Installation & Licensing
Autodesk Building Design Suite Ultimate 2014 install error
1 REPLY 1
Diarmaidoc
217 Views, 1 Reply
I have purchased Autodesk Building Design Suite Ultimate 2014 which was sent on a USB Stick.
I have had both AutoCad 2014 and 2015 for a trial period which has subsequently expired.
I uninstalled both AutoCad versions and then started to install the Suite as bought.
It did install Revit but then stopped and asked "Please insert the disk" which I obviously don't have.
On subsequent attempts it starts and then asks "Please insert the disk"
I do have seriel numbers and activation codes so don't know what to do.
I can only assume it has something left from the uninstall procedure - but do not know
Any help would be appreciated.
Many thanks
1 REPLY 1
TravisNave
in reply to: Diarmaidoc
Copy the USB to a folder on your hard drive, then install setup.exe from there.  Make sure your antivirus is temporarily disabled.  Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
