Installation & Licensing
AUTODESK INVENTOR PROFESSIONAL 2015 FOR 64-BITS
3 REPLIES 3
ivana.newby
1872 Views, 3 Replies
AFTER INSTALLING WINDOWS 7 SERVICE PACK 1 ON MY MACBOOK, AUTODESK INVENTOR PROFESSIONAL 2015 WILL NOT INSTALL ON MY COMPUTER. I'VE UPDATED EVERYTHING SUCCESSFULLY, I JUST GET RED X'S AND "FAILURE TO INSTALL" AFTER I CLICK INSTALL. NOT SURE WHAT TO DO AT THIS POINT.
3 REPLIES 3
dembkod
in reply to: ivana.newby
ivana.newby
Hello. There is likely a log file in your temp directory with the program name in it.
1.)  Click the Windows Start button
2.)  In the run box type %TEMP% and press Enter
3.)  Search the folder for the log file
4.)  Open in notepad
5.)  Click Edit > Find
6.)  Search on the word “failed”
7.)  Locate any failures and look for references to C++ or NET- uninstall the referenced versions
8.)  Reinstall
In some cases, this does not help. If you have a full download of the installer files to your machine (Browser Download or Download Now), you can open the setup INI file in the install directory.
1.)  Open Setup.ini
2.)  Click Edit > Replace
3.)  Replace PREREQ with #PREREQ
4.)  Click “Replace All”
5.)  Search for PREREQ and change to #PREREQ
6.)  Save the file
7.)  Run the install
Thank you for taking part in our community!
David Dembkoski
ivana.newby
in reply to: dembkod
you are the best!!!! I appreciate this!
ivana.newby
you're the man!!
Administrator Productivity
