My autodesk download manager won't launch. I reistalled it, tryied again and it didn't work. Then I rebooted my computer, tryied to launch and it didn't work too. What can I do to solve this problem?
Hi ft3,
Have you tried using a different browser? Do you still have the same error? When you said it won't launch, did you receive any particular error message or it's just completely a blank screen?
Hi ft3
As it happens I spent a couple of hours fighting with this little beauty yesterday, yes on a Sunday!!! in order to meet tight deadlines for a major Tech Refresh project.
Here is what I found....
I await with baited breath to see what the final outcome is.
I found the attached pdf a few minutes ago and it would have been so useful to have read yesterday so:-
AUTODESK WHY IS IT NOT OFFERED BEFORE YOU ATTEMPT TO INSTALL AND WHY DO YOU NOT EXPLICITLY TELL USERS ABOUT THE AKAMAI COMPONENT????
Many users will have protection on PCs that will need to know about both ADLM and Akamai components.
@Anonymous
This posting is 6 years old. What are you trying to do? You have only provided very limited information. There's no way we can assist you at this point.
Mark Lancaster
& Autodesk Services MarketPlace Provider
@Anonymous
There's a couple of ways to properly download and install your Autodesk product to your machine. Please review this article and the solution it provides.
If the installation does fail using the preferred methods, please post your installation log file here so we can review it.
Posting info: Sometimes the installation log file contains the serial # that was assigned to you. Open your log file using Windows Notepad and perform a search on "/SN". Depending on the number of installation attempts, your serial # may be located throughout the log file. If present, remove or "X" out your serial # prior to posting.
Good luck on your installation and report back on your progress.
Mark Lancaster
Do you have an issue / error? I ask as this is a 2 year old forum post ....
