Installation & Licensing
Autodesk Design Review Error 1904
4 REPLIES 4
2320 Views, 4 Replies
I have searched high and low for a solution to this with no avail.  I got an error a few weeks ago loading the software and ultimately tried first to repair, then to remove and reinstall.  Everytime I try I get an error message as follows:
Error 1904.Module C:\program Files (x86)\Autodesk Shared\dwf Common\dwf_vshell.dll failed to register. Hresult -2147220473. Contact your support personnel.
I have no idea how to correct this.  I need this software to review documents from clients.  Any assistance is appreciated.
4 REPLIES 4
cool_rpp
Wow so glad someone from Autodesk replied because I have a similar error (same number 1904 but different file path).
Got the same error. were you able to fix it?
Mark.Lancaster
@Anonymous
Welcome to the community..  Download the full software here http://usa.autodesk.com/design-review/download/ and see if that helps.  Also if it does work apply this hot fix as well https://knowledge.autodesk.com/support/design-review/downloads/caas/downloads/content/autodesk-design-review-2013-hotfix.html
Mark Lancaster
hckim
I have same problem when install Vault professional 2017.
this is my solution.
1. uninstall vault pro.
2. uninstall design review.
3. uninstall all the c++ application in control panel.
4. reinstall vault pro.
Administrator Productivity
