Installation & Licensing
Autodesk Composite error on Linux
2 REPLIES 2
wdanilo
470 Views, 2 Replies
Hello! I'm trying to run Autodesk Composite on a new Linux hardware (Thinkpad w540, Quadro K2100, Optimus technology, Gentoo linux, x64).
I've installed it, but while running the composite binary I get following output:
Exception encountered: Current screen bits per pixel is 24, required bits per pixel is 32. Please configure the graphics system accordingly.
Terminate handler called from thread: 0x7fa807763780
Stack trace: /usr/autodesk/composite2014-x64/lib/libDLresmgt.so(Dl::MtLogger::terminateHandler()+0x23) [0x7fa7fbf729d3]
/usr/lib/gcc/x86_64-pc-linux-gnu/4.8.2/libstdc++.so.6(+0x637d6) [0x7fa806b257d6]
/usr/lib/gcc/x86_64-pc-linux-gnu/4.8.2/libstdc++.so.6(+0x63803) [0x7fa806b25803]
/usr/lib/gcc/x86_64-pc-linux-gnu/4.8.2/libstdc++.so.6(+0x63a2e) [0x7fa806b25a2e]
/usr/autodesk/composite2014-x64/lib/libDLbase.so(Dl::InInitGuard::performInitialization(int&, char const* const*&, bool) const+0x403) [0x7fa7fb0f9253]
/usr/autodesk/composite2014-x64/lib/libDLbase.so(Dl::InInitGuard::InInitGuard(int&, char const* const*&, Dl::InInitGuard::NoCallStack)+0x8) [0x7fa7fb0f92a8]
/usr/autodesk/composite2014-x64/lib/libDLtxapp.so(Dl::ApplicationBuilder::execute()+0x526) [0x7fa8015a8076]
/usr/autodesk/composite2014-x64/lib/libDLtxapp.so(txappmain+0x5a) [0x7fa8015af64a]
./composite.bin() [0x40112b]
/lib/libc.so.6(__libc_start_main+0xf5) [0x7fa806309dc5]
./composite.bin() [0x400fe9]
Does anybody know what is the reason?
2 REPLIES 2
azeone123
in reply to: wdanilo
Its not a help as this is not solved here, but you are not alone Check This Thread
gkocov
in reply to: azeone123
I ran into the "Exception encountered: Current screen bits per pixel is 24, required bits per pixel is 32. Please configure the graphics system accordingly." problem on CentOS 6.5 running NVidia's 340.24 drivers. Downgrading to 331.89 solved the problem for me.
Hope this helps, but as always with this things YMMV.
Administrator Productivity
