Installation & Licensing
AutoDesk Maya 2014 fails to install
1 REPLY 1
1844 Views, 1 Reply
I've been trying so many times installing Maya 2014 and even 2013 which all fail to install giving me the error 1603 and 1619. I've tried many fixes like downloading directx and reinstalling java and read many post but I just can't figure out what is going on.
2014/1/7:11:28:18 Sebastian SEBASTIAN-PC === Setup started on SEBASTIAN-PC by Sebastian ===
2014/1/7:11:28:18 Sebastian SEBASTIAN-PC Path_Length: 151
2014/1/7:11:28:18 Sebastian SEBASTIAN-PC Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2014/1/7:11:28:18 Sebastian SEBASTIAN-PC Launch
2014/1/7:11:28:18 Sebastian SEBASTIAN-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/Autodesk_Maya_2014_wi_en-US_Setup.exe" /SN 900-44225391 /PK 657F1 /student /akamai /auth authparam /sid SESSION_ID
2014/1/7:11:28:18 Sebastian SEBASTIAN-PC Current Directory C:\Users\SEBAST~1\AppData\Local\Temp\_AI64DA.tmp
2014/1/7:11:29:15 Sebastian SEBASTIAN-PC === Setup ended ===
2014/1/7:11:28:19 Sebastian SEBASTIAN-PC === Setup started on SEBASTIAN-PC by Sebastian ===
2014/1/7:11:28:19 Sebastian SEBASTIAN-PC Path_Length: 151
2014/1/7:11:28:19 Sebastian SEBASTIAN-PC Current Directory C:\Users\SEBAST~1\AppData\Local\Temp\_AI64DA.tmp
2014/1/7:11:28:19 Sebastian SEBASTIAN-PC Launch
2014/1/7:11:28:58 Sebastian SEBASTIAN-PC Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/SETUP_x...
2014/1/7:11:29:14 Sebastian SEBASTIAN-PC Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/SETUP_x...
2014/1/7:11:29:15 Sebastian SEBASTIAN-PC PageOpen LaunchDialog
2014/1/7:11:29:28 Sebastian SEBASTIAN-PC PageOpen LicenseDialog
2014/1/7:11:29:33 Sebastian SEBASTIAN-PC PageOpen ProductInfoDialog
2014/1/7:11:29:33 Sebastian SEBASTIAN-PC PageOpen ProductSelectionDialog2
2014/1/7:11:29:53 Sebastian SEBASTIAN-PC PageOpen FullProgressDialog
2014/1/7:11:29:53 Sebastian SEBASTIAN-PC Download Play VCREDIST2008SP1X86 http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/VCREDIS...
2014/1/7:11:29:58 Sebastian SEBASTIAN-PC Download Complete VCREDIST2008SP1X86 http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/VCREDIS...
2014/1/7:11:29:58 Sebastian SEBASTIAN-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2014/1/7:11:30:24 Sebastian SEBASTIAN-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2014/1/7:11:30:25 Sebastian SEBASTIAN-PC Download Play VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/VCREDIS...
2014/1/7:11:30:28 Sebastian SEBASTIAN-PC Download Complete VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/VCREDIS...
2014/1/7:11:30:28 Sebastian SEBASTIAN-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\SEBAST~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/1/7:11:30:58 Sebastian SEBASTIAN-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Succeeded
2014/1/7:11:31:00 Sebastian SEBASTIAN-PC Download Play DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/DIRECTX...
2014/1/7:11:32:14 Sebastian SEBASTIAN-PC Download Complete DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/DIRECTX...
2014/1/7:11:32:14 Sebastian SEBASTIAN-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/1/7:11:34:19 Sebastian SEBASTIAN-PC Install DirectX® Runtime Succeeded
2014/1/7:11:34:21 Sebastian SEBASTIAN-PC Download Play Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/Maya_en...
2014/1/7:11:44:01 Sebastian SEBASTIAN-PC Download Aborted Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/Maya_en...
2014/1/7:11:44:01 Sebastian SEBASTIAN-PC Install Autodesk® Maya® 2014 Failed Download Failed, Installation aborted, Result=1603
2014/1/7:11:44:02 Sebastian SEBASTIAN-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/1/7:11:44:03 Sebastian SEBASTIAN-PC PageOpen InstallCompleteDialog
2014/1/7:11:44:17 Sebastian SEBASTIAN-PC === Setup ended ===
2014/1/7:11:46:00 Sebastian SEBASTIAN-PC === Setup started on SEBASTIAN-PC by Sebastian ===
2014/1/7:11:46:00 Sebastian SEBASTIAN-PC Path_Length: 151
2014/1/7:11:46:00 Sebastian SEBASTIAN-PC Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2014/1/7:11:46:00 Sebastian SEBASTIAN-PC Launch
2014/1/7:11:46:00 Sebastian SEBASTIAN-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/Autodesk_Maya_2014_wi_en-US_Setup.exe" /SN 900-44225391 /PK 657F1 /student /akamai /auth authparam /sid SESSION_ID
2014/1/7:11:46:00 Sebastian SEBASTIAN-PC Current Directory C:\Users\SEBAST~1\AppData\Local\Temp\_AI9B65.tmp
2014/1/7:11:46:04 Sebastian SEBASTIAN-PC === Setup ended ===
2014/1/7:11:46:02 Sebastian SEBASTIAN-PC === Setup started on SEBASTIAN-PC by Sebastian ===
2014/1/7:11:46:02 Sebastian SEBASTIAN-PC Path_Length: 151
2014/1/7:11:46:02 Sebastian SEBASTIAN-PC Current Directory C:\Users\SEBAST~1\AppData\Local\Temp\_AI9B65.tmp
2014/1/7:11:46:02 Sebastian SEBASTIAN-PC Launch
2014/1/7:11:46:03 Sebastian SEBASTIAN-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/SETUP_x...
2014/1/7:11:46:04 Sebastian SEBASTIAN-PC PageOpen LaunchDialog
2014/1/7:11:46:10 Sebastian SEBASTIAN-PC PageOpen LicenseDialog
2014/1/7:11:46:13 Sebastian SEBASTIAN-PC PageOpen ProductInfoDialog
2014/1/7:11:46:13 Sebastian SEBASTIAN-PC PageOpen ProductSelectionDialog2
2014/1/7:11:46:45 Sebastian SEBASTIAN-PC PageOpen FullProgressDialog
2014/1/7:11:46:46 Sebastian SEBASTIAN-PC Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/DIRECTX...
2014/1/7:11:46:46 Sebastian SEBASTIAN-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/1/7:11:48:07 Sebastian SEBASTIAN-PC Install DirectX® Runtime Succeeded
2014/1/7:11:48:11 Sebastian SEBASTIAN-PC Download Play Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/Maya_en...
2014/1/7:11:57:45 Sebastian SEBASTIAN-PC Download Aborted Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/Maya_en...
2014/1/7:11:57:45 Sebastian SEBASTIAN-PC Install Autodesk® Maya® 2014 Failed Download Failed, Installation aborted, Result=1603
2014/1/7:11:57:46 Sebastian SEBASTIAN-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/1/7:11:57:46 Sebastian SEBASTIAN-PC PageOpen InstallCompleteDialog
2014/1/7:11:58:17 Sebastian SEBASTIAN-PC === Setup ended ===
2014/1/7:12:32:02 Sebastian SEBASTIAN-PC === Setup started on SEBASTIAN-PC by Sebastian ===
2014/1/7:12:32:02 Sebastian SEBASTIAN-PC Path_Length: 151
2014/1/7:12:32:02 Sebastian SEBASTIAN-PC Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2014/1/7:12:32:02 Sebastian SEBASTIAN-PC Launch
2014/1/7:12:32:02 Sebastian SEBASTIAN-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/Autodesk_Maya_2014_wi_en-US_Setup.exe" /SN 900-44225391 /PK 657F1 /student /akamai /auth authparam /sid SESSION_ID
2014/1/7:12:32:02 Sebastian SEBASTIAN-PC Current Directory C:\Users\SEBAST~1\AppData\Local\Temp\_AIC082.tmp
2014/1/7:12:32:22 Sebastian SEBASTIAN-PC === Setup ended ===
2014/1/7:12:32:04 Sebastian SEBASTIAN-PC === Setup started on SEBASTIAN-PC by Sebastian ===
2014/1/7:12:32:04 Sebastian SEBASTIAN-PC Path_Length: 151
2014/1/7:12:32:04 Sebastian SEBASTIAN-PC Current Directory C:\Users\SEBAST~1\AppData\Local\Temp\_AIC082.tmp
2014/1/7:12:32:04 Sebastian SEBASTIAN-PC Launch
2014/1/7:12:32:16 Sebastian SEBASTIAN-PC Download Error Network error SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/Autodesk_Maya_2014_wi_en-US_Setup.exe
2014/1/7:12:32:16 Sebastian SEBASTIAN-PC Error downloading. Please Install Now again from the Autodesk website. 2014/1/7:12:32:23 Sebastian SEBASTIAN-PC === Setup ended ===
2014/1/7:12:33:13 Sebastian SEBASTIAN-PC === Setup started on SEBASTIAN-PC by Sebastian ===
2014/1/7:12:33:13 Sebastian SEBASTIAN-PC Path_Length: 151
2014/1/7:12:33:13 Sebastian SEBASTIAN-PC Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2014/1/7:12:33:13 Sebastian SEBASTIAN-PC Launch
2014/1/7:12:33:13 Sebastian SEBASTIAN-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/Autodesk_Maya_2014_wi_en-US_Setup.exe" /SN 900-44225391 /PK 657F1 /student /akamai /auth authparam /sid SESSION_ID
2014/1/7:12:33:13 Sebastian SEBASTIAN-PC Current Directory C:\Users\SEBAST~1\AppData\Local\Temp\_AID1D0.tmp
2014/1/7:12:33:16 Sebastian SEBASTIAN-PC === Setup ended ===
2014/1/7:12:33:15 Sebastian SEBASTIAN-PC === Setup started on SEBASTIAN-PC by Sebastian ===
2014/1/7:12:33:15 Sebastian SEBASTIAN-PC Path_Length: 151
2014/1/7:12:33:15 Sebastian SEBASTIAN-PC Current Directory C:\Users\SEBAST~1\AppData\Local\Temp\_AID1D0.tmp
2014/1/7:12:33:15 Sebastian SEBASTIAN-PC Launch
2014/1/7:12:33:15 Sebastian SEBASTIAN-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/SETUP_x...
2014/1/7:12:33:15 Sebastian SEBASTIAN-PC PageOpen LaunchDialog
2014/1/7:12:33:29 Sebastian SEBASTIAN-PC PageOpen LicenseDialog
2014/1/7:12:34:25 Sebastian SEBASTIAN-PC PageOpen ProductInfoDialog
2014/1/7:12:34:25 Sebastian SEBASTIAN-PC PageOpen ProductSelectionDialog2
2014/1/7:12:34:28 Sebastian SEBASTIAN-PC PageOpen FullProgressDialog
2014/1/7:12:34:28 Sebastian SEBASTIAN-PC Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/DIRECTX...
2014/1/7:12:34:28 Sebastian SEBASTIAN-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/1/7:12:35:40 Sebastian SEBASTIAN-PC Install DirectX® Runtime Succeeded
2014/1/7:12:35:41 Sebastian SEBASTIAN-PC Download Play Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/Maya_en...
2014/1/7:12:45:39 Sebastian SEBASTIAN-PC Download Aborted Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/Maya_en...
2014/1/7:12:45:39 Sebastian SEBASTIAN-PC Install Autodesk® Maya® 2014 Failed Download Failed, Installation aborted, Result=1603
2014/1/7:12:45:40 Sebastian SEBASTIAN-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/1/7:12:45:40 Sebastian SEBASTIAN-PC PageOpen InstallCompleteDialog
2014/1/7:12:53:05 Sebastian SEBASTIAN-PC === Setup ended ===
2014/1/29:20:44:07 Sebastian SEBASTIAN-PC === Setup started on SEBASTIAN-PC by Sebastian ===
2014/1/29:20:44:07 Sebastian SEBASTIAN-PC Path_Length: 151
2014/1/29:20:44:07 Sebastian SEBASTIAN-PC Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2014/1/29:20:44:07 Sebastian SEBASTIAN-PC Launch
2014/1/29:20:44:07 Sebastian SEBASTIAN-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/Autodesk_Maya_2014_wi_en-US_Setup.exe" /SN 900-36874060 /PK 657F1 /student /akamai /auth authparam /sid SESSION_ID
2014/1/29:20:44:07 Sebastian SEBASTIAN-PC Current Directory C:\Users\SEBAST~1\AppData\Local\Temp\_AI699C.tmp
2014/1/29:20:44:13 Sebastian SEBASTIAN-PC === Setup ended ===
2014/1/29:20:44:09 Sebastian SEBASTIAN-PC === Setup started on SEBASTIAN-PC by Sebastian ===
2014/1/29:20:44:09 Sebastian SEBASTIAN-PC Path_Length: 151
2014/1/29:20:44:09 Sebastian SEBASTIAN-PC Current Directory C:\Users\SEBAST~1\AppData\Local\Temp\_AI699C.tmp
2014/1/29:20:44:09 Sebastian SEBASTIAN-PC Launch
2014/1/29:20:44:12 Sebastian SEBASTIAN-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/SETUP_x...
2014/1/29:20:44:12 Sebastian SEBASTIAN-PC PageOpen LaunchDialog
2014/1/29:20:44:28 Sebastian SEBASTIAN-PC PageOpen LicenseDialog
2014/1/29:20:44:33 Sebastian SEBASTIAN-PC PageOpen ProductInfoDialog
2014/1/29:20:44:33 Sebastian SEBASTIAN-PC PageOpen ProductSelectionDialog2
2014/1/29:20:44:44 Sebastian SEBASTIAN-PC PageOpen FullProgressDialog
2014/1/29:20:44:45 Sebastian SEBASTIAN-PC Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/DIRECTX...
2014/1/29:20:44:45 Sebastian SEBASTIAN-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/1/29:20:48:06 Sebastian SEBASTIAN-PC Install DirectX® Runtime Succeeded
2014/1/29:20:48:09 Sebastian SEBASTIAN-PC Download Play Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/Maya_en...
2014/1/29:21:44:23 Sebastian SEBASTIAN-PC Download Error Maya <B>Connection has expired.</B>Please Install Now again from the Autodesk website. http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/Maya_en...
2014/1/29:21:44:23 Sebastian SEBASTIAN-PC Download Error Maya Decompressing failed http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/Maya_en...
2014/1/29:21:44:24 Sebastian SEBASTIAN-PC Download Aborted Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/Maya_en...
2014/1/29:21:44:24 Sebastian SEBASTIAN-PC Install Autodesk® Maya® 2014 Failed Download Failed, Installation aborted, Result=1603
2014/1/29:21:44:25 Sebastian SEBASTIAN-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/1/29:21:44:26 Sebastian SEBASTIAN-PC PageOpen InstallCompleteDialog
2014/1/29:21:56:20 Sebastian SEBASTIAN-PC === Setup ended ===
2014/2/3:01:14:06 Sebastian SEBASTIAN-PC === Setup started on SEBASTIAN-PC by Sebastian ===
2014/2/3:01:14:06 Sebastian SEBASTIAN-PC Path_Length: 151
2014/2/3:01:14:06 Sebastian SEBASTIAN-PC Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2014/2/3:01:14:06 Sebastian SEBASTIAN-PC Launch
2014/2/3:01:14:06 Sebastian SEBASTIAN-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/Autodesk_Maya_2014_wi_en-US_Setup.exe" /SN 900-36874060 /PK 657F1 /student /akamai /auth authparam /sid SESSION_ID
2014/2/3:01:14:06 Sebastian SEBASTIAN-PC Current Directory C:\Users\SEBAST~1\AppData\Local\Temp\_AI6D3B.tmp
2014/2/3:01:14:14 Sebastian SEBASTIAN-PC === Setup ended ===
2014/2/3:01:14:08 Sebastian SEBASTIAN-PC === Setup started on SEBASTIAN-PC by Sebastian ===
2014/2/3:01:14:08 Sebastian SEBASTIAN-PC Path_Length: 151
2014/2/3:01:14:08 Sebastian SEBASTIAN-PC Current Directory C:\Users\SEBAST~1\AppData\Local\Temp\_AI6D3B.tmp
2014/2/3:01:14:08 Sebastian SEBASTIAN-PC Launch
2014/2/3:01:14:09 Sebastian SEBASTIAN-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/SETUP_x...
2014/2/3:01:14:13 Sebastian SEBASTIAN-PC PageOpen LaunchDialog
2014/2/3:01:14:32 Sebastian SEBASTIAN-PC PageOpen LicenseDialog
2014/2/3:01:14:35 Sebastian SEBASTIAN-PC PageOpen ProductSelectionDialog2
2014/2/3:01:14:38 Sebastian SEBASTIAN-PC PageOpen FullProgressDialog
2014/2/3:01:14:39 Sebastian SEBASTIAN-PC Installing Network License Manager: INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Network License Manager\" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Maya 2014" SETUP_PACKAGECODE={44FFD99B-4877-4732-AA33-2FD3D7B622D2} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Maya 2014" INSTALLDIR="C:\Program Files\Autodesk Network License Manager\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/3:01:14:41 Sebastian SEBASTIAN-PC Install Network License Manager Succeeded
2014/2/3:01:14:41 Sebastian SEBASTIAN-PC PageOpen InstallCompleteDialog
2014/2/3:01:14:46 Sebastian SEBASTIAN-PC === Setup ended ===
2014/2/3:01:17:54 Sebastian SEBASTIAN-PC === Setup started on SEBASTIAN-PC by Sebastian ===
2014/2/3:01:17:54 Sebastian SEBASTIAN-PC Path_Length: 151
2014/2/3:01:17:54 Sebastian SEBASTIAN-PC Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2014/2/3:01:17:54 Sebastian SEBASTIAN-PC Launch
2014/2/3:01:17:54 Sebastian SEBASTIAN-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/Autodesk_Maya_2014_wi_en-US_Setup.exe" /SN 900-36874060 /PK 657F1 /student /akamai /auth authparam /sid SESSION_ID
2014/2/3:01:17:54 Sebastian SEBASTIAN-PC Current Directory C:\Users\SEBAST~1\AppData\Local\Temp\_AIED33.tmp
2014/2/3:01:17:58 Sebastian SEBASTIAN-PC === Setup ended ===
2014/2/3:01:17:57 Sebastian SEBASTIAN-PC === Setup started on SEBASTIAN-PC by Sebastian ===
2014/2/3:01:17:57 Sebastian SEBASTIAN-PC Path_Length: 151
2014/2/3:01:17:57 Sebastian SEBASTIAN-PC Current Directory C:\Users\SEBAST~1\AppData\Local\Temp\_AIED33.tmp
2014/2/3:01:17:57 Sebastian SEBASTIAN-PC Launch
2014/2/3:01:17:58 Sebastian SEBASTIAN-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/SETUP_x...
2014/2/3:01:17:58 Sebastian SEBASTIAN-PC PageOpen LaunchDialog
2014/2/3:01:18:06 Sebastian SEBASTIAN-PC PageOpen LicenseDialog
2014/2/3:01:18:09 Sebastian SEBASTIAN-PC PageOpen ProductInfoDialog
2014/2/3:01:18:09 Sebastian SEBASTIAN-PC PageOpen ProductSelectionDialog2
2014/2/3:01:18:18 Sebastian SEBASTIAN-PC PageOpen FullProgressDialog
2014/2/3:01:18:18 Sebastian SEBASTIAN-PC Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/DIRECTX...
2014/2/3:01:18:18 Sebastian SEBASTIAN-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/2/3:01:20:28 Sebastian SEBASTIAN-PC Install DirectX® Runtime Succeeded
2014/2/3:01:20:29 Sebastian SEBASTIAN-PC Download Play Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/Maya_en...
2014/2/3:01:21:16 Sebastian SEBASTIAN-PC Download Aborted Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/Maya_en...
2014/2/3:01:21:16 Sebastian SEBASTIAN-PC Install Autodesk® Maya® 2014 Failed Download Failed, Installation aborted, Result=1603
2014/2/3:01:21:17 Sebastian SEBASTIAN-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/2/3:01:21:18 Sebastian SEBASTIAN-PC PageOpen InstallCompleteDialog
2014/2/3:01:30:01 Sebastian SEBASTIAN-PC === Setup ended ===
2014/2/3:01:30:22 Sebastian SEBASTIAN-PC === Setup started on SEBASTIAN-PC by Sebastian ===
2014/2/3:01:30:22 Sebastian SEBASTIAN-PC Path_Length: 151
2014/2/3:01:30:22 Sebastian SEBASTIAN-PC Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2014/2/3:01:30:22 Sebastian SEBASTIAN-PC Launch
2014/2/3:01:30:22 Sebastian SEBASTIAN-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/Autodesk_Maya_2014_wi_en-US_Setup.exe" /SN 900-36874060 /PK 657F1 /student /akamai /auth authparam /sid SESSION_ID
2014/2/3:01:30:22 Sebastian SEBASTIAN-PC Current Directory C:\Users\SEBAST~1\AppData\Local\Temp\_AI570D.tmp
2014/2/3:01:30:26 Sebastian SEBASTIAN-PC === Setup ended ===
2014/2/3:01:30:24 Sebastian SEBASTIAN-PC === Setup started on SEBASTIAN-PC by Sebastian ===
2014/2/3:01:30:24 Sebastian SEBASTIAN-PC Path_Length: 151
2014/2/3:01:30:24 Sebastian SEBASTIAN-PC Current Directory C:\Users\SEBAST~1\AppData\Local\Temp\_AI570D.tmp
2014/2/3:01:30:24 Sebastian SEBASTIAN-PC Launch
2014/2/3:01:30:25 Sebastian SEBASTIAN-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/SETUP_x...
2014/2/3:01:30:26 Sebastian SEBASTIAN-PC PageOpen LaunchDialog
2014/2/3:01:30:33 Sebastian SEBASTIAN-PC PageOpen LicenseDialog
2014/2/3:01:30:36 Sebastian SEBASTIAN-PC PageOpen ProductInfoDialog
2014/2/3:01:30:36 Sebastian SEBASTIAN-PC PageOpen ProductSelectionDialog2
2014/2/3:01:30:41 Sebastian SEBASTIAN-PC PageOpen FullProgressDialog
2014/2/3:01:30:41 Sebastian SEBASTIAN-PC Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/DIRECTX...
2014/2/3:01:30:41 Sebastian SEBASTIAN-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/2/3:01:32:14 Sebastian SEBASTIAN-PC Install DirectX® Runtime Succeeded
2014/2/3:01:32:15 Sebastian SEBASTIAN-PC Download Play Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/Maya_en...
2014/2/3:01:43:47 Sebastian SEBASTIAN-PC Download Aborted Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/Maya_en...
2014/2/3:01:43:47 Sebastian SEBASTIAN-PC Install Autodesk® Maya® 2014 Failed Download Failed, Installation aborted, Result=1603
2014/2/3:01:43:48 Sebastian SEBASTIAN-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/2/3:01:43:48 Sebastian SEBASTIAN-PC PageOpen InstallCompleteDialog
2014/2/3:01:58:54 Sebastian SEBASTIAN-PC === Setup ended ===
2014/2/3:01:58:53 Sebastian SEBASTIAN-PC === Setup started on SEBASTIAN-PC by Sebastian ===
2014/2/3:01:58:53 Sebastian SEBASTIAN-PC Path_Length: 151
2014/2/3:01:58:53 Sebastian SEBASTIAN-PC Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2014/2/3:01:58:53 Sebastian SEBASTIAN-PC Launch
2014/2/3:01:58:53 Sebastian SEBASTIAN-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/Autodesk_Maya_2014_wi_en-US_Setup.exe" /SN 900-36874060 /PK 657F1 /student /akamai /auth authparam /sid SESSION_ID
2014/2/3:01:58:53 Sebastian SEBASTIAN-PC Current Directory C:\Users\SEBAST~1\AppData\Local\Temp\_AI72E6.tmp
2014/2/3:01:58:57 Sebastian SEBASTIAN-PC === Setup ended ===
2014/2/3:01:58:55 Sebastian SEBASTIAN-PC === Setup started on SEBASTIAN-PC by Sebastian ===
2014/2/3:01:58:55 Sebastian SEBASTIAN-PC Path_Length: 151
2014/2/3:01:58:55 Sebastian SEBASTIAN-PC Current Directory C:\Users\SEBAST~1\AppData\Local\Temp\_AI72E6.tmp
2014/2/3:01:58:55 Sebastian SEBASTIAN-PC Launch
2014/2/3:01:58:57 Sebastian SEBASTIAN-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/SETUP_x...
2014/2/3:01:58:57 Sebastian SEBASTIAN-PC PageOpen LaunchDialog
2014/2/3:01:59:09 Sebastian SEBASTIAN-PC PageOpen LicenseDialog
2014/2/3:01:59:14 Sebastian SEBASTIAN-PC PageOpen ProductInfoDialog
2014/2/3:01:59:14 Sebastian SEBASTIAN-PC PageOpen ProductSelectionDialog2
2014/2/3:02:00:16 Sebastian SEBASTIAN-PC PageOpen FullProgressDialog
2014/2/3:02:00:16 Sebastian SEBASTIAN-PC Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/DIRECTX...
2014/2/3:02:00:16 Sebastian SEBASTIAN-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/2/3:02:01:46 Sebastian SEBASTIAN-PC Install DirectX® Runtime Succeeded
2014/2/3:02:01:47 Sebastian SEBASTIAN-PC Download Play Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/Maya_en...
2014/2/3:02:13:06 Sebastian SEBASTIAN-PC Download Aborted Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/Maya_en...
2014/2/3:02:13:06 Sebastian SEBASTIAN-PC Install Autodesk® Maya® 2014 Failed Download Failed, Installation aborted, Result=1603
2014/2/3:02:13:07 Sebastian SEBASTIAN-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/2/3:02:13:07 Sebastian SEBASTIAN-PC PageOpen InstallCompleteDialog
2014/2/3:02:17:39 Sebastian SEBASTIAN-PC === Setup ended ===
2014/2/3:02:35:14 Sebastian SEBASTIAN-PC === Setup started on SEBASTIAN-PC by Sebastian ===
2014/2/3:02:35:14 Sebastian SEBASTIAN-PC Path_Length: 151
2014/2/3:02:35:14 Sebastian SEBASTIAN-PC Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2014/2/3:02:35:14 Sebastian SEBASTIAN-PC Launch
2014/2/3:02:35:14 Sebastian SEBASTIAN-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/Autodesk_Maya_2014_wi_en-US_Setup.exe" /SN 900-36874060 /PK 657F1 /student /akamai /auth authparam /sid SESSION_ID
2014/2/3:02:35:14 Sebastian SEBASTIAN-PC Current Directory C:\Users\SEBAST~1\AppData\Local\Temp\_AIB987.tmp
2014/2/3:02:35:17 Sebastian SEBASTIAN-PC === Setup ended ===
2014/2/3:02:35:16 Sebastian SEBASTIAN-PC === Setup started on SEBASTIAN-PC by Sebastian ===
2014/2/3:02:35:16 Sebastian SEBASTIAN-PC Path_Length: 151
2014/2/3:02:35:16 Sebastian SEBASTIAN-PC Current Directory C:\Users\SEBAST~1\AppData\Local\Temp\_AIB987.tmp
2014/2/3:02:35:16 Sebastian SEBASTIAN-PC Launch
2014/2/3:02:35:16 Sebastian SEBASTIAN-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/SETUP_x...
2014/2/3:02:35:17 Sebastian SEBASTIAN-PC PageOpen LaunchDialog
2014/2/3:02:35:25 Sebastian SEBASTIAN-PC PageOpen LicenseDialog
2014/2/3:02:35:28 Sebastian SEBASTIAN-PC PageOpen ProductInfoDialog
2014/2/3:02:35:28 Sebastian SEBASTIAN-PC PageOpen ProductSelectionDialog2
2014/2/3:02:35:31 Sebastian SEBASTIAN-PC PageOpen FullProgressDialog
2014/2/3:02:35:31 Sebastian SEBASTIAN-PC Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/DIRECTX...
2014/2/3:02:35:31 Sebastian SEBASTIAN-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/2/3:02:37:12 Sebastian SEBASTIAN-PC Install DirectX® Runtime Succeeded
2014/2/3:02:37:13 Sebastian SEBASTIAN-PC Download Play Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/Maya_en...
2014/2/3:02:50:07 Sebastian SEBASTIAN-PC Download Aborted Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/Maya_en...
2014/2/3:02:50:07 Sebastian SEBASTIAN-PC Install Autodesk® Maya® 2014 Failed Download Failed, Installation aborted, Result=1603
2014/2/3:02:50:08 Sebastian SEBASTIAN-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
1 REPLY 1
TravisNave
You are experiencing an unfortunate error plaguing a lot of users recently.
 I have created an article about that here:
http://forums.autodesk.com/t5/Installation-Licensing/Download-Failed-Installation-aborted-Result-160...
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
