Installation & Licensing
Autodesk Maya 2012 sp1 x64 installation failed
4 REPLIES 4
2206 Views, 4 Replies
Hi I am trying to install Maya 2012 sp1 x64 But it keeps giving me this error.
1:52:adlmPIT SetProductInformation failed 3:25
And then in the installation log it gives me this:
2012/2/7:10:53:58 Geran GERAN-PC === Setup started on GERAN-PC by Geran ===
2012/2/7:10:53:58 Geran GERAN-PC Launch
2012/2/7:10:54:25 Geran GERAN-PC PageOpen LaunchDialog
2012/2/7:10:58:27 Geran GERAN-PC PageOpen LicenseDialog
2012/2/7:11:03:32 Geran GERAN-PC PageOpen ProductInfoDialog
2012/2/7:11:03:38 Geran GERAN-PC PageOpen ProductSelectionDialog2
2012/2/7:11:03:40 Geran GERAN-PC PageOpen FullProgressDialog
2012/2/7:11:03:40 Geran GERAN-PC Installing DirectX® Runtime: C:\Autodesk\Maya_2012_EJ_Win_64-bit\3rdParty\DirectX\DXSETUP.exe /silent
2012/2/7:11:06:39 Geran GERAN-PC Install DirectX® Runtime Succeeded
2012/2/7:11:06:43 Geran GERAN-PC Installing Autodesk® Maya® 2012: TRANSFORMS="C:\Users\Geran\AppData\Local\Temp\_AI428.tmp\x64\Maya\Maya2012-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Maya_2012_EJ_Win_64-bit\" INSTALLDIR="C:\Program Files\Autodesk\Maya2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/2/7:11:15:12 Geran GERAN-PC Install Autodesk® Maya® 2012 Failed Installation aborted, Result=1603
2012/2/7:11:15:12 Geran GERAN-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
I am at my wits end! I have tried many possible solutions this is my final desparate attempt to get it working.
If all else fails I will reinstall my Windows 7 (which I am not looking forward to)
Please is there anyway around this error?
All and any help will be much appreciated.
Geran
4 REPLIES 4
Dwayne.Poot
Hi GeranBronn;
   Unfortunately the error indicates the Productinformation.PIT file has become corrupt. You will need to remove or rename the file to .OLD to install Maya. This will also force the re-installation of the other Autodesk applications. If you have other Autodesk applications please remove them via Add/Remove programs and then remove the .PIT from the below folder
Windows XP
C:\Documents and Settings\All Users\Application Data\Autodesk\AdLM
Windows Vista or 7
C:\Users\All Users\Autodesk\Adlm
- Note: you may need to turn on Show Hidden files and folders and Show System folders on in your control panel
Dwayne
Dwayne Poot
Support Specialist
Product Support
Autodesk, Inc.
in reply to: Dwayne.Poot
Hello, I have a problem with the installation of Autodesk Maya 2012 . I installed the program many times but there seems to be some kind of a problem and I have this result=1603. Each time, there is this error while the Microsoft Visual C++ 2005 SP1 Redistributable installation. I dont know what to do, maybe someone can help me.
Thank you.
Windows 7
Intel Core i7
64bit OS
video card : nvidia GeForce 660M
2012/10/26:01:52:55 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
2012/10/26:01:52:55 LENOVO LENOVO-PC Launch
2012/10/26:01:53:17 LENOVO LENOVO-PC === Setup ended ===
2012/10/26:01:53:18 LENOVO LENOVO-PC PageOpen LaunchDialog
2012/10/26:01:54:46 LENOVO LENOVO-PC PageOpen LicenseDialog
2012/10/26:01:55:40 LENOVO LENOVO-PC PageOpen ProductInfoDialog
2012/10/26:01:56:56 LENOVO LENOVO-PC PageOpen ProductSelectionDialog2
2012/10/26:01:57:13 LENOVO LENOVO-PC PageOpen FullProgressDialog
2012/10/26:01:57:13 LENOVO LENOVO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\Maya_2012_EJ_Win_64-bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\LENOVO\AppData\Local\Temp\vcredist_x86_2005.log"" "
2012/10/26:03:02:43 LENOVO LENOVO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2012/10/26:03:02:43 LENOVO LENOVO-PC PageOpen InstallCompleteDialog
2012/10/26:07:08:43 LENOVO LENOVO-PC === Setup ended ===
2012/10/26:07:10:44 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
2012/10/26:07:10:44 LENOVO LENOVO-PC Launch
2012/10/26:07:10:51 LENOVO LENOVO-PC === Setup ended ===
2012/10/26:07:10:45 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
2012/10/26:07:10:45 LENOVO LENOVO-PC Launch
2012/10/26:07:10:51 LENOVO LENOVO-PC PageOpen LaunchDialog
2012/10/26:07:14:21 LENOVO LENOVO-PC PageOpen LicenseDialog
2012/10/26:07:15:39 LENOVO LENOVO-PC PageOpen ProductInfoDialog
2012/10/26:07:16:41 LENOVO LENOVO-PC PageOpen ProductSelectionDialog2
2012/10/26:07:18:18 LENOVO LENOVO-PC PageOpen FullProgressDialog
2012/10/26:07:18:19 LENOVO LENOVO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\Maya_2012_EJ_Win_64-bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\LENOVO\AppData\Local\Temp\vcredist_x86_2005.log"" "
2012/10/26:08:42:02 LENOVO LENOVO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2012/10/26:08:42:02 LENOVO LENOVO-PC PageOpen InstallCompleteDialog
2012/10/26:09:26:25 LENOVO LENOVO-PC === Setup ended ===
2012/10/26:09:39:00 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
2012/10/26:09:39:00 LENOVO LENOVO-PC Launch
2012/10/26:09:39:08 LENOVO LENOVO-PC === Setup ended ===
2012/10/26:09:39:07 LENOVO LENOVO-PC PageOpen LaunchDialog
2012/10/26:09:40:37 LENOVO LENOVO-PC PageOpen LicenseDialog
2012/10/26:09:41:02 LENOVO LENOVO-PC PageOpen ProductInfoDialog
2012/10/26:09:41:33 LENOVO LENOVO-PC PageOpen ProductSelectionDialog2
2012/10/26:09:41:39 LENOVO LENOVO-PC PageOpen FullProgressDialog
2012/10/26:09:41:39 LENOVO LENOVO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\Maya_2012_EJ_Win_64-bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\LENOVO\AppData\Local\Temp\vcredist_x86_2005.log"" "
2012/10/26:10:52:26 LENOVO LENOVO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2012/10/26:10:52:26 LENOVO LENOVO-PC PageOpen InstallCompleteDialog
2012/10/26:10:53:18 LENOVO LENOVO-PC === Setup ended ===
2012/10/26:13:17:47 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
2012/10/26:13:17:47 LENOVO LENOVO-PC Launch
2012/10/26:13:17:59 LENOVO LENOVO-PC === Setup ended ===
2012/10/26:13:17:48 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
2012/10/26:13:17:48 LENOVO LENOVO-PC Launch
2012/10/26:13:17:59 LENOVO LENOVO-PC PageOpen LaunchDialog
2012/10/26:13:19:31 LENOVO LENOVO-PC PageOpen LicenseDialog
2012/10/26:13:20:14 LENOVO LENOVO-PC PageOpen ProductInfoDialog
2012/10/26:13:20:51 LENOVO LENOVO-PC PageOpen ProductSelectionDialog2
2012/10/26:13:21:43 LENOVO LENOVO-PC PageOpen FullProgressDialog
2012/10/26:13:21:43 LENOVO LENOVO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\Maya_2012_EJ_Win_64-bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\LENOVO\AppData\Local\Temp\vcredist_x86_2005.log"" "
2012/10/26:14:17:02 LENOVO LENOVO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2012/10/26:14:17:02 LENOVO LENOVO-PC PageOpen InstallCompleteDialog
2012/10/26:16:49:44 LENOVO LENOVO-PC === Setup ended ===
2012/10/26:16:54:06 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
2012/10/26:16:54:06 LENOVO LENOVO-PC Launch
2012/10/26:16:54:23 LENOVO LENOVO-PC === Setup ended ===
2012/10/26:16:54:07 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
2012/10/26:16:54:07 LENOVO LENOVO-PC Launch
2012/10/26:16:54:23 LENOVO LENOVO-PC PageOpen LaunchDialog
2012/10/26:16:54:27 LENOVO LENOVO-PC PageOpen LicenseDialog
2012/10/26:16:54:30 LENOVO LENOVO-PC PageOpen ProductSelectionDialog2
2012/10/26:16:54:56 LENOVO LENOVO-PC PageOpen FullProgressDialog
2012/10/26:16:54:56 LENOVO LENOVO-PC Installing Network License Manager: INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Network License Manager\" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Maya_2012_EJ_Win_64-bit\" INSTALLDIR="C:\Program Files\Autodesk Network License Manager\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/10/26:16:54:58 LENOVO LENOVO-PC Install Network License Manager Succeeded
2012/10/26:16:54:58 LENOVO LENOVO-PC PageOpen InstallCompleteDialog
2012/10/26:16:55:09 LENOVO LENOVO-PC === Setup ended ===
2012/10/26:16:56:07 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
2012/10/26:16:56:07 LENOVO LENOVO-PC Launch
2012/10/26:16:56:11 LENOVO LENOVO-PC === Setup ended ===
2012/10/28:10:50:58 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
2012/10/28:10:50:58 LENOVO LENOVO-PC Launch
2012/10/28:10:51:13 LENOVO LENOVO-PC === Setup ended ===
2012/10/28:10:51:00 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
2012/10/28:10:51:00 LENOVO LENOVO-PC Launch
2012/10/28:10:51:13 LENOVO LENOVO-PC PageOpen LaunchDialog
2012/10/28:10:54:46 LENOVO LENOVO-PC PageOpen LicenseDialog
2012/10/28:10:54:50 LENOVO LENOVO-PC PageOpen ProductInfoDialog
2012/10/28:10:55:34 LENOVO LENOVO-PC PageOpen ProductSelectionDialog2
2012/10/28:10:55:45 LENOVO LENOVO-PC PageOpen FullProgressDialog
2012/10/28:10:55:45 LENOVO LENOVO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): F:\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\LENOVO\AppData\Local\Temp\vcredist_x86_2005.log"" "
2012/10/28:11:51:07 LENOVO LENOVO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2012/10/28:11:51:08 LENOVO LENOVO-PC PageOpen InstallCompleteDialog
2012/10/28:12:14:28 LENOVO LENOVO-PC === Setup ended ===
2012/10/31:15:24:52 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
2012/10/31:15:24:52 LENOVO LENOVO-PC Launch
2012/10/31:15:25:08 LENOVO LENOVO-PC === Setup ended ===
2012/10/31:15:24:53 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
2012/10/31:15:24:53 LENOVO LENOVO-PC Launch
2012/10/31:15:25:09 LENOVO LENOVO-PC PageOpen LaunchDialog
2012/10/31:15:26:33 LENOVO LENOVO-PC PageOpen LicenseDialog
2012/10/31:15:27:09 LENOVO LENOVO-PC PageOpen ProductInfoDialog
2012/10/31:15:27:43 LENOVO LENOVO-PC PageOpen ProductSelectionDialog2
2012/10/31:15:29:38 LENOVO LENOVO-PC PageOpen FullProgressDialog
2012/10/31:15:29:38 LENOVO LENOVO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\Maya_2012_EJ_Win_64-bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\LENOVO\AppData\Local\Temp\vcredist_x86_2005.log"" "
2012/10/31:16:24:58 LENOVO LENOVO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2012/10/31:16:24:58 LENOVO LENOVO-PC PageOpen InstallCompleteDialog
2012/10/31:17:07:52 LENOVO LENOVO-PC === Setup ended ===
2012/11/7:23:55:20 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
2012/11/7:23:55:20 LENOVO LENOVO-PC Launch
2012/11/7:23:55:44 LENOVO LENOVO-PC === Setup ended ===
2012/11/7:23:55:21 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
2012/11/7:23:55:21 LENOVO LENOVO-PC Launch
2012/11/7:23:55:45 LENOVO LENOVO-PC PageOpen LaunchDialog
2012/11/7:23:56:16 LENOVO LENOVO-PC PageOpen BeginDeploymentDialog
2012/11/7:23:56:52 LENOVO LENOVO-PC PageOpen LaunchDialog
2012/11/7:23:57:00 LENOVO LENOVO-PC PageOpen LicenseDialog
2012/11/7:23:57:03 LENOVO LENOVO-PC PageOpen ProductSelectionDialog2
2012/11/7:23:57:07 LENOVO LENOVO-PC PageOpen LicenseDialog
2012/11/7:23:57:07 LENOVO LENOVO-PC PageOpen LaunchDialog
2012/11/7:23:58:24 LENOVO LENOVO-PC PageOpen LicenseDialog
2012/11/7:23:58:43 LENOVO LENOVO-PC PageOpen ProductInfoDialog
2012/11/7:23:59:27 LENOVO LENOVO-PC PageOpen ProductSelectionDialog2
2012/11/8:00:00:06 LENOVO LENOVO-PC PageOpen FullProgressDialog
2012/11/8:00:00:06 LENOVO LENOVO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\Maya_2012_EJ_Win_64-bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\LENOVO\AppData\Local\Temp\vcredist_x86_2005.log"" "
2012/11/8:00:58:27 LENOVO LENOVO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2012/11/8:00:58:27 LENOVO LENOVO-PC PageOpen InstallCompleteDialog
2012/11/8:01:09:50 LENOVO LENOVO-PC === Setup ended ===
2012/11/8:01:12:07 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
2012/11/8:01:12:07 LENOVO LENOVO-PC Launch
2012/11/8:01:12:15 LENOVO LENOVO-PC === Setup ended ===
2012/11/8:01:12:08 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
2012/11/8:01:12:08 LENOVO LENOVO-PC Launch
2012/11/8:01:12:15 LENOVO LENOVO-PC PageOpen LaunchDialog
2012/11/8:01:16:13 LENOVO LENOVO-PC PageOpen LicenseDialog
2012/11/8:01:16:32 LENOVO LENOVO-PC PageOpen ProductInfoDialog
2012/11/8:01:16:58 LENOVO LENOVO-PC PageOpen ProductSelectionDialog2
2012/11/8:01:17:02 LENOVO LENOVO-PC PageOpen FullProgressDialog
2012/11/8:01:17:02 LENOVO LENOVO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\Maya_2012_EJ_Win_64-bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\LENOVO\AppData\Local\Temp\vcredist_x86_2005.log"" "
2012/11/8:03:08:56 LENOVO LENOVO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2012/11/8:03:08:56 LENOVO LENOVO-PC PageOpen InstallCompleteDialog
2012/11/8:03:35:44 LENOVO LENOVO-PC === Setup ended ===
2012/11/8:07:01:14 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
2012/11/8:07:01:14 LENOVO LENOVO-PC Launch
2012/11/8:07:01:28 LENOVO LENOVO-PC === Setup ended ===
2012/11/8:07:01:28 LENOVO LENOVO-PC PageOpen LaunchDialog
2012/11/8:07:03:00 LENOVO LENOVO-PC PageOpen LicenseDialog
2012/11/8:07:04:32 LENOVO LENOVO-PC PageOpen ProductInfoDialog
2012/11/8:07:05:16 LENOVO LENOVO-PC PageOpen ProductSelectionDialog2
2012/11/8:07:05:20 LENOVO LENOVO-PC PageOpen FullProgressDialog
2012/11/8:07:05:21 LENOVO LENOVO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\Maya_2012_EJ_Win_64-bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\LENOVO\AppData\Local\Temp\vcredist_x86_2005.log"" "
2012/11/8:08:00:39 LENOVO LENOVO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2012/11/8:08:00:39 LENOVO LENOVO-PC PageOpen InstallCompleteDialog
2012/11/8:09:53:20 LENOVO LENOVO-PC === Setup ended ===
2012/11/8:10:25:56 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
2012/11/8:10:25:56 LENOVO LENOVO-PC Launch
2012/11/8:10:26:55 LENOVO LENOVO-PC === Setup ended ===
2012/11/8:10:26:55 LENOVO LENOVO-PC PageOpen LaunchDialog
2012/11/8:10:28:16 LENOVO LENOVO-PC PageOpen LicenseDialog
2012/11/8:10:28:34 LENOVO LENOVO-PC PageOpen ProductInfoDialog
2012/11/8:10:29:16 LENOVO LENOVO-PC === Setup ended ===
2012/11/8:10:29:37 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
2012/11/8:10:29:37 LENOVO LENOVO-PC Launch
2012/11/8:10:29:40 LENOVO LENOVO-PC === Setup ended ===
2012/11/8:10:29:40 LENOVO LENOVO-PC PageOpen LaunchDialog
2012/11/8:10:31:08 LENOVO LENOVO-PC PageOpen LicenseDialog
2012/11/8:10:33:58 LENOVO LENOVO-PC === Setup ended ===
2012/11/8:10:57:24 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
2012/11/8:10:57:24 LENOVO LENOVO-PC Launch
2012/11/8:10:57:28 LENOVO LENOVO-PC === Setup ended ===
2012/11/8:13:16:42 LENOVO LENOVO-PC === Setup started on LENOVO-PC by LENOVO ===
2012/11/8:13:16:42 LENOVO LENOVO-PC Launch
2012/11/8:13:16:54 LENOVO LENOVO-PC === Setup ended ===
2012/11/8:13:16:53 LENOVO LENOVO-PC PageOpen LaunchDialog
2012/11/8:13:18:14 LENOVO LENOVO-PC PageOpen LicenseDialog
2012/11/8:13:18:37 LENOVO LENOVO-PC PageOpen ProductInfoDialog
2012/11/8:13:19:08 LENOVO LENOVO-PC PageOpen ProductSelectionDialog2
2012/11/8:13:19:13 LENOVO LENOVO-PC PageOpen FullProgressDialog
2012/11/8:13:19:13 LENOVO LENOVO-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\Maya_2012_EJ_Win_64-bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\LENOVO\AppData\Local\Temp\vcredist_x86_2005.log"" "
2012/11/8:15:05:33 LENOVO LENOVO-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
How to fix that ...
please help !!!
stocker689
Have same problem here, diffretns i my error is Result=2, and when i isntall only Maya, error give me massage
"1606: COULD NOT ACCESS NETWORK LOCATION bin/DE-DE/"
i tried instal and reinstall NET Framework, repair registry, also tried with disconected web but error always show
Administrator Productivity
