Installation & Licensing
autodesk inventor 2010 suite
2 REPLIES 2
245 Views, 2 Replies
I am unable to reinstall AutoCad Inventor suite 2010 onto my new computer with windows 7.
2 REPLIES 2
byron.morales
In regards to Autodesk Inventor 2010 not installing onto your computer, please Uninstall, re-install of the VCREDIST (Microsoft Visual C++) packages. Usually, it works best to uninstall them in this order (newest to oldest)
2010 x86
2010 x64
2008x64
2008x86
2005x64
2005x86
Then reinstall in the opposite order: (oldest to newest)
2005 x86
2005 x64 etc.
You can locate the packages in the 3rdParty\x86 and 3rdParty/x64 VCREDIST folders in the install media or deployment.
Please uninstall .NET Framework 4.5 if installed then continue.
Then Run the dotNetFx40_Full_x86_x64.exe file located on  the \3rdParty\NET\4\wcu\dotNetFramework folder and select Repair.
Reboot computer, Turn Antivirus Off, Clear the contents of the %temp% folder and then attempt to re-install the software.
If the installation fails please create a new local user account onto the computer and give it administrator permissions then log into the computer with newly created test account and Turn Antivirus Off, Clear the contents of the %temp% folder and then attempt to re-install the software.
If the installation fails please reply back to this email and include any  screen captures of error messages and also include the setup and install log files found on the %temp% folder.
Let me know if the above helps you resolve the issue.
Byron M.
TravisNave
Post your installation logs for verification.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
