Installation & Licensing
New Member
andrewalbon
Message 1 of 5 (7,247 Views)
Autodesk Maya 2013 '0xc000007b' error
7247 Views, 4 Replies
01-04-2013 05:11 AM
Hello I have recently attempted to upgrade from Maya 2011 to Maya 2013.
After I installed 2013 and it attempted to open it a message popped up saying:
"The application was unable to start correctly (0xc000007b). Click OK to close the application."
At first I thought it was because there were 2 versions of maya on the same machine so I uninstalled EVERY piece of Autodesk software and reinstalled Maya 2013. The error message still appears.
How can this be fixed? I've searched everywhere but found no reliabe method.
This shouldn't be getting in my way.
I am on Windows 7 64-bit
New Member
pjmbraddock
Message 2 of 5 (7,183 Views)
Re: Autodesk Maya 2013 '0xc000007b' error
01-07-2013 07:44 PM in reply to: andrewalbon
I am having this exact same issue, and have found many threads on it all over the internet with no solution.
Have you had any luck with it?
camilo.lemos
Message 3 of 5 (7,165 Views)
01-08-2013 01:39 AM in reply to: pjmbraddock
Hi andrewalbon and pjmbraddock,
Through a search here on the forums I've been able to find these two threads containing possible solutions for this error:
Thread 1
Thread 2
Please, can you try the methods mentioned on these threads and let me know if they work for you?
Camilo Lemos
Member
mircot80
Message 4 of 5 (7,018 Views)
01-21-2013 08:18 AM in reply to: andrewalbon
New Member
kevin_rutland
Message 5 of 5 (6,704 Views)
02-23-2013 03:11 PM in reply to: mircot80
I am having the same problem and I dont speak Italian and already went through that. 3dsmax 2013
