Installation & Licensing
Member
s.reald
Message 1 of 6 (370 Views)
Autodesk Invertor Prof. instalation problem - nothing instal please help
370 Views, 5 Replies
12-27-2012 08:33 AM
I Cant install any component/program of Autodesk Invertor Professional. I have serial number from student section because Im student from one school. When I downloaded installer from Autodesk student site, apply serial code, then the installations completed in few minutes but the result is that nothing installed, every program have red cross next to it and it says that nothing installed. Please help. I attach a log file from that. By the way my computer reaches the recommended requirements.
Install    Microsoft Visual C + + 2010 Redistributable (x86)    Failed    Installation aborted, Result=1603
Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/3382347
Good Luck!
TravisNave
Message 2 of 6 (361 Views)
Re: Autodesk Invertor Prof. instalation problem - nothing instal please help
12-27-2012 08:58 AM in reply to: s.reald
Please attach the log file.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
jessica.t
Message 3 of 6 (358 Views)
12-27-2012 09:04 AM in reply to: s.reald
Hi S.Reald and welcome to the Discussion Forums!
You may want to try to the "Browser Download" option for your product. It sometimes works better than the "Download Now" choice. Clearing out your cookies and cache as well as temporarily disarming any firewalls or antivirus software also helps.
Jessica Thrasher
Member
s.reald
Message 4 of 6 (355 Views)
12-27-2012 09:09 AM in reply to: s.reald
I attached it, I think the better way would be that I paste here what is in the log file
2012/12/1:21:57:17    Kuba-RealD    JAKUBSKALA    === Setup started on JAKUBSKALA by Kuba-RealD ===
2012/12/1:21:57:17    Kuba-RealD    JAKUBSKALA    Launch
2012/12/1:21:58:46    Kuba-RealD    JAKUBSKALA    === Setup ended ===
2012/12/1:21:57:18    Kuba-RealD    JAKUBSKALA    === Setup started on JAKUBSKALA by Kuba-RealD ===
2012/12/1:21:57:18    Kuba-RealD    JAKUBSKALA    Launch
2012/12/1:21:57:43    Kuba-RealD    JAKUBSKALA    Inventorui== Parameter: Prereq_1 SetupMode:1 InstallState:1 InstallAction:0 Message:
2012/12/1:21:58:44    Kuba-RealD    JAKUBSKALA    Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2012/12/1:21:58:44    Kuba-RealD    JAKUBSKALA    Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2012/12/1:21:58:44    Kuba-RealD    JAKUBSKALA    Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message:
2012/12/1:21:58:47    Kuba-RealD    JAKUBSKALA    PageOpen    LaunchDialog
2012/12/1:21:58:53    Kuba-RealD    JAKUBSKALA    PageOpen    LicenseDialog
2012/12/1:21:58:56    Kuba-RealD    JAKUBSKALA    PageOpen    ProductInfoDialog
2012/12/1:21:59:05    Kuba-RealD    JAKUBSKALA    === Setup ended ===
2012/12/6:08:16:06    Kuba-RealD    JAKUBSKALA    === Setup started on JAKUBSKALA by Kuba-RealD ===
2012/12/6:08:16:06    Kuba-RealD    JAKUBSKALA    Launch
2012/12/6:08:16:20    Kuba-RealD    JAKUBSKALA    === Setup ended ===
2012/12/6:08:16:07    Kuba-RealD    JAKUBSKALA    === Setup started on JAKUBSKALA by Kuba-RealD ===
2012/12/6:08:16:07    Kuba-RealD    JAKUBSKALA    Launch
2012/12/6:08:16:14    Kuba-RealD    JAKUBSKALA    Inventorui== Parameter: Prereq_1 SetupMode:1 InstallState:1 InstallAction:0 Message:
2012/12/6:08:16:18    Kuba-RealD    JAKUBSKALA    Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2012/12/6:08:16:18    Kuba-RealD    JAKUBSKALA    Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2012/12/6:08:16:19    Kuba-RealD    JAKUBSKALA    Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message:
2012/12/6:08:16:21    Kuba-RealD    JAKUBSKALA    PageOpen    LaunchDialog
2012/12/6:08:16:40    Kuba-RealD    JAKUBSKALA    PageOpen    LicenseDialog
2012/12/6:08:19:12    Kuba-RealD    JAKUBSKALA    PageOpen    ProductInfoDialog
2012/12/6:08:19:48    Kuba-RealD    JAKUBSKALA    PageOpen    InventorFlavorSelectionDialog
2012/12/6:08:19:48    Kuba-RealD    JAKUBSKALA    Inventorui==DefaultLanguage:    cs-cz
2012/12/6:08:19:48    Kuba-RealD    JAKUBSKALA    Inventorui==InstallName:    INVENTOR
2012/12/6:08:19:48    Kuba-RealD    JAKUBSKALA    Inventorui==ProductName:    Autodesk Inventor 2012
2012/12/6:08:19:48    Kuba-RealD    JAKUBSKALA    Inventorui==DisplayName:    Autodesk® Inventor® 2012
2012/12/6:08:19:48    Kuba-RealD    JAKUBSKALA    Inventorui==DeploymentName:
2012/12/6:08:19:48    Kuba-RealD    JAKUBSKALA    Inventorui==SetupTitle:    Autodesk Inventor 2012
2012/12/6:08:19:48    Kuba-RealD    JAKUBSKALA    Inventorui==ConfigTransform:
2012/12/6:08:19:48    Kuba-RealD    JAKUBSKALA    Inventorui==ExeParams:
2012/12/6:08:19:48    Kuba-RealD    JAKUBSKALA    Inventorui==ProductCode:    {7F4DD591-1664-0409-0000-7107D70F3DB4}
2012/12/6:08:19:48    Kuba-RealD    JAKUBSKALA    Inventorui==SupportLink:
2012/12/6:08:19:48    Kuba-RealD    JAKUBSKALA    Inventorui==InfotainmentLink:
2012/12/6:08:19:48    Kuba-RealD    JAKUBSKALA    Inventorui==MsiFileName:    inventor.msi
2012/12/6:08:19:48    Kuba-RealD    JAKUBSKALA    Inventorui==AdminImageConfigName:    AdminImagex64
2012/12/6:08:19:48    Kuba-RealD    JAKUBSKALA    Inventorui==AdminImageRoot:
2012/12/6:08:19:48    Kuba-RealD    JAKUBSKALA    Inventorui==GetBaseDeploymentName:
2012/12/6:08:19:48    Kuba-RealD    JAKUBSKALA    Inventorui==DeploymentLocation:
2012/12/6:08:19:48    Kuba-RealD    JAKUBSKALA    Inventorui==DocumentLink:    SetupRes\InfoLink\help_landing.html
2012/12/6:08:19:48    Kuba-RealD    JAKUBSKALA    Inventorui==InstallDeploymentShortcut:
2012/12/6:08:19:48    Kuba-RealD    JAKUBSKALA    Inventorui==ModifyDeploymentShortcut:
2012/12/6:08:19:48    Kuba-RealD    JAKUBSKALA    Inventorui==SetupLockType:    2
2012/12/6:08:19:48    Kuba-RealD    JAKUBSKALA    Inventorui==SetupNetworkType:     0
2012/12/6:08:19:48    Kuba-RealD    JAKUBSKALA    Inventorui==SystemLocale:    1029
2012/12/6:08:19:48    Kuba-RealD    JAKUBSKALA    Inventorui==EvalMsiFilePath:    C:\Users\KUBA-R~1\AppData\Local\Temp\_AIC939.tmp\SetupRes\eval.msi
2012/12/6:08:19:48    Kuba-RealD    JAKUBSKALA    Inventorui==EulaPath:    C:\Users\KUBA-R~1\AppData\Local\Temp\_AIC939.tmp\EULA
2012/12/6:08:19:48    Kuba-RealD    JAKUBSKALA    Inventorui==InstallLogPath:    C:\Users\KUBA-R~1\AppData\Local\Temp\Inventor2012Install.log
2012/12/6:08:19:48    Kuba-RealD    JAKUBSKALA    Inventorui==ConfigFile:    C:\Users\KUBA-R~1\AppData\Local\Temp\_AIC939.tmp\setup.ini
2012/12/6:08:19:48    Kuba-RealD    JAKUBSKALA    Inventorui==SetupPath:    C:\Program Files (x86)\Autodesk\Autodesk_Inventor_2012_Czech_Win_64bit\
2012/12/6:08:19:48    Kuba-RealD    JAKUBSKALA    Inventorui==NetworkLogPath:
2012/12/6:08:19:48    Kuba-RealD    JAKUBSKALA    Inventorui==SourceRoot:    C:\Program Files (x86)\Autodesk\Autodesk_Inventor_2012_Czech_Win_64bit\
2012/12/6:08:19:56    Kuba-RealD    JAKUBSKALA    Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2012/12/6:08:19:56    Kuba-RealD    JAKUBSKALA    PageOpen    ProductSelectionDialog2
2012/12/6:08:20:11    Kuba-RealD    JAKUBSKALA    PageOpen    FullProgressDialog
2012/12/6:08:20:11    Kuba-RealD    JAKUBSKALA    Installing Microsoft Visual C++ 2005 SP1 (x86):   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Program Files (x86)\Autodesk\Autodesk_Inventor_2012_Czech_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/12/6:08:20:18    Kuba-RealD    JAKUBSKALA    Install    Microsoft Visual C++ 2005 SP1 (x86)    Succeeded
2012/12/6:08:20:18    Kuba-RealD    JAKUBSKALA    Installing Microsoft Visual C + + 2010 Redistributable (x86): C:\Program Files (x86)\Autodesk\Autodesk_Inventor_2012_Czech_Win_64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\KUBA-R~1\AppData\Local\Temp\vcredist_x86_2010.log
2012/12/6:08:20:20    Kuba-RealD    JAKUBSKALA    Install    Microsoft Visual C + + 2010 Redistributable (x86)    Failed    Installation aborted, Result=1603
2012/12/6:08:20:20    Kuba-RealD    JAKUBSKALA    PageOpen    InstallCompleteDialog
2012/12/6:08:20:52    Kuba-RealD    JAKUBSKALA    === Setup ended ===
2012/12/7:09:06:44    Kuba-RealD    JAKUBSKALA    === Setup started on JAKUBSKALA by Kuba-RealD ===
2012/12/7:09:06:44    Kuba-RealD    JAKUBSKALA    Launch
2012/12/7:09:07:20    Kuba-RealD    JAKUBSKALA    === Setup ended ===
2012/12/7:09:06:48    Kuba-RealD    JAKUBSKALA    === Setup started on JAKUBSKALA by Kuba-RealD ===
2012/12/7:09:06:48    Kuba-RealD    JAKUBSKALA    Launch
2012/12/7:09:07:13    Kuba-RealD    JAKUBSKALA    Inventorui== Parameter: Prereq_1 SetupMode:1 InstallState:1 InstallAction:0 Message:
2012/12/7:09:07:14    Kuba-RealD    JAKUBSKALA    Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2012/12/7:09:07:14    Kuba-RealD    JAKUBSKALA    Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2012/12/7:09:07:14    Kuba-RealD    JAKUBSKALA    Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message:
2012/12/7:09:07:19    Kuba-RealD    JAKUBSKALA    PageOpen    LaunchDialog
2012/12/7:09:07:28    Kuba-RealD    JAKUBSKALA    PageOpen    LicenseDialog
2012/12/7:09:07:30    Kuba-RealD    JAKUBSKALA    PageOpen    LaunchDialog
2012/12/7:09:07:33    Kuba-RealD    JAKUBSKALA    Inventorui== Parameter: Prereq_13 SetupMode:4 InstallState:2 InstallAction:11 Message:
2012/12/7:09:07:33    Kuba-RealD    JAKUBSKALA    Inventorui== Parameter: Prereq_14 SetupMode:4 InstallState:2 InstallAction:11 Message:
2012/12/7:09:07:38    Kuba-RealD    JAKUBSKALA    Vytváříte 64bitové rozmístění pro produkt Autodesk Inventor 2012. Chcete-li vytvořit 32bitové rozmístění pro produkt Autodesk Inventor 2012, vložte disk 32bitové verze nebo si stáhněte instalační program 32bitové verze produktu Autodesk Inventor 2012. 2012/12/7:09:07:45    Kuba-RealD    JAKUBSKALA    PageOpen    BeginDeploymentDialog
2012/12/7:09:07:47    Kuba-RealD    JAKUBSKALA    PageOpen    LaunchDialog
2012/12/7:09:07:50    Kuba-RealD    JAKUBSKALA    PageOpen    LicenseDialog
2012/12/7:09:07:54    Kuba-RealD    JAKUBSKALA    PageOpen    ProductSelectionDialog2
2012/12/7:09:08:06    Kuba-RealD    JAKUBSKALA    PageOpen    LicenseDialog
2012/12/7:09:08:08    Kuba-RealD    JAKUBSKALA    PageOpen    LaunchDialog
2012/12/7:09:08:23    Kuba-RealD    JAKUBSKALA    PageOpen    LicenseDialog
2012/12/7:09:08:27    Kuba-RealD    JAKUBSKALA    PageOpen    ProductInfoDialog
2012/12/7:09:08:48    Kuba-RealD    JAKUBSKALA    PageOpen    InventorFlavorSelectionDialog
2012/12/7:09:08:48    Kuba-RealD    JAKUBSKALA    Inventorui==DefaultLanguage:    cs-cz
2012/12/7:09:08:48    Kuba-RealD    JAKUBSKALA    Inventorui==InstallName:    INVENTOR
2012/12/7:09:08:48    Kuba-RealD    JAKUBSKALA    Inventorui==ProductName:    Autodesk Inventor 2012
2012/12/7:09:08:48    Kuba-RealD    JAKUBSKALA    Inventorui==DisplayName:    Autodesk® Inventor® 2012
2012/12/7:09:08:48    Kuba-RealD    JAKUBSKALA    Inventorui==DeploymentName:
2012/12/7:09:08:48    Kuba-RealD    JAKUBSKALA    Inventorui==SetupTitle:    Autodesk Inventor 2012
2012/12/7:09:08:48    Kuba-RealD    JAKUBSKALA    Inventorui==ConfigTransform:
2012/12/7:09:08:48    Kuba-RealD    JAKUBSKALA    Inventorui==ExeParams:
2012/12/7:09:08:48    Kuba-RealD    JAKUBSKALA    Inventorui==ProductCode:    {7F4DD591-1664-0409-0000-7107D70F3DB4}
2012/12/7:09:08:48    Kuba-RealD    JAKUBSKALA    Inventorui==SupportLink:
2012/12/7:09:08:48    Kuba-RealD    JAKUBSKALA    Inventorui==InfotainmentLink:
2012/12/7:09:08:48    Kuba-RealD    JAKUBSKALA    Inventorui==MsiFileName:    inventor.msi
2012/12/7:09:08:48    Kuba-RealD    JAKUBSKALA    Inventorui==AdminImageConfigName:    AdminImagex64
2012/12/7:09:08:48    Kuba-RealD    JAKUBSKALA    Inventorui==AdminImageRoot:    AdminImage
2012/12/7:09:08:48    Kuba-RealD    JAKUBSKALA    Inventorui==GetBaseDeploymentName:
2012/12/7:09:08:48    Kuba-RealD    JAKUBSKALA    Inventorui==DeploymentLocation:
2012/12/7:09:08:48    Kuba-RealD    JAKUBSKALA    Inventorui==DocumentLink:    SetupRes\InfoLink\help_landing.html
2012/12/7:09:08:48    Kuba-RealD    JAKUBSKALA    Inventorui==InstallDeploymentShortcut:
2012/12/7:09:08:48    Kuba-RealD    JAKUBSKALA    Inventorui==ModifyDeploymentShortcut:
2012/12/7:09:08:48    Kuba-RealD    JAKUBSKALA    Inventorui==SetupLockType:    2
2012/12/7:09:08:48    Kuba-RealD    JAKUBSKALA    Inventorui==SetupNetworkType:     0
2012/12/7:09:08:48    Kuba-RealD    JAKUBSKALA    Inventorui==SystemLocale:    1029
2012/12/7:09:08:48    Kuba-RealD    JAKUBSKALA    Inventorui==EvalMsiFilePath:    C:\Users\KUBA-R~1\AppData\Local\Temp\_AI1E1A.tmp\SetupRes\eval.msi
2012/12/7:09:08:48    Kuba-RealD    JAKUBSKALA    Inventorui==EulaPath:    C:\Users\KUBA-R~1\AppData\Local\Temp\_AI1E1A.tmp\EULA
2012/12/7:09:08:48    Kuba-RealD    JAKUBSKALA    Inventorui==InstallLogPath:    C:\Users\KUBA-R~1\AppData\Local\Temp\Inventor2012Install.log
2012/12/7:09:08:48    Kuba-RealD    JAKUBSKALA    Inventorui==ConfigFile:    C:\Users\KUBA-R~1\AppData\Local\Temp\_AI1E1A.tmp\Setup.ini
2012/12/7:09:08:48    Kuba-RealD    JAKUBSKALA    Inventorui==SetupPath:    C:\Program Files (x86)\Autodesk\Autodesk_Inventor_2012_Czech_Win_64bit\
2012/12/7:09:08:48    Kuba-RealD    JAKUBSKALA    Inventorui==NetworkLogPath:
2012/12/7:09:08:48    Kuba-RealD    JAKUBSKALA    Inventorui==SourceRoot:    C:\Program Files (x86)\Autodesk\Autodesk_Inventor_2012_Czech_Win_64bit\
2012/12/7:09:08:52    Kuba-RealD    JAKUBSKALA    Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2012/12/7:09:08:52    Kuba-RealD    JAKUBSKALA    PageOpen    ProductSelectionDialog2
2012/12/7:09:09:09    Kuba-RealD    JAKUBSKALA    PageOpen    FullProgressDialog
2012/12/7:09:09:09    Kuba-RealD    JAKUBSKALA    Installing Microsoft Visual C + + 2010 Redistributable (x86): C:\Program Files (x86)\Autodesk\Autodesk_Inventor_2012_Czech_Win_64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\KUBA-R~1\AppData\Local\Temp\vcredist_x86_2010.log
2012/12/7:09:09:11    Kuba-RealD    JAKUBSKALA    Install    Microsoft Visual C + + 2010 Redistributable (x86)    Failed    Installation aborted, Result=1603
2012/12/7:09:09:12    Kuba-RealD    JAKUBSKALA    PageOpen    InstallCompleteDialog
2012/12/7:09:09:40    Kuba-RealD    JAKUBSKALA    === Setup ended ===
2012/12/7:09:21:24    Kuba-RealD    JAKUBSKALA    === Setup started on JAKUBSKALA by Kuba-RealD ===
2012/12/7:09:21:24    Kuba-RealD    JAKUBSKALA    Launch
2012/12/7:09:21:37    Kuba-RealD    JAKUBSKALA    === Setup ended ===
2012/12/7:09:21:25    Kuba-RealD    JAKUBSKALA    === Setup started on JAKUBSKALA by Kuba-RealD ===
2012/12/7:09:21:25    Kuba-RealD    JAKUBSKALA    Launch
2012/12/7:09:21:31    Kuba-RealD    JAKUBSKALA    Inventorui== Parameter: Prereq_1 SetupMode:1 InstallState:1 InstallAction:0 Message:
2012/12/7:09:21:33    Kuba-RealD    JAKUBSKALA    Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2012/12/7:09:21:33    Kuba-RealD    JAKUBSKALA    Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2012/12/7:09:21:33    Kuba-RealD    JAKUBSKALA    Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message:
2012/12/7:09:21:36    Kuba-RealD    JAKUBSKALA    PageOpen    LaunchDialog
2012/12/7:09:25:47    Kuba-RealD    JAKUBSKALA    PageOpen    LicenseDialog
2012/12/7:09:31:50    Kuba-RealD    JAKUBSKALA    PageOpen    ProductInfoDialog
2012/12/7:09:33:02    Kuba-RealD    JAKUBSKALA    PageOpen    InventorFlavorSelectionDialog
2012/12/7:09:33:02    Kuba-RealD    JAKUBSKALA    Inventorui==DefaultLanguage:    cs-cz
2012/12/7:09:33:02    Kuba-RealD    JAKUBSKALA    Inventorui==InstallName:    INVENTOR
2012/12/7:09:33:02    Kuba-RealD    JAKUBSKALA    Inventorui==ProductName:    Autodesk Inventor 2012
2012/12/7:09:33:02    Kuba-RealD    JAKUBSKALA    Inventorui==DisplayName:    Autodesk® Inventor® 2012
2012/12/7:09:33:02    Kuba-RealD    JAKUBSKALA    Inventorui==DeploymentName:
2012/12/7:09:33:02    Kuba-RealD    JAKUBSKALA    Inventorui==SetupTitle:    Autodesk Inventor 2012
2012/12/7:09:33:02    Kuba-RealD    JAKUBSKALA    Inventorui==ConfigTransform:
2012/12/7:09:33:02    Kuba-RealD    JAKUBSKALA    Inventorui==ExeParams:
2012/12/7:09:33:02    Kuba-RealD    JAKUBSKALA    Inventorui==ProductCode:    {7F4DD591-1664-0409-0000-7107D70F3DB4}
2012/12/7:09:33:02    Kuba-RealD    JAKUBSKALA    Inventorui==SupportLink:
2012/12/7:09:33:02    Kuba-RealD    JAKUBSKALA    Inventorui==InfotainmentLink:
2012/12/7:09:33:02    Kuba-RealD    JAKUBSKALA    Inventorui==MsiFileName:    inventor.msi
2012/12/7:09:33:02    Kuba-RealD    JAKUBSKALA    Inventorui==AdminImageConfigName:    AdminImagex64
2012/12/7:09:33:02    Kuba-RealD    JAKUBSKALA    Inventorui==AdminImageRoot:
2012/12/7:09:33:02    Kuba-RealD    JAKUBSKALA    Inventorui==GetBaseDeploymentName:
2012/12/7:09:33:02    Kuba-RealD    JAKUBSKALA    Inventorui==DeploymentLocation:
2012/12/7:09:33:02    Kuba-RealD    JAKUBSKALA    Inventorui==DocumentLink:    SetupRes\InfoLink\help_landing.html
2012/12/7:09:33:02    Kuba-RealD    JAKUBSKALA    Inventorui==InstallDeploymentShortcut:
2012/12/7:09:33:02    Kuba-RealD    JAKUBSKALA    Inventorui==ModifyDeploymentShortcut:
2012/12/7:09:33:02    Kuba-RealD    JAKUBSKALA    Inventorui==SetupLockType:    2
2012/12/7:09:33:02    Kuba-RealD    JAKUBSKALA    Inventorui==SetupNetworkType:     0
2012/12/7:09:33:02    Kuba-RealD    JAKUBSKALA    Inventorui==SystemLocale:    1029
2012/12/7:09:33:02    Kuba-RealD    JAKUBSKALA    Inventorui==EvalMsiFilePath:    C:\Users\KUBA-R~1\AppData\Local\Temp\_AI897A.tmp\SetupRes\eval.msi
2012/12/7:09:33:02    Kuba-RealD    JAKUBSKALA    Inventorui==EulaPath:    C:\Users\KUBA-R~1\AppData\Local\Temp\_AI897A.tmp\EULA
2012/12/7:09:33:02    Kuba-RealD    JAKUBSKALA    Inventorui==InstallLogPath:    C:\Users\KUBA-R~1\AppData\Local\Temp\Inventor2012Install.log
2012/12/7:09:33:02    Kuba-RealD    JAKUBSKALA    Inventorui==ConfigFile:    C:\Users\KUBA-R~1\AppData\Local\Temp\_AI897A.tmp\setup.ini
2012/12/7:09:33:02    Kuba-RealD    JAKUBSKALA    Inventorui==SetupPath:    C:\Autodesk\Autodesk_Inventor_2012_Czech_Win_64bit\
2012/12/7:09:33:02    Kuba-RealD    JAKUBSKALA    Inventorui==NetworkLogPath:
2012/12/7:09:33:02    Kuba-RealD    JAKUBSKALA    Inventorui==SourceRoot:    C:\Autodesk\Autodesk_Inventor_2012_Czech_Win_64bit\
2012/12/7:09:33:04    Kuba-RealD    JAKUBSKALA    Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2012/12/7:09:33:04    Kuba-RealD    JAKUBSKALA    PageOpen    ProductSelectionDialog2
2012/12/7:09:33:11    Kuba-RealD    JAKUBSKALA    PageOpen    FullProgressDialog
2012/12/7:09:33:11    Kuba-RealD    JAKUBSKALA    Installing Microsoft Visual C + + 2010 Redistributable (x86): C:\Autodesk\Autodesk_Inventor_2012_Czech_Win_64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\KUBA-R~1\AppData\Local\Temp\vcredist_x86_2010.log
2012/12/7:09:33:13    Kuba-RealD    JAKUBSKALA    Install    Microsoft Visual C + + 2010 Redistributable (x86)    Failed    Installation aborted, Result=1603
TravisNave
Message 5 of 6 (353 Views)
12-27-2012 09:11 AM in reply to: s.reald
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
Good Luck!
Member
s.reald
Message 6 of 6 (340 Views)
12-27-2012 11:12 AM in reply to: TravisNave
Yep, the problem was solved. Thank you very much for your time and advice. Have a nice day and successful happy new year
