I have purchased Autodesk Building Design Suite Ultimate 2014 which was sent on a USB Stick.
I have had both AutoCad 2014 and 2015 for a trial period which has subsequently expired.
I uninstalled both AutoCad versions and then started to install the Suite as bought.
It did install Revit but then stopped and asked "Please insert the disk" which I obviously don't have.
On subsequent attempts it starts and then asks "Please insert the disk"
I do have seriel numbers and activation codes so don't know what to do.
I can only assume it has something left from the uninstall procedure - but do not know
Any help would be appreciated.
Many thanks
Copy the USB to a folder on your hard drive, then install setup.exe from there. Make sure your antivirus is temporarily disabled. Good Luck!
