Installation & Licensing
Welcome to Autodeskā€™s Installation and Licensing Forums. Share your knowledge, ask questions, and explore popular Download, Installation, and Licensing topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Autodesk License Manager on Windows 64 bit
2 REPLIES 2
338 Views, 2 Replies
Hi
I need to install the Autodesk Network License Manager on a Windows 2003 R2 64 bit with Xeon processor.
On macrovision.com i found 3 archives created for this platform:
lmgrd.exe
lmutil.exe
lmtools.exe
But the file adskflex.exe was not found.
If i start lmtools.exe the application run, but without adskflex.exe donĀ“t recognize the license file.
Any ideas?
2 REPLIES 2
TravisNave
Use the adskflex.exe in your CD. That is provided by Autodesk, not Macrovision. Let me know if it works.
What is the version of the LMTOOLS that you downloaded from Macrovision.com?
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Travis, is the 10.8.
I just install the NLM that came with Acad 2007 and work
Tanks
Administrator Productivity
