AFTER INSTALLING WINDOWS 7 SERVICE PACK 1 ON MY MACBOOK, AUTODESK INVENTOR PROFESSIONAL 2015 WILL NOT INSTALL ON MY COMPUTER. I'VE UPDATED EVERYTHING SUCCESSFULLY, I JUST GET RED X'S AND "FAILURE TO INSTALL" AFTER I CLICK INSTALL. NOT SURE WHAT TO DO AT THIS POINT.
Solved by dembkod. Go to Solution.
Hello. There is likely a log file in your temp directory with the program name in it.
1.) Click the Windows Start button
2.) In the run box type %TEMP% and press Enter
3.) Search the folder for the log file
4.) Open in notepad
5.) Click Edit > Find
6.) Search on the word “failed”
7.) Locate any failures and look for references to C++ or NET- uninstall the referenced versions
8.) Reinstall
In some cases, this does not help. If you have a full download of the installer files to your machine (Browser Download or Download Now), you can open the setup INI file in the install directory.
1.) Open Setup.ini
2.) Click Edit > Replace
3.) Replace PREREQ with #PREREQ
4.) Click “Replace All”
5.) Search for PREREQ and change to #PREREQ
6.) Save the file
7.) Run the install
Thank you for taking part in our community!
