When starting AutoCAD 2014 for the first time it gets to the part where it is checking the license and it stops working. An dialog box pops up and says Autodesk component has stopped working. A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available. So I can't get into 2014. I have not uninstalled 2013 yet so I am using that now. AutoCAD 2013 shut down on me yesterday unexpectantly when I was creating a bitmap image for a new toolbar. The dialog box popped up when asking me to report the error and when I went to send it I got a similar message saying again the Autodesk component has stopped working, then a new dialog box popped us saying internet explorer has stopped working and needed to be closed closed. Can anyone help me with this. I have opened a new case through subscription acouple days ago, but thought I might get faster results here. Case number is 08255552.
Solved by jsxoinas360. Go to Solution.
I've got the same problem! I've tried 3 different versions and it just wont work. Did you figure out why? I'm running windows 7.
I am having this problem but with revit. I have tried the fixes but am still having issues. Is there anything else to try?
Welcome to the Community.
Your issues at launch could be due to a problem identified as the 2014 Activation Crash. You can see if the KB article about this issue resolves your problem.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21825687&linkID=12305695
Good Luck!
did you ever have any luck figure out the issues you were having? i'm running revit 2013 and after 5 months of a great run it stopped working today due to the activation issues on windows 7. Any input would be appreciated. thanks!
@jsxoinas360 wrote:
http://upandready.typepad.com/up_and_ready/2013/08/autodesk-software-activation-freezing-on-laptops-... instant solution!!! worked for me
Thanks for the confirmation. I have written an additional information about this issue here:
I'm having same problem with my Infraworks 360 R2.
Acutally none of these suggestions worked for me, but I found that by pressing the "Activate" button as soon(!) as I can see it, it takes be beyond the "freeze" point. However, if I wait even just 1 sec. with pressing the button then the program freezes.
yea, this totaly works, I was up past 3am just trying to install max 2014, i checked this comments while trouble shoooting and tried pressing the activation button as soon as it appeared. It worked!!!
After such a frustrating experience with Revit 2014 Components failing close to a deadline. I felt it necessary to post a response that others may benefit. Strangely, NOT ONE suggested this strategy. As I'm not a computer wizard, I usually do not try anything rash without some backup advice. Strangely there isn't much said about this problem.
1. If you have tried the solutions posted on this forum and they do not work. try the following.
note: this will reset revit, so probably a good idea to back up your projects and component lists and any other 'special' files you may have changed.
2. Try using the windows uninstall process via control panels to start the Autodesk uninstall wizard.
3. Choose the option to REPAIR.
4. Activate your software. You may need to contact Autodesk for a re-acctivation code.
This worked for me and was relatively fuss free.
I hope this experience may help you find your solution.
Please note. I have been successfully operating Revit 2014 on a 17" Apple MacbookPro(6,1) i7 2.66GHz, NVIDIA GeForce GT 330M,
with 8Gb ram using Bootcamp, Windows 7(64bit) and GMWARE Fusion. The only issue I have ever experienced is sluggishness caused by multiple sleep transitions. I reboot my machine about 1/week so I'm actually surprised this is as stable as it is. Windows has crashed less on this machine than any other computer I have ever used. Not sure about what new Macs are like....
Re: Autodesk component has stopped working on autocad 2011 and autocad 2012 ?? what shall i do please answer me important
i am facing this problem in Autodesk recap 2015 .plz help me .
and my another id - harveersolanki@gmail.com
