Installation & Licensing
Autodesk Inventor Install
3 REPLIES 3
192 Views, 3 Replies
I have a Macbook Pro 13.3in from early 2011. I have done the bootcamp so I now have Windows Ultimate 64-bit and OSX Lion on the harddrive. I downloaded Inventor Professional with a student license and it will not let me install the programs. It will begin to start and then immediately fail. I have installed .net 4.0 as well. Any help would be greatly appriciated. Thanks
3 REPLIES 3
TravisNave
You'll have to attach your installation log files as a means to find out why it is failing.  Generally though it is due to a prerequisite file like .NET Framework or Visual C++.  The file will be found in your %TEMP% folder.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
in reply to: TravisNave
I figured it out. I guess my computer already had a newer version of the C++ 2010 version. I uninstalled that and then started the installation and it worked without a problem.
TravisNave
You did the correct thing.  Now if you could just convince everyone else that is having that problem to do what you did, this board would have a lot less threads!  Good job!
Autodesk Forums:
Administrator Productivity
