I have attached the log files from the installation. The error occurs install the language pack.
I'm going to direct you to my own answer that worked for me with an LT install. Your problem is similar with the Language Pack failure so the solution may be similar. There is also another thread embedded in this that was the information I used to start with.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
that didn't seem to make a difference, unfortunately. Any other suggestions.
What is your Windows Installer version? Type MSIEXEC at the Start > Run line and reply with the version.
is my version of Windows installer adequate. Do you think this is the problem. Any suggestions would be appreciated.
