Upon trying to install the student version of inventor, the program failed to install, I do not know which program is causing the issue. Here is a copy of the installation log file:
2014/4/8:20:25:12 Salman SALMAN-PC === Setup started on SALMAN-PC by Salman ===
2014/4/8:20:25:12 Salman SALMAN-PC Launch
2014/4/8:20:25:12 Salman SALMAN-PC CommandLine /url "http://trial.autodesk.com/SWDLDDLM/2013/INVNTOR/WI/Autodesk_Inventor_2013_English_Win_64bit_wi_en-US... /SN 900-36446863 /PK 797E1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/8:20:28:09 Salman SALMAN-PC === Setup ended ===
2014/4/8:20:25:16 Salman SALMAN-PC === Setup started on SALMAN-PC by Salman ===
2014/4/8:20:25:16 Salman SALMAN-PC Launch
2014/4/8:20:26:16 Salman SALMAN-PC Download Play SETUP_CONFIG http://trial.autodesk.com/SWDLDDLM/2013/INVNTOR/WI/{7A8FD266-4E05-4485-8B20-473DDFB57937}/SETUP_x64....
2014/4/8:20:28:09 Salman SALMAN-PC Download Complete SETUP_CONFIG http://trial.autodesk.com/SWDLDDLM/2013/INVNTOR/WI/{7A8FD266-4E05-4485-8B20-473DDFB57937}/SETUP_x64....
2014/4/8:20:28:09 Salman SALMAN-PC PageOpen LaunchDialog
2014/4/8:21:25:50 Salman SALMAN-PC Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2014/4/8:21:25:50 Salman SALMAN-PC Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2014/4/8:21:26:10 Salman SALMAN-PC PageOpen LicenseDialog
2014/4/8:21:26:11 Salman SALMAN-PC PageOpen ProductInfoDialog
2014/4/8:21:26:11 Salman SALMAN-PC PageOpen InventorFlavorSelectionDialog
2014/4/8:21:26:11 Salman SALMAN-PC Inventorui==DefaultLanguage: en-us
2014/4/8:21:26:11 Salman SALMAN-PC Inventorui==InstallName: INVENTOR
2014/4/8:21:26:11 Salman SALMAN-PC Inventorui==ProductName: Autodesk Inventor 2013
2014/4/8:21:26:11 Salman SALMAN-PC Inventorui==DisplayName: Autodesk® Inventor® 2013
2014/4/8:21:26:11 Salman SALMAN-PC Inventorui==DeploymentName:
2014/4/8:21:26:11 Salman SALMAN-PC Inventorui==SetupTitle: Autodesk Inventor 2013
2014/4/8:21:26:11 Salman SALMAN-PC Inventorui==ConfigTransform:
2014/4/8:21:26:11 Salman SALMAN-PC Inventorui==ExeParams:
2014/4/8:21:26:11 Salman SALMAN-PC Inventorui==ProductCode: {7F4DD591-1764-0001-0000-7107D70F3DB4}
2014/4/8:21:26:11 Salman SALMAN-PC Inventorui==SupportLink:
2014/4/8:21:26:11 Salman SALMAN-PC Inventorui==InfotainmentLink:
2014/4/8:21:26:11 Salman SALMAN-PC Inventorui==MsiFileName: inventor.msi
2014/4/8:21:26:11 Salman SALMAN-PC Inventorui==AdminImageConfigName: AdminImagex64
2014/4/8:21:26:11 Salman SALMAN-PC Inventorui==AdminImageRoot:
2014/4/8:21:26:11 Salman SALMAN-PC Inventorui==GetBaseDeploymentName:
2014/4/8:21:26:11 Salman SALMAN-PC Inventorui==DeploymentLocation:
2014/4/8:21:26:11 Salman SALMAN-PC Inventorui==DocumentLink: http://autodesk.com/wikihelp-inventor-install-2013-enu
2014/4/8:21:26:11 Salman SALMAN-PC Inventorui==InstallDeploymentShortcut:
2014/4/8:21:26:11 Salman SALMAN-PC Inventorui==ModifyDeploymentShortcut:
2014/4/8:21:26:11 Salman SALMAN-PC Inventorui==SetupLockType: 2
2014/4/8:21:26:11 Salman SALMAN-PC Inventorui==SetupNetworkType: 1
2014/4/8:21:26:11 Salman SALMAN-PC Inventorui==SystemLocale: 1033
2014/4/8:21:26:11 Salman SALMAN-PC Inventorui==EvalMsiFilePath: C:\Users\Salman\AppData\Local\Temp\_AIEAED.tmp\SetupRes\eval.msi
2014/4/8:21:26:11 Salman SALMAN-PC Inventorui==EulaPath: C:\Autodesk\WI\Autodesk Inventor 2013\EULA
2014/4/8:21:26:11 Salman SALMAN-PC Inventorui==InstallLogPath: C:\Users\Salman\AppData\Local\Temp\Inventor2013Install.log
2014/4/8:21:26:11 Salman SALMAN-PC Inventorui==ConfigFile: C:\Users\Salman\AppData\Local\Temp\_AIEAED.tmp\Setup.ini
2014/4/8:21:26:11 Salman SALMAN-PC Inventorui==SetupPath: C:\Users\Salman\AppData\Local\Temp\_AIEAED.tmp\
2014/4/8:21:26:11 Salman SALMAN-PC Inventorui==NetworkLogPath:
2014/4/8:21:26:11 Salman SALMAN-PC Inventorui==SourceRoot: C:\Autodesk\WI\Autodesk Inventor 2013
2014/4/8:21:26:30 Salman SALMAN-PC Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2014/4/8:21:26:30 Salman SALMAN-PC PageOpen ProductSelectionDialog2
2014/4/8:21:27:06 Salman SALMAN-PC PageOpen FullProgressDialog
2014/4/8:21:27:08 Salman SALMAN-PC Download Play VCREDIST2010SP1X64 http://trial.autodesk.com/SWDLDDLM/2013/INVNTOR/WI/{7A8FD266-4E05-4485-8B20-473DDFB57937}/VCREDIST20...
2014/4/8:21:27:12 Salman SALMAN-PC Download Complete VCREDIST2010SP1X64 http://trial.autodesk.com/SWDLDDLM/2013/INVNTOR/WI/{7A8FD266-4E05-4485-8B20-473DDFB57937}/VCREDIST20...
2014/4/8:21:27:12 Salman SALMAN-PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Autodesk\WI\Autodesk Inventor 2013\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart
2014/4/8:21:27:27 Salman SALMAN-PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2014/4/8:21:27:27 Salman SALMAN-PC Download Play VCREDIST2010SP1X86 http://trial.autodesk.com/SWDLDDLM/2013/INVNTOR/WI/{7A8FD266-4E05-4485-8B20-473DDFB57937}/VCREDIST20...
2014/4/8:21:27:34 Salman SALMAN-PC Download Complete VCREDIST2010SP1X86 http://trial.autodesk.com/SWDLDDLM/2013/INVNTOR/WI/{7A8FD266-4E05-4485-8B20-473DDFB57937}/VCREDIST20...
2014/4/8:21:27:34 Salman SALMAN-PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Autodesk\WI\Autodesk Inventor 2013\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart
2014/4/8:21:27:44 Salman SALMAN-PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2014/4/8:21:27:44 Salman SALMAN-PC Uninstall {8D20B4D7-3422-4099-9332-39F27E617A6F} Failed
2014/4/8:21:27:44 Salman SALMAN-PC Uninstall {55D9E026-DCB0-46FF-B60A-68B972228CF6} Failed
2014/4/8:21:27:44 Salman SALMAN-PC Uninstall {450063AA-643B-417C-8CF5-405BA3F4EF40} Failed
2014/4/8:21:27:44 Salman SALMAN-PC Uninstall {02A00C13-555A-4B8A-B53B-1D02FFF5EEAF} Failed
2014/4/8:21:27:44 Salman SALMAN-PC Uninstall {106EC844-9F5E-4B72-BB3B-1E47D274A944} Failed
2014/4/8:21:27:44 Salman SALMAN-PC Uninstall {FACF203E-0F4D-489A-B80C-D185253C8FCB} Failed
2014/4/8:21:27:44 Salman SALMAN-PC Uninstall {1A2948E0-9445-42BE-9D01-472952F2657F} Failed
2014/4/8:21:27:44 Salman SALMAN-PC Uninstall {9A346205-EA92-4406-B1AB-50379DA3F057} Failed
2014/4/8:21:27:44 Salman SALMAN-PC Uninstall {C46C3C20-039E-4D7C-869F-9C0C05D65C06} Failed
2014/4/8:21:27:44 Salman SALMAN-PC Uninstall {577D60CB-0D5E-48D1-8850-84098AD34804} Failed
2014/4/8:21:27:44 Salman SALMAN-PC Uninstall {0576A3D0-0000-0409-0000-491C453655D7} Failed
2014/4/8:21:27:44 Salman SALMAN-PC Uninstall {7BDBD5BE-B02E-4FB4-8735-B9AF4FCA838F} Failed
2014/4/8:21:27:44 Salman SALMAN-PC Uninstall {1ECD6EC8-7BB2-4CD5-A384-BAA371BC4D21} Failed
2014/4/8:21:27:44 Salman SALMAN-PC Uninstall {4780F600-0000-0409-0000-114715ACF216} Failed
2014/4/8:21:27:45 Salman SALMAN-PC Download Play ADR2013 http://trial.autodesk.com/SWDLDDLM/2013/INVNTOR/WI/{7A8FD266-4E05-4485-8B20-473DDFB57937}/ADR2013_en...
2014/4/8:21:28:10 Salman SALMAN-PC Download Complete ADR2013 http://trial.autodesk.com/SWDLDDLM/2013/INVNTOR/WI/{7A8FD266-4E05-4485-8B20-473DDFB57937}/ADR2013_en...
2014/4/8:21:28:10 Salman SALMAN-PC Installing Autodesk® Design Review 2013: INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Design Review 2013\" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/8:21:28:49 Salman SALMAN-PC Install Autodesk® Design Review 2013 Succeeded
2014/4/8:21:28:50 Salman SALMAN-PC Download Play VCREDIST2005SP1ATLX64 http://trial.autodesk.com/SWDLDDLM/2013/INVNTOR/WI/{7A8FD266-4E05-4485-8B20-473DDFB57937}/VCREDIST20...
2014/4/8:21:28:53 Salman SALMAN-PC Download Complete VCREDIST2005SP1ATLX64 http://trial.autodesk.com/SWDLDDLM/2013/INVNTOR/WI/{7A8FD266-4E05-4485-8B20-473DDFB57937}/VCREDIST20...
2014/4/8:21:28:53 Salman SALMAN-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): C:\Autodesk\WI\Autodesk Inventor 2013\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe /q:a /T:C:\windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Salman\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/4/8:21:29:08 Salman SALMAN-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Succeeded
2014/4/8:21:29:09 Salman SALMAN-PC Download Play CM2013 http://trial.autodesk.com/SWDLDDLM/2013/INVNTOR/WI/{7A8FD266-4E05-4485-8B20-473DDFB57937}/CM2013.tar...
2014/4/8:21:29:46 Salman SALMAN-PC Download Complete CM2013 http://trial.autodesk.com/SWDLDDLM/2013/INVNTOR/WI/{7A8FD266-4E05-4485-8B20-473DDFB57937}/CM2013.tar...
2014/4/8:21:29:46 Salman SALMAN-PC Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/8:21:30:22 Salman SALMAN-PC Install Autodesk Material Library 2013 Succeeded
2014/4/8:21:30:23 Salman SALMAN-PC Download Play CMILB2013 http://trial.autodesk.com/SWDLDDLM/2013/INVNTOR/WI/{7A8FD266-4E05-4485-8B20-473DDFB57937}/CMILB2013....
2014/4/8:21:31:22 Salman SALMAN-PC Download Complete CMILB2013 http://trial.autodesk.com/SWDLDDLM/2013/INVNTOR/WI/{7A8FD266-4E05-4485-8B20-473DDFB57937}/CMILB2013....
2014/4/8:21:31:22 Salman SALMAN-PC Installing Autodesk Material Library 2013 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/8:21:31:37 Salman SALMAN-PC Install Autodesk Material Library 2013 - Base Image Library Succeeded
2014/4/8:21:31:37 Salman SALMAN-PC Download Play DIRECTX http://trial.autodesk.com/SWDLDDLM/2013/INVNTOR/WI/{7A8FD266-4E05-4485-8B20-473DDFB57937}/DIRECTX.ta...
2014/4/8:21:31:43 Salman SALMAN-PC Download Complete DIRECTX http://trial.autodesk.com/SWDLDDLM/2013/INVNTOR/WI/{7A8FD266-4E05-4485-8B20-473DDFB57937}/DIRECTX.ta...
2014/4/8:21:31:43 Salman SALMAN-PC Installing DirectX® Runtime: C:\Autodesk\WI\Autodesk Inventor 2013\3rdParty\DirectX\DXSETUP.exe /silent
2014/4/8:21:33:01 Salman SALMAN-PC Install DirectX® Runtime Succeeded
2014/4/8:21:33:02 Salman SALMAN-PC Download Play CMILL2013 http://trial.autodesk.com/SWDLDDLM/2013/INVNTOR/WI/{7A8FD266-4E05-4485-8B20-473DDFB57937}/CMILL2013....
2014/4/8:21:41:50 Salman SALMAN-PC Download Complete CMILL2013 http://trial.autodesk.com/SWDLDDLM/2013/INVNTOR/WI/{7A8FD266-4E05-4485-8B20-473DDFB57937}/CMILL2013....
2014/4/8:21:41:50 Salman SALMAN-PC Installing Autodesk Material Library 2013 - Low Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/8:21:42:07 Salman SALMAN-PC Install Autodesk Material Library 2013 - Low Image Library Succeeded
2014/4/8:21:42:08 Salman SALMAN-PC Download Play UNINSTALLTOOL http://trial.autodesk.com/SWDLDDLM/2013/INVNTOR/WI/{7A8FD266-4E05-4485-8B20-473DDFB57937}/UNINSTALLT...
2014/4/8:21:42:09 Salman SALMAN-PC Download Complete UNINSTALLTOOL http://trial.autodesk.com/SWDLDDLM/2013/INVNTOR/WI/{7A8FD266-4E05-4485-8B20-473DDFB57937}/UNINSTALLT...
2014/4/8:21:42:09 Salman SALMAN-PC Installing Quick Uninstall Tool for Autodesk® Inventor® 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/8:21:42:13 Salman SALMAN-PC Install Quick Uninstall Tool for Autodesk® Inventor® 2013 Succeeded
2014/4/8:21:42:13 Salman SALMAN-PC Download Play DWGTRUEVIEW2013 http://trial.autodesk.com/SWDLDDLM/2013/INVNTOR/WI/{7A8FD266-4E05-4485-8B20-473DDFB57937}/DWGTRUEVIE...
2014/4/8:21:44:23 Salman SALMAN-PC Download Complete DWGTRUEVIEW2013 http://trial.autodesk.com/SWDLDDLM/2013/INVNTOR/WI/{7A8FD266-4E05-4485-8B20-473DDFB57937}/DWGTRUEVIE...
2014/4/8:21:44:23 Salman SALMAN-PC Installing DWG TrueView: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/8:21:46:19 Salman SALMAN-PC Install DWG TrueView Succeeded
2014/4/8:21:46:19 Salman SALMAN-PC Installing Autodesk Cloud sync: ADLANGUAGE=en-us ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Inventor 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/8:21:46:31 Salman SALMAN-PC Install Autodesk Cloud sync Succeeded
2014/4/8:21:46:32 Salman SALMAN-PC Download Play INVENTOR http://trial.autodesk.com/SWDLDDLM/2013/INVNTOR/WI/{7A8FD266-4E05-4485-8B20-473DDFB57937}/INVENTOR_x...
2014/4/8:21:53:44 Salman SALMAN-PC Download Error INVENTOR <B>File not found</B>Please Install Now again from the Autodesk website. http://trial.autodesk.com/SWDLDDLM/2013/INVNTOR/WI/{7A8FD266-4E05-4485-8B20-473DDFB57937}/INVENTOR_x...
2014/4/8:21:53:45 Salman SALMAN-PC Download Error INVENTOR Unpackaging failed http://trial.autodesk.com/SWDLDDLM/2013/INVNTOR/WI/{7A8FD266-4E05-4485-8B20-473DDFB57937}/INVENTOR_x...
2014/4/8:21:53:46 Salman SALMAN-PC Download Aborted INVENTOR http://trial.autodesk.com/SWDLDDLM/2013/INVNTOR/WI/{7A8FD266-4E05-4485-8B20-473DDFB57937}/INVENTOR_x...
2014/4/8:21:53:46 Salman SALMAN-PC Install Autodesk® Inventor® 2013 Failed Download Failed, Installation aborted, Result=1603
2014/4/8:21:53:51 Salman SALMAN-PC Rollback Autodesk Cloud sync Succeeded
2014/4/8:21:54:51 Salman SALMAN-PC Rollback Autodesk Material Library 2013 - Low Image Library Succeeded
2014/4/8:21:54:51 Salman SALMAN-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/4/8:21:56:01 Salman SALMAN-PC Rollback Autodesk Material Library 2013 - Base Image Library Succeeded
2014/4/8:21:56:43 Salman SALMAN-PC Rollback Autodesk Material Library 2013 Succeeded
2014/4/8:21:57:55 Salman SALMAN-PC Rollback Autodesk® Design Review 2013 Succeeded
And another copy of the Inventor Community Library thing:
Please help figure the program that is causeing the issue, so I can install Inventor.
Ask for any additional information that will make answer easier to figure out.
Hi, welcome to Autodesk Community!
Please try to download the installer to your local and install from there, see if works.You can find the installer from our Virtual Agent.
Hello. Yes, the method you tried failed, so try another. Downloading the files and testing them is the way to go.
Thank you for taking part in our community!
