Installation & Licensing
Autodesk Inventor Installation Error
13 REPLIES 13
Message 1 of 14
1675 Views, 13 Replies
I tried to install Inventer.  The screen showed serial number details, but when I click on Install Now, it does not respond.  On the left bottom of screen, it showed "Error on page".  What do I need to do?  Thanks.
13 REPLIES 13
Message 2 of 14
philip.s
Hi Greg,
I'm assuming that you are referring to the Install Now feature from within the Education Community? As this method can present errors depending on your personal computer settings (firewall, antivirus, connection speed etc.) I'd recommend utilizing an alternative download method (Download Now or Browser Download) as a workaround.
Message 3 of 14
in reply to: philip.s
Thanks Philip. I did try both Download Now and Browser Download, still had the same problem. Earlier, when I first downloaded, my computer did not have enough space. So I had to halt the process and clean up for more spaces. I guess maybe it recognizes my computer and will not allow me to download again? Anyway to get around this?
Message 4 of 14
reginald_c
HI
I have been getting the same error for 5 days on two diffrent computers I have tryed everything
Any help out there?  I am running internetExplorer8 on Win xp
Message 5 of 14
philip.s
Hi Greg,
I've provided the following 48hr timed direct download links based on your download history from the Education Community. Please let me know if this resolves the issue, or reply with error specifics.
Click here for Autodesk Inventor 2013 32BIT
Click here for Autodesk Inventor 2013 64BIT
Click here for Autodesk Inventor Professional 2012 32BIT
Message 6 of 14
Thanks Philip. The link worked well, and allowed me to download the files. But I have a new problem. At the end of installation, it showed all products failed to install. I attached the Installation log file. Could you take a look? Thanks. Greg
Message 7 of 14
philip.s
It doesn't look like anything attached. Do you mind trying again Greg?
Message 8 of 14
Philip, Here is the log file. If you still don't see it, let me know. Thanks. Greg
Message 9 of 14
philip.s
Still not showing up Greg.... How are you attaching the file? Do you just want to copy and paste the last few lines into a reply?
Message 10 of 14
Here is what I got, thanks. 2012/9/30:10:39:48 nijimd NIJIMDXP === Setup started on NIJIMDXP by nijimd === 2012/9/30:10:39:48 nijimd NIJIMDXP Launch 2012/9/30:10:39:48 nijimd NIJIMDXP CommandLine /url " http://studentsdownload.autodesk.com/SWDLDDLM/2013/INVNTOR/WI/Autodesk_Inventor_2013_English_Win_32b..." /SN xxx-xxxxxxxx /PK 797E1 /student /skipEULA /akamai /auth /sid 2012/9/30:10:44:24 nijimd NIJIMDXP === Setup ended === 2012/9/30:12:40:46 nijimd NIJIMDXP === Setup started on NIJIMDXP by nijimd === 2012/9/30:12:40:46 nijimd NIJIMDXP Launch 2012/9/30:12:40:46 nijimd NIJIMDXP CommandLine 2012/9/30:12:41:07 nijimd NIJIMDXP === Setup ended === 2012/9/30:12:40:51 nijimd NIJIMDXP === Setup started on NIJIMDXP by nijimd === 2012/9/30:12:40:51 nijimd NIJIMDXP Launch 2012/9/30:12:41:08 nijimd NIJIMDXP === Setup ended === 2012/9/30:12:46:27 nijimd NIJIMDXP === Setup started on NIJIMDXP by nijimd === 2012/9/30:12:46:27 nijimd NIJIMDXP Launch 2012/9/30:12:46:27 nijimd NIJIMDXP CommandLine 2012/9/30:12:47:21 nijimd NIJIMDXP === Setup ended === 2012/9/30:12:46:32 nijimd NIJIMDXP === Setup started on NIJIMDXP by nijimd === 2012/9/30:12:46:32 nijimd NIJIMDXP Launch 2012/9/30:12:47:22 nijimd NIJIMDXP === Setup ended === 2012/9/30:13:00:27 nijimd NIJIMDXP === Setup started on NIJIMDXP by nijimd === 2012/9/30:13:00:27 nijimd NIJIMDXP Launch 2012/9/30:13:00:27 nijimd NIJIMDXP CommandLine 2012/9/30:13:04:22 nijimd NIJIMDXP === Setup ended === 2012/9/30:13:00:34 nijimd NIJIMDXP === Setup started on NIJIMDXP by nijimd === 2012/9/30:13:00:34 nijimd NIJIMDXP Launch 2012/9/30:13:04:23 nijimd NIJIMDXP === Setup ended === 2012/9/30:13:14:31 nijimd NIJIMDXP === Setup started on NIJIMDXP by nijimd === 2012/9/30:13:14:31 nijimd NIJIMDXP Launch 2012/9/30:13:14:31 nijimd NIJIMDXP CommandLine 2012/9/30:13:14:56 nijimd NIJIMDXP === Setup ended === 2012/9/30:13:14:41 nijimd NIJIMDXP === Setup started on NIJIMDXP by nijimd === 2012/9/30:13:14:41 nijimd NIJIMDXP Launch 2012/9/30:13:14:57 nijimd NIJIMDXP === Setup ended === 2012/9/30:13:20:57 nijimd NIJIMDXP === Setup started on NIJIMDXP by nijimd === 2012/9/30:13:20:57 nijimd NIJIMDXP Launch 2012/9/30:13:20:57 nijimd NIJIMDXP CommandLine 2012/9/30:13:21:08 nijimd NIJIMDXP === Setup ended === 2012/9/30:13:21:04 nijimd NIJIMDXP === Setup started on NIJIMDXP by nijimd === 2012/9/30:13:21:04 nijimd NIJIMDXP Launch 2012/9/30:13:21:09 nijimd NIJIMDXP === Setup ended === 2012/9/30:13:22:39 nijimd NIJIMDXP === Setup started on NIJIMDXP by nijimd === 2012/9/30:13:22:39 nijimd NIJIMDXP Launch 2012/9/30:13:22:39 nijimd NIJIMDXP CommandLine 2012/9/30:13:22:48 nijimd NIJIMDXP === Setup ended === 2012/9/30:13:22:46 nijimd NIJIMDXP === Setup started on NIJIMDXP by nijimd === 2012/9/30:13:22:46 nijimd NIJIMDXP Launch 2012/9/30:13:22:49 nijimd NIJIMDXP === Setup ended === 2012/9/30:20:52:16 nijimd NIJIMDXP === Setup started on NIJIMDXP by nijimd === 2012/9/30:20:52:16 nijimd NIJIMDXP Launch 2012/9/30:20:52:16 nijimd NIJIMDXP CommandLine 2012/9/30:20:52:43 nijimd NIJIMDXP === Setup ended === 2012/9/30:20:52:26 nijimd NIJIMDXP === Setup started on NIJIMDXP by nijimd === 2012/9/30:20:52:26 nijimd NIJIMDXP Launch 2012/9/30:20:52:44 nijimd NIJIMDXP === Setup ended === 2012/10/3:08:49:03 nijimd NIJIMDXP === Setup started on NIJIMDXP by nijimd === 2012/10/3:08:49:03 nijimd NIJIMDXP Launch 2012/10/3:08:49:14 nijimd NIJIMDXP === Setup ended === 2012/10/3:08:49:10 nijimd NIJIMDXP === Setup started on NIJIMDXP by nijimd === 2012/10/3:08:49:10 nijimd NIJIMDXP Launch 2012/10/3:08:49:13 nijimd NIJIMDXP Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message: 2012/10/3:08:49:13 nijimd NIJIMDXP Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message: 2012/10/3:08:49:13 nijimd NIJIMDXP Inventorui== Parameter: Prereq_4 SetupMode:1 InstallState:2 InstallAction:0 Message: 2012/10/3:08:49:13 nijimd NIJIMDXP Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message: 2012/10/3:08:49:14 nijimd NIJIMDXP PageOpen LaunchDialog 2012/10/3:08:49:20 nijimd NIJIMDXP PageOpen LicenseDialog 2012/10/3:08:49:25 nijimd NIJIMDXP PageOpen ProductInfoDialog 2012/10/3:08:50:32 nijimd NIJIMDXP PageOpen InventorFlavorSelectionDialog 2012/10/3:08:50:32 nijimd NIJIMDXP Inventorui==DefaultLanguage: en-us 2012/10/3:08:50:32 nijimd NIJIMDXP Inventorui==InstallName: INVENTOR 2012/10/3:08:50:32 nijimd NIJIMDXP Inventorui==ProductName: Autodesk Inventor 2013 2012/10/3:08:50:32 nijimd NIJIMDXP Inventorui==DisplayName: Autodesk? Inventor? 2013 2012/10/3:08:50:32 nijimd NIJIMDXP Inventorui==DeploymentName: 2012/10/3:08:50:32 nijimd NIJIMDXP Inventorui==SetupTitle: Autodesk Inventor 2013 2012/10/3:08:50:32 nijimd NIJIMDXP Inventorui==ConfigTransform: 2012/10/3:08:50:32 nijimd NIJIMDXP Inventorui==ExeParams: 2012/10/3:08:50:32 nijimd NIJIMDXP Inventorui==ProductCode: {7F4DD591-1732-0001-0000-7107D70F3DB4} 2012/10/3:08:50:32 nijimd NIJIMDXP Inventorui==SupportLink: 2012/10/3:08:50:32 nijimd NIJIMDXP Inventorui==InfotainmentLink: 2012/10/3:08:50:32 nijimd NIJIMDXP Inventorui==MsiFileName: inventor.msi 2012/10/3:08:50:32 nijimd NIJIMDXP Inventorui==AdminImageConfigName: AdminImagex86 2012/10/3:08:50:32 nijimd NIJIMDXP Inventorui==AdminImageRoot: 2012/10/3:08:50:32 nijimd NIJIMDXP Inventorui==GetBaseDeploymentName: 2012/10/3:08:50:32 nijimd NIJIMDXP Inventorui==DeploymentLocation: 2012/10/3:08:50:32 nijimd NIJIMDXP Inventorui==DocumentLink: http://autodesk.com/wikihelp-inventor-install-2013-enu 2012/10/3:08:50:32 nijimd NIJIMDXP Inventorui==InstallDeploymentShortcut: 2012/10/3:08:50:32 nijimd NIJIMDXP Inventorui==ModifyDeploymentShortcut: 2012/10/3:08:50:32 nijimd NIJIMDXP Inventorui==SetupLockType: 2 2012/10/3:08:50:32 nijimd NIJIMDXP Inventorui==SetupNetworkType: 1 2012/10/3:08:50:32 nijimd NIJIMDXP Inventorui==SystemLocale: 1033 2012/10/3:08:50:32 nijimd NIJIMDXP Inventorui==EvalMsiFilePath: C:\DOCUME~1\nijimd\LOCALS~1\Temp\_AI14.tmp\SetupRes\eval.msi 2012/10/3:08:50:32 nijimd NIJIMDXP Inventorui==EulaPath: C:\DOCUME~1\nijimd\LOCALS~1\Temp\_AI14.tmp\EULA 2012/10/3:08:50:32 nijimd NIJIMDXP Inventorui==InstallLogPath: C:\DOCUME~1\nijimd\LOCALS~1\Temp\Inventor2013Install.log 2012/10/3:08:50:32 nijimd NIJIMDXP Inventorui==ConfigFile: C:\DOCUME~1\nijimd\LOCALS~1\Temp\_AI14.tmp\Setup.ini 2012/10/3:08:50:32 nijimd NIJIMDXP Inventorui==SetupPath: C:\DOCUME~1\nijimd\LOCALS~1\Temp\_AI14.tmp\ 2012/10/3:08:50:32 nijimd NIJIMDXP Inventorui==NetworkLogPath: 2012/10/3:08:50:32 nijimd NIJIMDXP Inventorui==SourceRoot: C:\Autodesk\Autodesk_Inventor_2013_English_Win_32bit\ 2012/10/3:08:50:37 nijimd NIJIMDXP Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA 2012/10/3:08:50:37 nijimd NIJIMDXP PageOpen ProductSelectionDialog2 2012/10/3:08:51:18 nijimd NIJIMDXP PageOpen FullProgressDialog 2012/10/3:08:51:18 nijimd NIJIMDXP Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Autodesk\Autodesk_Inventor_2013_English_Win_32bit\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart 2012/10/3:08:51:25 nijimd NIJIMDXP Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded 2012/10/3:08:51:25 nijimd NIJIMDXP Uninstall {8D20B4D7-3422-4099-9332-39F27E617A6F} Failed 2012/10/3:08:51:25 nijimd NIJIMDXP Uninstall {55D9E026-DCB0-46FF-B60A-68B972228CF6} Failed 2012/10/3:08:51:25 nijimd NIJIMDXP Uninstall {450063AA-643B-417C-8CF5-405BA3F4EF40} Failed 2012/10/3:08:51:25 nijimd NIJIMDXP Uninstall {02A00C13-555A-4B8A-B53B-1D02FFF5EEAF} Failed 2012/10/3:08:51:25 nijimd NIJIMDXP Uninstall {106EC844-9F5E-4B72-BB3B-1E47D274A944} Failed 2012/10/3:08:51:25 nijimd NIJIMDXP Uninstall {FACF203E-0F4D-489A-B80C-D185253C8FCB} Failed 2012/10/3:08:51:25 nijimd NIJIMDXP Uninstall {1A2948E0-9445-42BE-9D01-472952F2657F} Failed 2012/10/3:08:51:25 nijimd NIJIMDXP Uninstall {9A346205-EA92-4406-B1AB-50379DA3F057} Failed 2012/10/3:08:51:25 nijimd NIJIMDXP Uninstall {C46C3C20-039E-4D7C-869F-9C0C05D65C06} Failed 2012/10/3:08:51:25 nijimd NIJIMDXP Uninstall {577D60CB-0D5E-48D1-8850-84098AD34804} Failed 2012/10/3:08:51:25 nijimd NIJIMDXP Uninstall {0576A3D0-0000-0409-0000-491C453655D7} Failed 2012/10/3:08:51:25 nijimd NIJIMDXP Uninstall {7BDBD5BE-B02E-4FB4-8735-B9AF4FCA838F} Failed 2012/10/3:08:51:25 nijimd NIJIMDXP Uninstall {1ECD6EC8-7BB2-4CD5-A384-BAA371BC4D21} Failed 2012/10/3:08:51:25 nijimd NIJIMDXP Uninstall {4780F600-0000-0409-0000-114715ACF216} Failed 2012/10/3:08:51:25 nijimd NIJIMDXP Installing Autodesk? Design Review 2013: INSTALLDIR="C:\Program Files\Autodesk\Autodesk Design Review 2013\" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Inventor_2013_English_Win_32bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2012/10/3:08:52:02 nijimd NIJIMDXP Install Autodesk? Design Review 2013 Succeeded 2012/10/3:08:52:02 nijimd NIJIMDXP Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\Autodesk_Inventor_2013_English_Win_32bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\WINDOWS\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\DOCUME~1\nijimd\LOCALS~1\Temp\vcredist_x86_2005.log"" " 2012/10/3:08:53:56 nijimd NIJIMDXP Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Succeeded 2012/10/3:08:53:56 nijimd NIJIMDXP Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Autodesk\Autodesk_Inventor_2013_English_Win_32bit\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q 2012/10/3:08:54:02 nijimd NIJIMDXP Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded 2012/10/3:08:54:02 nijimd NIJIMDXP Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Inventor_2013_English_Win_32bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2012/10/3:08:54:25 nijimd NIJIMDXP Install Autodesk Material Library 2013 Succeeded 2012/10/3:08:54:25 nijimd NIJIMDXP Installing Autodesk Material Library 2013 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Inventor_2013_English_Win_32bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2012/10/3:08:54:43 nijimd NIJIMDXP Install Autodesk Material Library 2013 - Base Image Library Succeeded 2012/10/3:08:54:43 nijimd NIJIMDXP Installing VBA Runtime: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Inventor_2013_English_Win_32bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2012/10/3:08:54:51 nijimd NIJIMDXP Install VBA Runtime Succeeded 2012/10/3:08:54:51 nijimd NIJIMDXP Installing DirectX? Runtime: C:\Autodesk\Autodesk_Inventor_2013_English_Win_32bit\3rdParty\DirectX\DXSETUP.exe /silent 2012/10/3:08:54:55 nijimd NIJIMDXP Install DirectX? Runtime Succeeded 2012/10/3:08:54:55 nijimd NIJIMDXP Installing Web Services Enhancements (WSE) 3.0 for Microsoft .NET: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Inventor_2013_English_Win_32bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2012/10/3:08:55:01 nijimd NIJIMDXP Install Web Services Enhancements (WSE) 3.0 for Microsoft .NET Succeeded 2012/10/3:08:55:01 nijimd NIJIMDXP Installing Autodesk Material Library 2013 - Low Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Inventor_2013_English_Win_32bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2012/10/3:08:55:30 nijimd NIJIMDXP Install Autodesk Material Library 2013 - Low Image Library Succeeded 2012/10/3:08:55:30 nijimd NIJIMDXP Installing Quick Uninstall Tool for Autodesk? Inventor? 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Inventor_2013_English_Win_32bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2012/10/3:08:55:34 nijimd NIJIMDXP Install Quick Uninstall Tool for Autodesk? Inventor? 2013 Succeeded 2012/10/3:08:55:34 nijimd NIJIMDXP Installing DWG TrueView: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Inventor_2013_English_Win_32bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2012/10/3:08:56:49 nijimd NIJIMDXP Install DWG TrueView Succeeded 2012/10/3:08:56:49 nijimd NIJIMDXP Installing Autodesk Cloud sync: ADLANGUAGE=en-us ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Inventor_2013_English_Win_32bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2012/10/3:08:56:58 nijimd NIJIMDXP Install Autodesk Cloud sync Succeeded 2012/10/3:08:56:58 nijimd NIJIMDXP Installing Autodesk? Inventor? 2013: TRANSFORMS="C:\Autodesk\Autodesk_Inventor_2013_English_Win_32bit\x86\en-us\Inventor\inventor.mst;C:\DOCUME~1\nijimd\LOCALS~1\Temp\_AI14.tmp\x86\inventor\inventor-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Inventor_2013_English_Win_32bit\" INSTALLDIR="C:\Program Files\Autodesk\Inventor 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2012/10/3:09:01:15 nijimd NIJIMDXP Install Autodesk? Inventor? 2013 Failed Installation aborted, Result=1603 2012/10/3:09:01:18 nijimd NIJIMDXP Rollback Autodesk Cloud sync Succeeded 2012/10/3:09:01:38 nijimd NIJIMDXP Rollback Autodesk Material Library 2013 - Low Image Library Succeeded 2012/10/3:09:01:38 nijimd NIJIMDXP Rollback DirectX? Runtime Failed Failure is ignored, Result=1619 2012/10/3:09:02:02 nijimd NIJIMDXP Rollback Autodesk Material Library 2013 - Base Image Library Succeeded 2012/10/3:09:02:40 nijimd NIJIMDXP Rollback Autodesk Material Library 2013 Succeeded 2012/10/3:09:02:55 nijimd NIJIMDXP Rollback Autodesk? Design Review 2013 Succeeded
Edited by
Discussion_Admin
Message 11 of 14
philip.s
There may be a newer version of the Microsoft Visual C++ 2010 Redistributable Package installed on your computer which is causing the install failure.
A typical workaround is to uinstall Microsoft Visual C++ 2010 Redistributable (x86) via the Control Panel (add / remove programs), reinstall the software, and then install the latest version of Microsoft Visual C++ 2010 Redistributable (x86) from Microsoft (linked here).
For additional 1603 error causes and corresponding solutions, click here.
Please accept as a solution if this fully resolves the issue, or reply with specifics if the problem still persists.
Message 12 of 14
It is working now.  Thanks so much for the help.
Message 13 of 14
reginald_c
HI Can I also get the link for sketch pad ? Also is it better to reply to e-mail or the online board Reggie
Message 14 of 14
philip.s
in reply to: reginald_c
Hi Reggie,
Please make sure you are asking a question relevant to the specific board, so that the information stays relevant for someone experiencing the same issue. Current version download links can be found from Autodesk.com -> Download Free Trials -> and then selecting the product you need (in your case SketchBook Pro).
Administrator Productivity
