Installation & Licensing
Autodesk Building Design Suite Ultimate 2014 install error
8 REPLIES 8
Message 1 of 9
i.franco
2383 Views, 8 Replies
Good afternoon. I'm currently trying to install my autodesk building design suite ultimate 2014 on my workstation. I downloaded the installer and when I execute It, the following message pops out:
"The system cannot find the file specified.
C:\Users\HeptaW1\AppData\Local\Temp\_AI7DD7.tmp\x64\ACA\ACA.msi"
After I click Ok, the installer closes. I have tried everything, from rebooting the pc, to deleting the temp files, downloading the installer again, yet nothing seems to work. I need some assistance please.}
Iván Franco
8 REPLIES 8
Message 2 of 9
TravisNave
in reply to: i.franco
Welcome to the community.
This is a known issue with Trend Micro antivirus.  Simply disable it temporarily during installation.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21889889&linkID=9243099&CMP=OTC-RSS...
Good Luck!
Autodesk Forums:
Message 3 of 9
i.franco
in reply to: TravisNave
Thank you for your quick response, I checked the page you sent and I followed the procedure closely. First off, I do not have Trend Micro antivirus, and since I just formated my pc, I currently do not have any antivirus installed. I tried following the next part which was to clean up the temp folder, and that didn't work either. And finally I did the las procedure which was to create a new temp folder and restart the installation and... well it didnt work 😕
What else can I do?
Message 4 of 9
TravisNave
Make sure you have local admin rights and UAC is off.  I assume this is Windows 7?
Did you download this?
Autodesk Forums:
Message 5 of 9
asburyj
Clearly something is preventing the use of the install MSI that is unpacked to the temp folder. If it's not antivirus and you have cleaned the temp folder try disabling UAC and attempt the install again.
http://windows.microsoft.com/en-US/windows7/turn-user-account-control-on-or-off
Also, ensure you are running the install with an administrator account.
If you continue to get errors you may also was to try the microsoft install fix-it utility linked below as it can fix common errors with the windows installer service
http://support.microsoft.com/mats/Program_Install_and_Uninstall
Jeffry Asbury
Message 6 of 9
i.franco
in reply to: asburyj
Thanks again. I tried disabling UAC and the same problem appeared, and I ran the windows fix it tool and since the program was not installed on the workstation, the tool did not detect any problem at all. I do not know what else to do.
Ivan franco
Message 7 of 9
TravisNave
It's possible you have a bad download.
Might try again from the virtual assistant:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21889745&linkID=9240617
This isn't Vista, right?
Autodesk Forums:
Message 8 of 9
i.franco
Nope, it's windows 7. I'll try to download it again and see what happens. I will let you know. Thanks a lot to you both.
Message 9 of 9
i.franco
Hello to you all. I re-downloaded the installer again and this time it worked perfectly. Apparently I did have a bad installer, now the suite is up and running. Thank you all for your assistance.
Ivan Franco
Administrator Productivity
