to 2014 versions once your Subscription has been fulfilled.
You can use the online method to activate your license here:
http://usa.autodesk.com/adsk/servlet/pc/item?id=18424632&siteID=123112
Or you can can call Autodesk Product Registration and Authorization:
http://en.autodesk.ca/adsk/servlet/index?siteID=9719649&id=9830778
1-800-551-1490 > Option 1 (English) > Option 2 > (Network)
Asia / Pacific: 65.6735.5688
Europe / Middle East / Asia: 41.32.723.9595
You will need to provide your serial number and ethernet ID of the new license server.
For a Quick-Start Guide on configuring the Autodesk License Manager, please see my post for further information:
http://forums.autodesk.com/t5/Installation-Licensing/Quick-Start-Guide-for-Configuring-LMTOOLS/m-p/3...
Good Luck!
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
As in previous iterations of the NLM upgrades, this version also seems to suffer from the same -15 errors, IPv6 issues, and the subsequent exiting of the adskflex.exe vendor daemon on Windows 8 and Server 20xx R2 installations.
I was able to get it working with no problems on Windows 7, Server 2003, and Windows XP.  However, if you are installing on newer machine configurations, you will want to see my posts about fixing -15 errors here:
http://forums.autodesk.com/t5/Installation-Licensing/Network-License-Error-1-5-15-and-IPv6/m-p/2982864
Subsequently, you may find success in running the 11.7 version of the adskflex.exe vendor daemon, as I have done on my Windows 8 machine.  If you would like to use this file with the latest NLM, you can.  I have attached the older 11.7 version zipped here.
TravisNave
Message 2 of 70 (11,026 Views)
Re: Autodesk Network License Manager 2014
04-01-2013 10:06 AM in reply to: TravisNave
For those of you who need the 64-bit version of the adskflex.exe vendor daemon for your LMTOOLS update or FLEXnet License Administrator, you can find it attached to this post.
DarrenP
Message 3 of 70 (11,023 Views)
04-01-2013 10:08 AM in reply to: TravisNave
i was hoping they would switch to the flex net publisher
TravisNave
Message 4 of 70 (11,010 Views)
04-01-2013 10:19 AM in reply to: TravisNave
http://forums.autodesk.com/t5/Installation-Licensing/Network-License-Error-1-5-15-and-IPv6/m-p/29828...
TravisNave
Message 5 of 70 (11,013 Views)
04-01-2013 10:21 AM in reply to: DarrenP
I agree, Darren.  I keep hearing rumors about cloud licensing though.  Hard telling...
DarrenP
Message 6 of 70 (11,009 Views)
04-01-2013 10:22 AM in reply to: TravisNave
i have heard of that too
supposedly they are testing this with certain accounts
rseiple
Message 7 of 70 (10,851 Views)
04-10-2013 01:38 PM in reply to: TravisNave
Isn't this the same one that came with 2013 software? If so, then we should be able to use the existing LMTools already installed from last year. Correct? Just checking. Thanks.
DarrenP
Message 8 of 70 (10,849 Views)
04-10-2013 01:39 PM in reply to: rseiple
no a new license manager version comes out every year
2013 is 11.10
2014 is 11.11
rseiple
Message 9 of 70 (10,845 Views)
04-10-2013 01:47 PM in reply to: DarrenP
that's strange because mine shows the following:
TravisNave
Message 10 of 70 (10,832 Views)
04-10-2013 03:26 PM in reply to: rseiple
Then your license manager is already upgraded.  However, the vendor daemon from Autodesk changes every year as well.
