Installation & Licensing
Member
1 Kudo
Post 1 of 13
Autodesk Design Review 2013 Setup - Installation failed.
12838 Views, 12 Replies
10-29-2012 03:33 PM
I am on Windows 8 RTM x64. I am trying to install Design Review 2013, but the "internet connection" isn't being "found". My internet connection is fine. See the following:
Hi @CallawaySupport and welcome to the community!
Will you try this posted solution and let me know if it resolves your issue? If not, please respond to this post with further details.
Thank you!
904 Kudos
Post 2 of 13
Re: Autodesk Design Review 2013 Setup - Installation failed.
10-30-2012 07:07 AM in reply to: dcuccia
Please be aware that Autodesk products are not yet supported on Windows 8.  You should look to see if you can find a full download if available.
Member
1 Kudo
Post 3 of 13
10-30-2012 03:44 PM in reply to: dcuccia
Thanks.
Re: "You should look to see if you can find a full download if available."
I wasn't able to...any chance you could point me in the right direction?
David
Product Support
70 Kudos
Post 4 of 13
11-01-2012 07:51 AM in reply to: dcuccia
dcuccia,
Hello. This program is not supported on Windows 8, so it may not be usable in your environment. There is an alternate download method, however. I have a link for you hat describes this here:
http://upandready.typepad.com/up_and_ready/2012/04/design-review-download-now-vs-additional-install-...
Thank you for taking part in our community!
David Dembkoski
Product Support Specialist
Autodesk Product Support
David Dembkoski
Member
1 Kudo
Post 5 of 13
11-02-2012 04:21 PM in reply to: dembkod
dembkod wrote:
dcuccia,
David Dembkoski
David - that worked perfectly. I'm up and running, thanks very much! -David
0 Kudos
Post 6 of 13
01-10-2013 03:28 PM in reply to: TravisNave
Hmm, but I'm getting the same error message... on a workstation that's WinXP 32-bit. I've tried the alternative download option as well. Any other ideas what I can do?
Thanks in advance.  ~Sona
Sona Greenberg
Product Support
70 Kudos
Post 7 of 13
01-18-2013 10:57 AM in reply to: dcuccia
sonablue,
Hello. I would uninstall the program and wipe the residual folders for Design Review. There could be residual traces from a failed install.  First, run the MS Fixit utility and try to uninstall Design Review if it lists in this program.
http://support.microsoft.com/mats/Program_Install_and_Uninstall\
Next, look for and delete residual traces that may be there. They will be clearly named and in a variety of places:
C:\Program Files\Autodesk\
C:\ProgramData\Autodesk\
C:\Program Files (x86)\Autodesk\
C:\Users\All Users\Autodesk\
C:\Users\**YOUR USERID**\AppData\Roaming\Autodesk\
C:\Users\**YOUR USERID**\AppData\Local\Autodesk\
After all this is clean, make sure you have the MSI installer on your system.
http://www.microsoft.com/en-us/download/details.aspx?id=8483
Log in with an Admin account, turn off Windows UAC and Antivirus and give the install a go.
David Dembkoski
David Dembkoski
0 Kudos
Post 8 of 13
01-22-2013 02:56 PM in reply to: dembkod
Hi dembkod,
Hmm, those look like folders in Win7, not WinXP. Nevertheless I'll look for their equivalent and clear what I find.
It's become less of a priority now that I've been switched to a Win7 machine myself (irony!), but a few other CAD users in my group are still using WinXP workstations and might like to see this resolved.
Sona Greenberg
New Member
0 Kudos
Post 9 of 13
02-12-2013 02:16 PM in reply to: dcuccia
David-
This worked for me as well.  Thank you for your help!
Member
0 Kudos
Post 10 of 13
05-12-2014 08:08 AM in reply to: bristleconedesign
Hello
I am getting similar errors as shown in the images on the 1st post.   I am using 64 bit windows 7 and I am in a Corporate environment, not at home.  Is it a firewall or other security issue that is blocking me?   My internet connection is fine.  Here is what I downloaded and the error I get.  I tried version 2012 also, got same type of error.
