I have been trying to download the student version of maya for ages and I cannot find a way to do it. I have tried every way (install now,download now,browser download). The first two always gives me a communication error when I try open the file downloaded. I have tried everything it says on the communication error pop up screen to fix it but have had no luck. The browser download always says the file is corrupt when I try to extract it. I'm really stuck so if I could get some help ASAP, that would be much appreciated.
Hi Nalonoli and welcome to the Community!
I've manually created the below download links, could you give them a shot and let me know if you get a different result?
2015 Autodesk Maya for Windows 64 Part 1
2015 Autodesk Maya for Windows 64 Part 2
It's working now but i don't know which serial number to use because every time I tried to download it, it gave me a new serial number. Which one should I use? Also, which license type should I use ? Stand alone or Network?
All Education Community licenses are standalone and assuming you were logged into the same account the serial number should be the same for all licenses obtained in the site.
Happy to help!
hey i been tryin foever to get maya its sayin proxy authentication errir ,,,, then i tried doing the part 1 n part still getting files missing or not downloaded yet ...wat do i do?
Hello @Anonymous!
Did you make sure that both files (part 1 & 2) were fully downloaded before trying to run the install on part 1?
I had problems downloading it but i got round it, and now i had to try and instuall it many times because it came up as failed. I got it to install with the student serial number i got in the email but when i open maya it says missing 'adlmint.dll' what do i need to do to get that?
