We're looking to install the Autodesk Design Review software but before we do so we'd like to know what the licensing terms are. I've had a look on the Autodesk website but can't find these anywhere for the free review product. Could you advise what they are please? Many thanks.
Solved by TravisNave. Go to Solution.
design review doesn't require any type license anyone can install it as many times as they want to and on as many computers as they want to
DarrenP
The EULA for this product is typically located in C:\Program Files\Autodesk\Autodesk Design Review\en-US and can usually be read during the installation portion where you click "I Agree."
As Darren pointed out, you pretty much have free reign to install this to as many clients as you deem necesary:
2.1 License Grant. Autodesk grants You a non-sublicensable, non-exclusive, non-transferable, limited license to use the Software in accordance with the applicable User Documentation and this Agreement, and to reproduce and distribute copies of the Software in accordance with the terms of this Agreement. You may Install the Software on one or more Computers in one or more locations; post and make available the Software on a network file server in order to Install the Software onto other Computers or use the Software over such network; and make backup copies of the Software. You may make unlimited copies of the Software and User Documentation and distribute such copies to other persons or entities, including downloading the Software from the Internet or similar on-line source, so long as (i) all such copies contain this Agreement and the same copyright and other proprietary notices that appear on or in the Software and User Documentation, and (ii) You copy and distribute the Software and User Documentation in its entirety, and (iii) You do not distribute incomplete, modified, reverse engineered, or otherwise altered copies of the Software or User Documentation. Autodesk’s license grant is conditioned on Your continuous compliance with all license limitations and restrictions described in this Agreement. If You violate any of these limitations or restrictions, the license grant will automatically and immediately expire. No license is granted under the terms of this Agreement if you did not lawfully acquire the Software.
Just had a Service Request on a similar issue. The full download can be found here:
http://usa.autodesk.com/adsk/servlet/pc/item?siteID=123112&id=10336080
