To whom it may concern
As I have changed my computer with Windows 7, I tried to install a stand-along autodesk inventor suite 2008, but it seems there is a compatability issue with Windows 7. Do you have any idea if it is true and what solution can you provide on the base of keeping the current version?
thank you
Autodesk 2008 products are not supported on Windows 7. That much is true.
You could search the forum for answer, but I would recommend running setup as Windows XP compatibility as administrator. Then run the program itself as XP compatibility after installation.
