Installation & Licensing
autodesk component issue for 3DS MAX 2014
6 REPLIES 6
vcwon1
1715 Views, 6 Replies
I am having issues after installnig 3DS MAX 2014. Once I start MAX i  get an Autodesk component error and
the program freezes. Anyone resolved this part? I couldn't even get to the activation menu. I tried uninstalling and installing the program for so many times now , downloading and installing both service packs but still the same problem. I just can't get past the licensing stage. I tried saving the adskflex_*_tsf.data file to a .bak file as mentioned in the
AutoCAD issue thread but still nothing. Any help would be much appreciated. Thanks.
6 REPLIES 6
DarrenP
in reply to: vcwon1
try this: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21825687&linkID=12305695
DarrenP
vcwon1
in reply to: DarrenP
My Windows works fine. Its just the launch of 3DS Max that freezes with the Autodesk component message. My issue is the same with this: http://forums.autodesk.com/t5/Installation-Licensing/Autodesk-component-has-stopped-working/td-p/384... except its for 3DS Max 2014.
TravisNave
in reply to: vcwon1
If you are running on a laptop, it could be an Optimus setting for your video card.  Subsequently, it can still be one of the two activation crashes plaguing the 2014 release.
http://forums.autodesk.com/t5/Hardware/Disabling-nVidia-Optimus-amp-Perform-Clean-Install/td-p/43632...
or
http://upandready.typepad.com/up_and_ready/2013/08/autodesk-software-activation-freezing-on-laptops-...
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
dembkod
in reply to: vcwon1
vcwon1,
Hello. Do you have IE 10 installed? It is possible that it is causing grief here. I would roll back to 9 and see if it changes the behavior.
  1. In the Windows Control Panel, go to Programs and Features
  2. Click Turn Windows features on or off
  3. Uncheck the Internet Explorer 10 box and click "OK". Let the process run
  4. After the system finishes processing, reboot the machine
  5. In the Windows Control Panel, go to Programs and Features
  6. Click "View Installed Updates"
  7. Locate the update for Internet Explorer 10 and select it and click "Uninstall" at the top of the screen.
  8. Let the process complete and reboot.
You can also look in the Windows Event logs to see if there is a particular module failing.
Thank you for taking part in our community!
David Dembkoski
vcwon1
in reply to: dembkod
Thanks everyone,
Will give that a try.
vcwon1
in reply to: vcwon1
This solved the problem.
Starting the program with integrated graphics worked! Hopefully this would be highlighted in the next release especially with laptop video devices. Thanks again to everyone with their help!
Administrator Productivity
