Installation & Licensing
Member
mc9911350
Message 1 of 9 (4,319 Views)
Autodesk Inventor 2012 64bit installation probs
4319 Views, 8 Replies
04-10-2012 05:02 AM
Hi, new to these forums but was wondering if anyone could give me a hand.  Im trying to install Inventor 2012 student onto my my computer, I have the 32bit on a laptop but got a better computer and downloaded the 64 bit.  It seems to be failing on installation everytime.  The computers new and pretty good so dont understand whats wrong, or how to fix it?
Installation log file looks like this
2012/4/10:11:48:46    Kenny    SCOTT-PC    === Setup started on SCOTT-PC by Kenny ===
2012/4/10:11:48:46    Kenny    SCOTT-PC    Launch
2012/4/10:11:48:57    Kenny    SCOTT-PC    Inventorui== Parameter: Prereq_1 SetupMode:1 InstallState:1 InstallAction:0 Message:
2012/4/10:11:48:58    Kenny    SCOTT-PC    Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2012/4/10:11:48:58    Kenny    SCOTT-PC    Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2012/4/10:11:49:14    Kenny    SCOTT-PC    Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message:
2012/4/10:11:49:14    Kenny    SCOTT-PC    PageOpen    LaunchDialog
2012/4/10:11:49:25    Kenny    SCOTT-PC    PageOpen    LicenseDialog
2012/4/10:11:49:30    Kenny    SCOTT-PC    PageOpen    ProductInfoDialog
2012/4/10:11:49:46    Kenny    SCOTT-PC    PageOpen    InventorFlavorSelectionDialog
2012/4/10:11:49:46    Kenny    SCOTT-PC    Inventorui==DefaultLanguage:    en-us
2012/4/10:11:49:46    Kenny    SCOTT-PC    Inventorui==InstallName:    INVENTOR
2012/4/10:11:49:46    Kenny    SCOTT-PC    Inventorui==ProductName:    Autodesk Inventor 2012
2012/4/10:11:49:46    Kenny    SCOTT-PC    Inventorui==DisplayName:    Autodesk® Inventor® 2012
2012/4/10:11:49:46    Kenny    SCOTT-PC    Inventorui==DeploymentName:
2012/4/10:11:49:46    Kenny    SCOTT-PC    Inventorui==SetupTitle:    Autodesk Inventor 2012
2012/4/10:11:49:46    Kenny    SCOTT-PC    Inventorui==ConfigTransform:
2012/4/10:11:49:46    Kenny    SCOTT-PC    Inventorui==ExeParams:
2012/4/10:11:49:46    Kenny    SCOTT-PC    Inventorui==ProductCode:    {7F4DD591-1664-0409-0000-7107D70F3DB4}
2012/4/10:11:49:46    Kenny    SCOTT-PC    Inventorui==SupportLink:
2012/4/10:11:49:46    Kenny    SCOTT-PC    Inventorui==InfotainmentLink:
2012/4/10:11:49:46    Kenny    SCOTT-PC    Inventorui==MsiFileName:    inventor.msi
2012/4/10:11:49:46    Kenny    SCOTT-PC    Inventorui==AdminImageConfigName:    AdminImagex64
2012/4/10:11:49:46    Kenny    SCOTT-PC    Inventorui==AdminImageRoot:
2012/4/10:11:49:46    Kenny    SCOTT-PC    Inventorui==GetBaseDeploymentName:
2012/4/10:11:49:46    Kenny    SCOTT-PC    Inventorui==DeploymentLocation:
2012/4/10:11:49:46    Kenny    SCOTT-PC    Inventorui==DocumentLink:    SetupRes\InfoLink\help_landing.html
2012/4/10:11:49:46    Kenny    SCOTT-PC    Inventorui==InstallDeploymentShortcut:
2012/4/10:11:49:46    Kenny    SCOTT-PC    Inventorui==ModifyDeploymentShortcut:
2012/4/10:11:49:46    Kenny    SCOTT-PC    Inventorui==SetupLockType:    2
2012/4/10:11:49:46    Kenny    SCOTT-PC    Inventorui==SetupNetworkType:     0
2012/4/10:11:49:46    Kenny    SCOTT-PC    Inventorui==SystemLocale:    2057
2012/4/10:11:49:46    Kenny    SCOTT-PC    Inventorui==EvalMsiFilePath:    C:\Users\Kenny\AppData\Local\Temp\_AIA9E7.tmp\SetupRes\eval.msi
2012/4/10:11:49:46    Kenny    SCOTT-PC    Inventorui==EulaPath:    C:\Users\Kenny\AppData\Local\Temp\_AIA9E7.tmp\EULA
2012/4/10:11:49:46    Kenny    SCOTT-PC    Inventorui==InstallLogPath:    C:\Users\Kenny\AppData\Local\Temp\Inventor2012Install.log
2012/4/10:11:49:46    Kenny    SCOTT-PC    Inventorui==ConfigFile:    C:\Users\Kenny\AppData\Local\Temp\_AIA9E7.tmp\Setup.ini
2012/4/10:11:49:46    Kenny    SCOTT-PC    Inventorui==SetupPath:    C:\Users\Kenny\Documents\inv\
2012/4/10:11:49:46    Kenny    SCOTT-PC    Inventorui==NetworkLogPath:
2012/4/10:11:49:46    Kenny    SCOTT-PC    Inventorui==SourceRoot:    C:\Users\Kenny\Documents\inv\
2012/4/10:11:49:48    Kenny    SCOTT-PC    Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2012/4/10:11:49:48    Kenny    SCOTT-PC    PageOpen    ProductSelectionDialog2
2012/4/10:11:49:50    Kenny    SCOTT-PC    PageOpen    FullProgressDialog
2012/4/10:11:49:50    Kenny    SCOTT-PC    Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Users\Kenny\Documents\inv\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2012/4/10:12:45:06    Kenny    SCOTT-PC    Install    Microsoft Visual C++ 2008 SP1 Redistributable (x86)    Failed    Installation aborted, Result=1603
Amyone got any ideas?
Many Thanks
Kenny
TravisNave
Message 2 of 9 (4,285 Views)
Re: Autodesk Inventor 2012 64bit installation probs
04-11-2012 07:34 AM in reply to: mc9911350
Yes, it is failing on the prerequisite installer:
Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
Good Luck!
Member
mc9911350
Message 3 of 9 (4,275 Views)
04-11-2012 01:53 PM in reply to: mc9911350
Hi, thanks for the reply. I had viewed that post and gave that a try. I viewed my control panel and i had Microsoft Visual C++ 2005 Redistributable, Microsoft Visual C++ 2008 Redistributable and Microsoft Visual C++ 2010 Redistributable.  I deleted 2008 and 2010, although computer tended to freeze whilst doing this. Afterwards I tried again, but still had the same problem? After It failed to install i checked the Control Panel again and the 2008 one was back. I deleted and tried again, same problem.  I tends to freeze trying to install the 2008 Redistributable, seeming to load for an hour then tell me it cant install.  Ive tried to install manually, downloading the redistributable from the Microsoft Website, doesnt make a difference though.
Any thoughts?
Thanks, Kenny
TravisNave
Message 4 of 9 (4,272 Views)
04-11-2012 02:01 PM in reply to: mc9911350
Yeah, that's rough.  Try one of the cleanup tools here and see if you can get it to uninstall cleanly.  Then try again.
To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
http://support.microsoft.com/mats/Program_Install_and_Uninstall
As a last ditch effort consider using the Microsoft Installer Clean Up Utility. For more information on this program, please my forum post here:
http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
Member
mc9911350
Message 5 of 9 (4,259 Views)
04-12-2012 04:16 AM in reply to: TravisNave
Hi again, I downloaded that programme and removed the 2008 redistributable again, tried to install but still failing for the same reason. This is the log file:
2012/4/11:23:38:41    Kenny    SCOTT-PC    === Setup started on SCOTT-PC by Kenny ===
2012/4/11:23:38:41    Kenny    SCOTT-PC    Launch
2012/4/11:23:38:51    Kenny    SCOTT-PC    Inventorui== Parameter: Prereq_1 SetupMode:1 InstallState:1 InstallAction:0 Message:
2012/4/11:23:38:51    Kenny    SCOTT-PC    Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2012/4/11:23:38:51    Kenny    SCOTT-PC    Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2012/4/11:23:39:15    Kenny    SCOTT-PC    Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message:
2012/4/11:23:39:16    Kenny    SCOTT-PC    PageOpen    LaunchDialog
2012/4/11:23:39:37    Kenny    SCOTT-PC    PageOpen    LicenseDialog
2012/4/11:23:39:41    Kenny    SCOTT-PC    PageOpen    ProductInfoDialog
2012/4/11:23:40:06    Kenny    SCOTT-PC    PageOpen    InventorFlavorSelectionDialog
2012/4/11:23:40:06    Kenny    SCOTT-PC    Inventorui==DefaultLanguage:    en-us
2012/4/11:23:40:06    Kenny    SCOTT-PC    Inventorui==InstallName:    INVENTOR
2012/4/11:23:40:06    Kenny    SCOTT-PC    Inventorui==ProductName:    Autodesk Inventor 2012
2012/4/11:23:40:06    Kenny    SCOTT-PC    Inventorui==DisplayName:    Autodesk® Inventor® 2012
2012/4/11:23:40:06    Kenny    SCOTT-PC    Inventorui==DeploymentName:
2012/4/11:23:40:06    Kenny    SCOTT-PC    Inventorui==SetupTitle:    Autodesk Inventor 2012
2012/4/11:23:40:06    Kenny    SCOTT-PC    Inventorui==ConfigTransform:
2012/4/11:23:40:06    Kenny    SCOTT-PC    Inventorui==ExeParams:
2012/4/11:23:40:06    Kenny    SCOTT-PC    Inventorui==ProductCode:    {7F4DD591-1664-0409-0000-7107D70F3DB4}
2012/4/11:23:40:06    Kenny    SCOTT-PC    Inventorui==SupportLink:
2012/4/11:23:40:06    Kenny    SCOTT-PC    Inventorui==InfotainmentLink:
2012/4/11:23:40:06    Kenny    SCOTT-PC    Inventorui==MsiFileName:    inventor.msi
2012/4/11:23:40:06    Kenny    SCOTT-PC    Inventorui==AdminImageConfigName:    AdminImagex64
2012/4/11:23:40:06    Kenny    SCOTT-PC    Inventorui==AdminImageRoot:
2012/4/11:23:40:06    Kenny    SCOTT-PC    Inventorui==GetBaseDeploymentName:
2012/4/11:23:40:06    Kenny    SCOTT-PC    Inventorui==DeploymentLocation:
2012/4/11:23:40:06    Kenny    SCOTT-PC    Inventorui==DocumentLink:    SetupRes\InfoLink\help_landing.html
2012/4/11:23:40:06    Kenny    SCOTT-PC    Inventorui==InstallDeploymentShortcut:
2012/4/11:23:40:06    Kenny    SCOTT-PC    Inventorui==ModifyDeploymentShortcut:
2012/4/11:23:40:06    Kenny    SCOTT-PC    Inventorui==SetupLockType:    2
2012/4/11:23:40:06    Kenny    SCOTT-PC    Inventorui==SetupNetworkType:     0
2012/4/11:23:40:06    Kenny    SCOTT-PC    Inventorui==SystemLocale:    2057
2012/4/11:23:40:06    Kenny    SCOTT-PC    Inventorui==EvalMsiFilePath:    C:\Users\Kenny\AppData\Local\Temp\_AID44E.tmp\SetupRes\eval.msi
2012/4/11:23:40:06    Kenny    SCOTT-PC    Inventorui==EulaPath:    C:\Users\Kenny\AppData\Local\Temp\_AID44E.tmp\EULA
2012/4/11:23:40:06    Kenny    SCOTT-PC    Inventorui==InstallLogPath:    C:\Users\Kenny\AppData\Local\Temp\Inventor2012Install.log
2012/4/11:23:40:06    Kenny    SCOTT-PC    Inventorui==ConfigFile:    C:\Users\Kenny\AppData\Local\Temp\_AID44E.tmp\Setup.ini
2012/4/11:23:40:06    Kenny    SCOTT-PC    Inventorui==SetupPath:    C:\Users\Kenny\Documents\Inventor 2\
2012/4/11:23:40:06    Kenny    SCOTT-PC    Inventorui==NetworkLogPath:
2012/4/11:23:40:06    Kenny    SCOTT-PC    Inventorui==SourceRoot:    C:\Users\Kenny\Documents\Inventor 2\
2012/4/11:23:40:08    Kenny    SCOTT-PC    Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2012/4/11:23:40:08    Kenny    SCOTT-PC    PageOpen    ProductSelectionDialog2
2012/4/11:23:40:12    Kenny    SCOTT-PC    PageOpen    FullProgressDialog
2012/4/11:23:40:13    Kenny    SCOTT-PC    Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Users\Kenny\Documents\Inventor 2\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2012/4/12:00:38:36    Kenny    SCOTT-PC    Install    Microsoft Visual C++ 2008 SP1 Redistributable (x86)    Failed    Installation aborted, Result=1603
Control Panel shows 2008 has been removed though.
I still have the 2005 redistributables installed, should these be removed too?  There are other profiles on the computer, would I have to delete the redistributables from them too?  I would have thought that removing them from my profile would remvoe them on all profiles? I have an admin profile, but there is another admin profile on the computer too.
Thanks for your help
Kenny
TravisNave
Message 6 of 9 (4,246 Views)
04-12-2012 05:19 PM in reply to: mc9911350
No, it's a system wide program.  You might see about installing it separately direct from Microsoft.  If that doesn't work, you might have to do the "modify the system.ini file" method.
Member
mc9911350
Message 7 of 9 (4,238 Views)
04-13-2012 02:45 AM in reply to: TravisNave
I tried editing the setup.ini file, when loading Inverntor I got this:
2012/4/13:10:35:08    Kenny    SCOTT-PC    === Setup started on SCOTT-PC by Kenny ===
2012/4/13:10:35:08    Kenny    SCOTT-PC    Launch
2012/4/13:10:36:32    Kenny    SCOTT-PC    Inventorui== Parameter: Prereq_1 SetupMode:1 InstallState:1 InstallAction:0 Message:
2012/4/13:10:36:32    Kenny    SCOTT-PC    Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2012/4/13:10:36:32    Kenny    SCOTT-PC    Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2012/4/13:10:37:12    Kenny    SCOTT-PC    Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message:
2012/4/13:10:37:16    Kenny    SCOTT-PC    PageOpen    LaunchDialog
2012/4/13:10:37:27    Kenny    SCOTT-PC    PageOpen    LicenseDialog
2012/4/13:10:37:34    Kenny    SCOTT-PC    PageOpen    ProductInfoDialog
2012/4/13:10:37:46    Kenny    SCOTT-PC    PageOpen    InventorFlavorSelectionDialog
2012/4/13:10:37:46    Kenny    SCOTT-PC    Inventorui==DefaultLanguage:    en-us
2012/4/13:10:37:46    Kenny    SCOTT-PC    Inventorui==InstallName:    INVENTOR
2012/4/13:10:37:46    Kenny    SCOTT-PC    Inventorui==ProductName:    Autodesk Inventor 2012
2012/4/13:10:37:46    Kenny    SCOTT-PC    Inventorui==DisplayName:    Autodesk® Inventor® 2012
2012/4/13:10:37:46    Kenny    SCOTT-PC    Inventorui==DeploymentName:
2012/4/13:10:37:46    Kenny    SCOTT-PC    Inventorui==SetupTitle:    Autodesk Inventor 2012
2012/4/13:10:37:46    Kenny    SCOTT-PC    Inventorui==ConfigTransform:
2012/4/13:10:37:46    Kenny    SCOTT-PC    Inventorui==ExeParams:
2012/4/13:10:37:46    Kenny    SCOTT-PC    Inventorui==ProductCode:    {7F4DD591-1664-0409-0000-7107D70F3DB4}
2012/4/13:10:37:46    Kenny    SCOTT-PC    Inventorui==SupportLink:
2012/4/13:10:37:46    Kenny    SCOTT-PC    Inventorui==InfotainmentLink:
2012/4/13:10:37:46    Kenny    SCOTT-PC    Inventorui==MsiFileName:    inventor.msi
2012/4/13:10:37:46    Kenny    SCOTT-PC    Inventorui==AdminImageConfigName:    AdminImagex64
2012/4/13:10:37:46    Kenny    SCOTT-PC    Inventorui==AdminImageRoot:
2012/4/13:10:37:46    Kenny    SCOTT-PC    Inventorui==GetBaseDeploymentName:
2012/4/13:10:37:46    Kenny    SCOTT-PC    Inventorui==DeploymentLocation:
2012/4/13:10:37:46    Kenny    SCOTT-PC    Inventorui==DocumentLink:    SetupRes\InfoLink\help_landing.html
2012/4/13:10:37:46    Kenny    SCOTT-PC    Inventorui==InstallDeploymentShortcut:
2012/4/13:10:37:46    Kenny    SCOTT-PC    Inventorui==ModifyDeploymentShortcut:
2012/4/13:10:37:46    Kenny    SCOTT-PC    Inventorui==SetupLockType:    2
2012/4/13:10:37:46    Kenny    SCOTT-PC    Inventorui==SetupNetworkType:     0
2012/4/13:10:37:46    Kenny    SCOTT-PC    Inventorui==SystemLocale:    2057
2012/4/13:10:37:46    Kenny    SCOTT-PC    Inventorui==EvalMsiFilePath:    C:\Users\Kenny\AppData\Local\Temp\_AI4F38.tmp\SetupRes\eval.msi
2012/4/13:10:37:46    Kenny    SCOTT-PC    Inventorui==EulaPath:    C:\Users\Kenny\AppData\Local\Temp\_AI4F38.tmp\EULA
2012/4/13:10:37:46    Kenny    SCOTT-PC    Inventorui==InstallLogPath:    C:\Users\Kenny\AppData\Local\Temp\Inventor2012Install.log
2012/4/13:10:37:46    Kenny    SCOTT-PC    Inventorui==ConfigFile:    C:\Users\Kenny\AppData\Local\Temp\_AI4F38.tmp\Setup.ini
2012/4/13:10:37:46    Kenny    SCOTT-PC    Inventorui==SetupPath:    C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\
2012/4/13:10:37:46    Kenny    SCOTT-PC    Inventorui==NetworkLogPath:
2012/4/13:10:37:46    Kenny    SCOTT-PC    Inventorui==SourceRoot:    C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\
2012/4/13:10:37:47    Kenny    SCOTT-PC    Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2012/4/13:10:37:47    Kenny    SCOTT-PC    PageOpen    ProductSelectionDialog2
2012/4/13:10:37:49    Kenny    SCOTT-PC    PageOpen    FullProgressDialog
2012/4/13:10:37:49    Kenny    SCOTT-PC    Installing : C:\Autodesk\Autodesk_Inventor_2012_English_Win_64bit\
2012/4/13:10:37:49    Kenny    SCOTT-PC    Install        Failed    Installation aborted, Result=5
Im starting to think my system just cant run this programme now? Its starting to drive me mad since this new computer is so much better than the one I currently have inventor running on.
Kenny
Member
mc9911350
Message 8 of 9 (4,236 Views)
04-13-2012 03:52 AM in reply to: TravisNave
Something else I had noticed, when installing the Redistributables manually, It never fully installs, getting to the end and freezing, then sometimes showing up in the control panel part as redistributable 2008 3.7645 or some numbers along those lines. Then it does the same freeze with the uninstall. When you close the programme using task manager as it wont close, then try to install again it says it is currently trying to install.
I hinestly dont know enough about programmes to get my head around this problem!
Kenny
TravisNave
Message 9 of 9 (4,190 Views)
04-15-2012 03:19 PM in reply to: mc9911350
If the prerequisites are not installing on your computer, then you may not be left with much choice but to format and start over with a fresh OS install.  :smileysad:
