Installation & Licensing
New Member
davidvandermeer1011
Message 11 of 17 (1,430 Views)
Re: Autodesk Mudbox wont open
12-07-2011 05:40 PM in reply to: driftwood
Same problem here. I start Mudbox 2012, and it loads up one CPU core, and starts eating up massive amounts of RAM. It killed my system the first time to a point all I could do was switch it off, second time I tried I killed the mudbox.exe process just before it hit 8Gb ram.
I have a Dell M4600 with i7, 8GB ram, Quadro 1000M.
Since I don't need the program for anything usefull I'm not going to try and fix it, but thought I'd mention it here.
New Member
LaCamilla
Message 12 of 17 (1,369 Views)
01-18-2012 03:11 PM in reply to: cleopar1
I'm glad I found a thread about this problem, or I would have reinstalled Mudbox and failed again, all in vain. Now I know I won't even have to try, just be happy with 3ds Max. :smileywink:
I tried to start the program, all 16gb of memory went to work the heck out of themselves, and the first time everything froze and the second it just ate 99% memory without anything else happening, so I switched off the computer, restarted, tried again, but alas, in vain. Sort of glad it seems to be a big problem. So to be able to use Mudbox, I conclude that you need a computer like the ones they have at Pixar animation studios...?
The other programs in the Entertainment Creation Suite work well, though, so they don't seem to affect each other. Good thing. :smileyhappy:
EDIT: I have Windows 7 Home Premium. Seems I need Professional to use Mudbox... didn't know until now. Maybe someone else also made that mistake?
New Member
Shadow5XL
Message 13 of 17 (1,335 Views)
02-05-2012 03:30 AM in reply to: cleopar1
You have to install Mudbox 2011 if you have intel or any graphics hardware that is not ATI or NVIDIA. It will stillhave the error message but the trick is to keep clicking on the version 2011 to force it to open then you will see the activation page. What I did was clicked "try" then let the program open and just clicked on a couple of things to see if the program was working properly then I closed it then opened it again saw the error message but the program still opened. I then activated the product key and it works fine but there is still an error message but just click on the x and this on a laptop that is running an Intel. Sometimes you just have to show these machines who is the boss.
New Member
genlin20
Message 14 of 17 (1,130 Views)
05-07-2012 07:49 AM in reply to: davidvandermeer1011
 I had the same issue then I updated my graphic card driver and It is working now.:smileyhappy:
New Member
hitesh.ramawat01
Message 15 of 17 (945 Views)
08-08-2012 03:41 AM in reply to: cleopar1
i am also having the same problem did find the solution..???
New Member
hitesh.ramawat01
Message 16 of 17 (945 Views)
08-08-2012 03:42 AM in reply to: cleopar1
i need help am having the same problem...plz help me.
junkaphobia
Message 17 of 17 (482 Views)
06-26-2013 08:08 AM in reply to: davidvandermeer1011
Me too. Brand new install Any help on this?
Asrock z77 extreme9 | Intel i7 3770K 3.5 | Win 7 64 bit | (4) EVGA GTX 690 | Apple Cinema Display | LEPA G1600W PSU | 16GB Ram | Storm Trooper Case | Tripp-Lite 1600W UPS | Autodesk Inventor | 3DS Max | Cinema 4D R14 Broadcast
